Platform information: openhabian OH2.1 RazBerryPi3
Issue of the topic: Onkyo Binding now all works, but makes tons of Log errors
My Onkyo Binging worked well the first time I set up Openhabian (however I never checked any logs as I dod not know where to find them). I decided to make a clean install as my rules were not working. After new setup and some help in forum my rules now work very nicely.
I had some issue to get the Onky Bining back to work. Initially it worked, the showed initializing, then offline. It was not working at all. I have removed things, binding, and even cleaned out the Json(s) files of all Onkyo entires as it was still logging errors with no Thing or item! Tried again, no luck.
Then I have changed the Onkyo from wired LAN to WLAN. An I could configure and control the Onkyo reciever. So far so good. But my openhab.log file is totally cluttered overnight with this
2017-11-13 12:11:14.261 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:6846e43e:zone1#power', b$
2017-11-13 12:11:14.266 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:b3605d64:zone1#power', b$
2017-11-13 12:11:14.271 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:5fb0e63a-e8e6-3ab9-3def-$
2017-11-13 12:11:14.274 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:d1cbc9ec:zone1#power', b$
2017-11-13 12:12:06.950 [ERROR] [nding.onkyo.internal.OnkyoConnection] - Can't connect: No route to host (Host unreachable)
2017-11-13 12:12:10.070 [ERROR] [nding.onkyo.internal.OnkyoConnection] - Can't connect: No route to host (Host unreachable)
2017-11-13 12:12:13.190 [ERROR] [nding.onkyo.internal.OnkyoConnection] - Can't connect: No route to host (Host unreachable)
2017-11-13 12:12:14.245 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:6846e43e:zone1#power', b$
2017-11-13 12:12:14.248 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:b3605d64:zone1#power', b$
2017-11-13 12:12:14.251 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:5fb0e63a-e8e6-3ab9-3def-$
2017-11-13 12:12:14.254 [WARN ] [ome.core.thing.internal.ThingManager] - Cannot delegate update 'OFF' for item 'Onkyo_Power' to handler for channel 'onkyo:TX-NR626:d1cbc9ec:zone1#power', b$
2017-11-13 12:13:09.110 [ERROR] [nding.onkyo.internal.OnkyoConnection] - Can't connect: No route to host (Host unreachable)
2017-11-13 12:13:12.230 [ERROR] [nding.onkyo.internal.OnkyoConnection] - Can't connect: No route to host (Host unreachable)
Any ideas?
Again - all function works!!! On, Off etc pp…
when I just controlled the Onkyo this came up
def-3a09e8b9e158:zone1#input', because no thing with the UID 'onkyo:TX-NR626:5fb0e63a-e8e6-3ab9-3def-3a09e8b9e158' could be found.
2017-11-13 18:20:14.559 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'onkyo:TX-NR626:5fb0e63a-e8e6-3ab9-3def-3a09e8b9e158' to inbox.
2017-11-13 18:20:15.430 [ERROR] [nding.onkyo.internal.OnkyoConnection] - Can't connect: No route to host (Host unreachable)
Any help- it is much appreciated… Probably something very basic- I am total newbe… sorry for asking a lot of questions.
But I am sort of happy my Zwave stuff now works, and my rules control my Warmwater circulation etc. and my Receiver works, for WAF this is important. She doesnt look at log files ![]()
