- Platform information:
- Hardware: Raspberry PI 3B+
- OS: Latest, updated version of OpenHABianPI
- Java Runtime Environment: latest??
- openHAB version:
I am a total newbie and encountered the error message in the topic. I use a RasPI with a CC2531 (amongst other, planned controllers)
I made an items-file containing 2 devices (IKEA outlet and switch). I found the device ID’s and put in everything.
Then I made a rule file, with “when the switch is turned on, turn on the outlet” and a corresponding off-version.
But when I push either button on the switch, I get (in the logs) what appears to be the correct response (switch is turned on or off), then I get the error “OnOff converter…”
Am i doing anything wrong, or do I have to install a MQTT broker or what?
I installed the Zigbee binding, and chose the correct settings for the CC2531. I can control the outlet from Paper UI -> Control
