I updated to 3.4.2 and then executed
- cd /etc/openhab/automation/js
- npm install openhab
- npm install openhab_rules_tools
Now I get a different error:
2023-02-27 11:01:17.972 [WARN ] [nhab.automation.script.ui.b95c424861] - "cache.get" has been deprecated and will be removed in a future release. Use "cache.private.get" or "cache.shared.get" instead. Visit the JavaScript Scripting Automation addon docs for more information about the cache.
2023-02-27 11:01:18.010 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: TypeError: (intermediate value).getItem(...).getMetadataValue is not a function
at <js>.:program(<eval>:153) ~[?:?]
at org.graalvm.polyglot.Context.eval(Context.java:399) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:426) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:264) ~[java.scripting:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:53) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:74) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:71) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) [?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:68) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1180) [bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:989) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:89) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2023-02-27 11:01:18.024 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'b95c424861' failed: org.graalvm.polyglot.PolyglotException: TypeError: (intermediate value).getItem(...).getMetadataValue is not a function
You can see the warning with the cache, but that shouldnāt be an issue.
