I try to use the OpenEnergyMonitor-Binding https://github.com/openhab/openhab/wiki/Open-Energy-Monitor-Binding with my RFM12Pi.
Using the rfm12pigw script, I am able to send received data to the UDP Port, where the Binding is supposed to listen. Well, it does listen but something is wrong with the parsing. This is what I get from the log:
2015-11-16 21:57:02.120 [TRACE] [b.o.i.OpenEnergyMonitorBinding] - Received data (len=7): 15EC1800106200 Exception in thread "Thread-25" java.lang.ArrayIndexOutOfBoundsException: 1 at org.openhab.binding.openenergymonitor.protocol.OpenEnergyMonitorDataP arser.toShort(OpenEnergyMonitorDataParser.java:113) at org.openhab.binding.openenergymonitor.protocol.OpenEnergyMonitorDataP arser.convertTo(OpenEnergyMonitorDataParser.java:93) at org.openhab.binding.openenergymonitor.protocol.OpenEnergyMonitorDataP arser.parseData(OpenEnergyMonitorDataParser.java:51) at org.openhab.binding.openenergymonitor.internal.OpenEnergyMonitorBindi ng$MessageListener.run(OpenEnergyMonitorBinding.java:199)
when I used this settings in the cfg:
openenergymonitor:udpPort=9997
openenergymonitor:Tiny1=21:U16(0)
openenergymonitor:Tiny2=21:U16(2|1)
openenergymonitor:Tiny3=21:U16(4|3)
openenergymonitor:Tiny4=21:U16(6|5)
I also tried indexing from 1 to 7 or just or just using byte 1-2 but nothing seems to work.
Any input is highly appreciated. Thank you very much in advance
RandomWireMan
