Hi, I have the problem that can be seen in the photo and I can’t run the openhab Designer. The demo is running perfectly.
I use windows 7 and eclipse luna and mars, but none of them doing anything.
Thank you for your time in advance
Which version of Java do you use?
jdk1.8.0_74 x64
ok, then simply install 32bit-Version additional, cause Designer needs 32bit-Version (has imho no negative side-effects)
Yes that was it. Thank you very much or your help
