I’ve been using OpenHab 1.8 for a while without any issues (at some point I’ll move to 2.0). For now, since everything is working correctly I haven’t wanted to make any changes.
Then last night, OpenHAB stopped working. I haven’t changed anything on my computer (Windows 10) or installed any new software or hardware, so I don’t even know where to begin looking for the issue.
Below is what I am now getting in the console. Any ideas of what may have gone wrong and what I can do to fix it?
Thank you in advance!
C:\OpenHAB>java -Dosgi.clean=true -Declipse.ignoreApp=true -Dosgi.noShutdown=true -Djetty.port=8080 -Djetty.port.ssl=8443 -Djetty.home=. -Dlogback.configurationFile=configurations/logback.xml -Dfelix.fileinstall.dir=addons -Dfelix.fileinstall.filter=.*\\.jar -Djava.library.path=lib -Djava.security.auth.login.config=./etc/login.conf -Dorg.quartz.properties=./etc/quartz.properties -Dequinox.ds.block_timeout=240000 -Dequinox.scr.waitTimeOnBlock=60000 -Djava.awt.headless=true -Dfelix.fileinstall.active.level=4 -jar C:\OpenHAB\server\plugins\org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar -console
osgi> 2017-02-11 21:12:55.472 [WARN ] [.u.component.AbstractLifeCycle] - FAILED SelectChannelConnector@0.0.0.0:8080: java.net.BindException: Address already in use: bind
at sun.nio.ch.Net.bind0(Native Method) ~[na:1.8.0_111]
at sun.nio.ch.Net.bind(Unknown Source) ~[na:1.8.0_111]
at sun.nio.ch.ServerSocketChannelImpl.bind(Unknown Source) ~[na:1.8.0_111]
at sun.nio.ch.ServerSocketAdaptor.bind(Unknown Source) ~[na:1.8.0_111]
at org.eclipse.jetty.server.nio.SelectChannelConnector.open(SelectChannelConnector.java:182) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.AbstractConnector.doStart(AbstractConnector.java:311) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.nio.SelectChannelConnector.doStart(SelectChannelConnector.java:260) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) [org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.server.Server.doStart(Server.java:273) [org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.ServerInstanceWrapper.start(ServerInstanceWrapper.java:166) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.JettyServerServiceTracker.serviceChanged(JettyServerServiceTracker.java:112) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:107) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:861) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:819) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:771) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:130) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:214) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:433) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.registerService(BundleContextImpl.java:451) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.DefaultJettyAtJettyHomeHelper.startJettyAtJettyHome(DefaultJettyAtJettyHomeHelper.java:156) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.osgi.boot.JettyBootstrapActivator.start(JettyBootstrapActivator.java:119) [org.eclipse.jetty.osgi.boot_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at java.security.AccessController.doPrivileged(Native Method) [na:1.8.0_111]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [org.eclipse.osgi_3.8.2.v20130124-134944.jar:na]
2017-02-11 21:12:55.660 [WARN ] [.u.component.AbstractLifeCycle] - FAILED SslSelectChannelConnector@0.0.0.0:8443: java.net.BindException: Address already in use: bind
at org.eclipse.jetty.server.ssl.SslSelectChannelConnector.doStart(SslSelectChannelConnector.java:626) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
2017-02-11 21:12:55.660 [WARN ] [.u.component.AbstractLifeCycle] - FAILED org.eclipse.jetty.server.Server@45425145: MultiException[java.net.BindException: Address already in use: bind, java.net.BindException: Address already in use: bind]
org.eclipse.jetty.util.MultiException: Multiple exceptions
at org.eclipse.jetty.server.Server.doStart(Server.java:255) ~[org.eclipse.jetty.server_8.1.3.v20120522.jar:8.1.3.v20120522]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) ~[org.eclipse.jetty.util_8.1.3.v20120522.jar:8.1.3.v20120522]
2017-02-11 21:12:56.735 [WARN ] [.i.s.JettyServerServiceTracker] -
at org.eclipse.jetty.server.Server.doStart(Server.java:255) ~[na:na]
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:59) ~[na:na]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.ServerInstanceWrapper.start(ServerInstanceWrapper.java:166) ~[na:na]
at org.eclipse.jetty.osgi.boot.internal.serverfactory.JettyServerServiceTracker.serviceChanged(JettyServerServiceTracker.java:112) ~[na:na]
2017-02-11 21:12:56.886 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.7.0).
2017-02-11 21:12:57.272 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2017-02-11 21:12:57.330 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2017-02-11 21:13:01.907 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = COM3
2017-02-11 21:13:01.907 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 1
2017-02-11 21:13:01.909 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, softReset = true
2017-02-11 21:13:01.909 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2017-02-11 21:13:01.915 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2017-02-11 21:13:01.915 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is true.
2017-02-11 21:13:01.915 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port COM3
2017-02-11 21:13:02.042 [INFO ] [.o.b.wemo.internal.WemoBinding] - Wemo device 'DiningRoom' found at 'http://192.168.1.11:49153'
2017-02-11 21:13:02.128 [INFO ] [.o.b.wemo.internal.WemoBinding] - Wemo device 'DiningRoom' found at 'http://192.168.1.11:49153'
2017-02-11 21:13:02.360 [INFO ] [b.z.i.protocol.ZWaveController] - Serial port is initialized
2017-02-11 21:13:02.387 [INFO ] [.b.a.internal.bus.AstroBinding] - AstroConfig[latitude=41.097093,longitude=-74.115518,interval=disabled,systemTimezone=America/New_York (EST -0500),daylightSavings=false]
2017-02-11 21:13:02.389 [INFO ] [o.o.b.w.i.common.WeatherConfig] - ProviderConfig[providerName=OPENWEATHERMAP,apiKey=fd635434a6091506db78dd8f48d921ce]
2017-02-11 21:13:02.389 [INFO ] [o.o.b.w.i.common.WeatherConfig] - LocationConfig[providerName=OPENWEATHERMAP,language=en,updateInterval=10,latitude=41.097396,longitude=-74.115593,locationId=home,name=<null>]
2017-02-11 21:13:02.557 [INFO ] [o.o.i.o.internal.CloudClient ] - Connected to the openHAB Cloud service (UUID = 1880517f-6911-496d-b44d-cd9a81ec8e74, local base URL = http://localhost:8080)
2017-02-11 21:13:05.391 [INFO ] [.o.b.w.i.s.WeatherJobScheduler] - Disabling weather locationId 'home', no binding available
2017-02-11 21:13:05.417 [INFO ] [.b.a.internal.job.JobScheduler] - Scheduled a daily job at midnight for astro calculation
2017-02-11 21:13:05.469 [INFO ] [rialApiGetInitDataMessageClass] - NODE 1: Node found
2017-02-11 21:13:05.469 [INFO ] [rialApiGetInitDataMessageClass] - NODE 2: Node found
2017-02-11 21:13:05.470 [INFO ] [rialApiGetInitDataMessageClass] - NODE 3: Node found
2017-02-11 21:13:05.470 [INFO ] [rialApiGetInitDataMessageClass] - NODE 4: Node found
2017-02-11 21:13:05.471 [INFO ] [rialApiGetInitDataMessageClass] - NODE 5: Node found
2017-02-11 21:13:05.471 [INFO ] [rialApiGetInitDataMessageClass] - NODE 11: Node found
2017-02-11 21:13:05.471 [INFO ] [rialApiGetInitDataMessageClass] - NODE 13: Node found
2017-02-11 21:13:05.472 [INFO ] [rialApiGetInitDataMessageClass] - NODE 16: Node found
2017-02-11 21:13:05.472 [INFO ] [rialApiGetInitDataMessageClass] - NODE 17: Node found
2017-02-11 21:13:05.472 [INFO ] [rialApiGetInitDataMessageClass] - NODE 18: Node found
2017-02-11 21:13:05.472 [INFO ] [rialApiGetInitDataMessageClass] - NODE 19: Node found
2017-02-11 21:13:05.473 [INFO ] [rialApiGetInitDataMessageClass] - NODE 20: Node found
2017-02-11 21:13:05.473 [INFO ] [rialApiGetInitDataMessageClass] - NODE 21: Node found
2017-02-11 21:13:05.473 [INFO ] [rialApiGetInitDataMessageClass] - NODE 24: Node found
2017-02-11 21:13:05.473 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller using Controller API
2017-02-11 21:13:05.474 [INFO ] [rialApiGetInitDataMessageClass] - ZWave Controller is Primary Controller
2017-02-11 21:13:05.474 [INFO ] [rialApiGetInitDataMessageClass] - ------------Number of Nodes Found Registered to ZWave Controller------------
2017-02-11 21:13:05.474 [INFO ] [rialApiGetInitDataMessageClass] - # Nodes = 14
2017-02-11 21:13:05.474 [INFO ] [rialApiGetInitDataMessageClass] - ----------------------------------------------------------------------------
2017-02-11 21:13:05.674 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 2: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.677 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 3: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.683 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 5: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.686 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 11: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.689 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 13: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.692 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 16: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.695 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 17: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.697 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 18: Unsupported command class SCENE_ACTUATOR_CONF
2017-02-11 21:13:05.698 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 18: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.701 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 19: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.704 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 20: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.706 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SCENE_ACTUATOR_CONF
2017-02-11 21:13:05.707 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 21: Unsupported command class SWITCH_ALL
2017-02-11 21:13:05.709 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 24: Unsupported command class SWITCH_ALL
2017-02-11 21:13:06.678 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 2: No item bound for event, endpoint = 0, command class = SWITCH_BINARY, value = 255, ignoring.
