openHAB 2.0 beta2 available!
All,
I have just created a new beta release for openHAB 2, which fixes many issues that were discovered in the beta1, most of them due to the switch to Karaf. Especially openHAB 1 add-ons had many issues and a lot of this has been fixed meanwhile. Thanks to everybody involved in testing (special thanks to @Lolodomo here!). There is still work to do, but I think beta2 is a huge step forward, so it makes sense to replace beta1 by it, so that this isn’t used anymore.
In any case, for testing I definitely recommend to always use the latest snapshot, since there is a frequent flow of fixes and enhancements.
Best regards,
Kai
hi
beta 2 vanilla install … no modifications at all throws:
openhab> [Fatal Error] :33:5: The element type “meta” must be terminated by the matching end-tag “”.
does run anyways
Online or offline distro? Which OS and JVM?
I use the Beta 2 Offline Distro and it works quite good! Had no problems yet and also no Error Message like shorty707.
Online
Latest raspbian in rpi2
I actually saw this today on my beta1 instance at startup…also.
Is there any further information available in the openhab.log? I have no clue where this message might come from…
no thats all.
Getting this error as well..
May I ask you to enter an issue here?
I released my Synology DiskStation package to release 2.0.0-beta2:
Cool, thanks. What would you think about moving the project GitHub - openhab/openhab-syno-spk: openHAB Synology SPK Install Package · GitHub to GitHub - openhab/openhab-syno-spk: openHAB Synology SPK Install Package · GitHub (with you of course staying the admin with full access to the repo)?
Hi Kai,
OK, Thanks!
I’ll try to give my best…
Chris
You can easily transfer repos through Github, just PM me if you want to coordinate that!
Is there any more information/fix on the “The element type “meta” must be terminated by the matching end-tag” error?
I am having it as well under Mac OS X with the latest Oracle JDK installation.
It is tracked under [Fatal Error] :33:5: The element type "meta" must be terminated by the matching end-tag "</meta>". · Issue #121 · openhab/openhab-distro · GitHub
I do not see this on OS X…
really strange
I see this error now for a long time … lets says last 15 builds at least
also used the tip from another guy to change from demo to standard before first bootup → still that error
Hello my name is Mark Ingle. I am new to this community. Recently I have purchased a ESP12E Dev board and set it up with OpenHAB 1.8.1 to get a simple LED test working. I noticed 2.0 Beta was available and I have latest snapshot running via start.bat. However I cannot get the landing page working…are there some instructions o check list for setting 2.0? I would like to contribute to testing if you need the help.
Thanks in advance for help!
MArk
https://github.com/openhab/openhab-distro/blob/master/docs/sources/getting-started.md#starting-the-runtime
https://github.com/openhab/openhab-distro/blob/master/docs/sources/getting-started.md#getting-started-with-openhab-2
https://github.com/openhab/openhab-distro/blob/master/docs/sources/features/compatibilitylayer.md
@sihui thank you!!!
