openHAB 2.0 beta4 has been released!
What was the exact permissions issue? I am having the same problem after updating (no extensions show up on Paper UI), but I don’t see anything wrong with my runtime directory.
Also, the Basic UI doesn’t even seem to load, just shows the home bar at the top…
My runtime directory was owned by root, not the user I run openhab as.
Thinking back, I also purged the contents of userdata/cache/* and userdata/tmp/*, and that may have had more to do with it than the permissions.
That should not be a problem. Configuration and userdata need to belong to openhab though.
Without being able to reference the thread, this was proposed as the solution for this problem. This should do: sudo rm -rf /var/lib/openhab2/cache/*
You will probably also need to reinstall your addons. Don’t worry, the things linked to them before are still known.
Hi
Is the OH2 download on the main OH website the beta4 version or is it still the beta2 version?
http://www.openhab.org/getting-started/downloads.html
It would be handy if the website actually stated what versions they are.
Thanks,
Neil.
@nweha27
Try this link http://docs.openhab.org/overview.html .
This will take you to the OH2 docs and download links.
This fixed my problem with no extensions showing up. Thanks!
It states that these are the snapshot releases (also mentioned in the filename) - so that is always the latest nightly build.
Following instructions on: http://docs.openhab.org/installation/linux.html#package-repository-installation
W: Failed to fetch //openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-offline/target/apt-repo/Packages HttpError404
W: Failed to fetch //openhab.ci.cloudbees.com/job/openHAB-Distribution/ws/distributions/openhab-online/target/apt-repo/Packages HttpError404
Looking at https://openhab.ci.cloudbees.com/job/openHAB-Distribution/
Build #556 (Oct 26, 2016 3:31:10 AM) Failed, so cant install using this method :-/
Edit: Update… Build #556 does seem to have issues… I also get the same error (404) when running apt-get update and it does appear as Failed on Cloudbees…
BR,
Dim
The last build failed, therefore the snapshot repo is wiped out. The repo will be available on the next successful build. We’ll working on a solution to get rid of the dependency of build success to having a snapshot apt-repo. Stay tuned, it will need some time to get this done.
I just installed the new build (#557) using apt-get on a Raspberry Pi 3 from https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ and all work fine
Thanx @theo !
Question, as it is now some weeks since the last beta release.
Should i wait for a new beta version before starting a fresh install, or is it no problem to get started tonight?
Up to you. You can start with the current snapshot or wait for the next beta (which I’d plan for some time mid December).
Is the http://dl.bintray.com/openhab/apt-repo2/dists/testing/Release.gpg repo gone now?
I am not sure, but eclipse does not like any of the URLs I have found from Kai. Tonight, I will try to download the tar ball and create a new project with it and see if that works. Seems like he has that code in a different place and not the git repo.
Otherwise, I think I may start my new development on my local copy of the master branch.
Great work. Congrats from the Eclipse Foundation Europe :slight_smile:
