Openhab 2.3 not corretly running Build 1231
  • Platform information:
    • Hardware:Raspberry Debian Stretch
    • OS: 4.9.80-v7+ #1098 SMP Fri Mar 9 19:11:42 GMT 2018 armv7l GNU/Linux
    • Java Runtime Environment: openjdk version “1.8.0_152”
      OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8.0_152-b76)
      OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, mixed mode, Evaluation)
    • openHAB version: 2.3 Build 1231
  • Issue of the topic:
KNX don’t work, it is not installed:
my openhab.log:
-03-17 14:14:48.344 [WARN ] [eclipse.jetty.servlet.ServletHandler] -
javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
  1. java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_3,4,11332951) has been shut down
    at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) [164:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [164:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [164:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [164:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [164:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [16:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [81:org.eclipse.jetty.servlet:9.3.21.v20170918]
    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [81:org.eclipse.jetty.servlet:9.3.21.v20170918]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [180:org.ops4j.pax.web.pax-web-jetty:6.0.9]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [78:org.eclipse.jetty.security:9.3.21.v20170918]
    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [180:org.ops4j.pax.web.pax-web-jetty:6.0.9]
    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [81:org.eclipse.jetty.servlet:9.3.21.v20170918]
    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [180:org.ops4j.pax.web.pax-web-jetty:6.0.9]
    at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.server.Server.handle(Server.java:534) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [80:org.eclipse.jetty.server:9.3.21.v20170918]
    at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [73:org.eclipse.jetty.io:9.3.21.v20170918]
    at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [73:org.eclipse.jetty.io:9.3.21.v20170918]
    at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [73:org.eclipse.jetty.io:9.3.21.v20170918]
    at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [84:org.eclipse.jetty.util:9.3.21.v20170918]
    at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [84:org.eclipse.jetty.util:9.3.21.v20170918]
    at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [84:org.eclipse.jetty.util:9.3.21.v20170918]
    at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [84:org.eclipse.jetty.util:9.3.21.v20170918]
    at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [84:org.eclipse.jetty.util:9.3.21.v20170918]
Caused by: org.glassfish.hk2.api.MultiException: A MultiException has 1 exceptions. They are:
    at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:106) ~[?:?]
    at org.jvnet.hk2.internal.FactoryCreator.dispose(FactoryCreator.java:173) ~[?:?]
    at org.jvnet.hk2.internal.SystemDescriptor.dispose(SystemDescriptor.java:526) ~[?:?]
    at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[166:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[166:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[166:org.glassfish.jersey.core.jersey-common:2.22.2]
    at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[167:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[167:org.glassfish.jersey.core.jersey-server:2.22.2]
    at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[164:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
    … 31 more
Caused by: java.lang.IllegalStateException: ServiceLocatorImpl(__HK2_Generated_3,4,11332951) has been shut down
at org.jvnet.hk2.internal.ServiceLocatorImpl.checkState(ServiceLocatorImpl.java:2288) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandleImpl(ServiceLocatorImpl.java:629) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:622) ~[?:?]
at org.jvnet.hk2.internal.ServiceLocatorImpl.getServiceHandle(ServiceLocatorImpl.java:640) ~[?:?]
at org.jvnet.hk2.internal.FactoryCreator.getFactoryHandle(FactoryCreator.java:103) ~[?:?]
… 31 more
javax.servlet.ServletException: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
    at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) [180:org.ops4j.pax.web.pax-web-jetty:6.0.9]
Caused by: javax.servlet.ServletException: A MultiException has 1 exceptions. They are:
    at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
    at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
    at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
    at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
    at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[?:?]
    at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) ~[?:?]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
    at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
    at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) ~[?:?]
    at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) ~[?:?]
    at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) ~[?:?]
    at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) ~[?:?]
    at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) ~[?:?]
    at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) ~[?:?]
    at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
    at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
    … 13 more
    at org.glassfish.jersey.process.internal.RequestScope$Instance.remove(RequestScope.java:532) ~[?:?]
    at org.glassfish.jersey.process.internal.RequestScope$Instance.release(RequestScope.java:549) ~[?:?]
    at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:319) ~[?:?]
    at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
    at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
    at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
    … 13 more
… 13 more
====> /var/log/openhab2/openhab.log <==
2018-03-17 14:14:49.945 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-03-17 14:14:50.054 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing ‘openhab-binding-knx1’: Error restarting bundles:
Unable to acquire the state change lock for the module: osgi.identity; type=“osgi.bundle”; version:Version=“0.10.0.201803161254”; osgi.identity=“org.eclipse.smarthome.model.script.runtime”; singleton:=“true” [id=136] STARTED [STARTED]
Check with the PaperUI if all bindings/add-ons are correct installed
It is.
First it wasn´t, than I installed the KNX binding, but it will not start.
After installing I´ve stopped and started openhab
I think KNX Binding is active:
244 │ Active │ 80 │ 2.3.0.201803161151 │ KNX Binding
But it doesn’t work. Furthertime I’ve seen that a connection to knx is established. but with this build there is no entry in the log. Also I changed the knx.cfg, than you get a log-info, but not yet. Whats wrong?
Is the KNX binding a new beinding? Do this also work, or have I to redefine all my KNX configuration? Is this working: Switch UG_Heizung “Licht Heizungsraum” (gUG) {knx=“1/1/1+<1/7/1”}
before I updatet it works fine
my English is not so good
Just a remark (I don’t have any knowledge on this subject and not able to support)
Kai Kreuzer posted a message regarding the latest 2.3 update → New KNX binding
Check manual as the configuration is different
https://docs.openhab.org/addons/bindings/knx/readme.html#full-example
I think the old KNX Binding 1 is killed, compromisslos . I see only the new version, so that I must have to reconfigure all my KNX Items. It is unfair to do that on this way.
No, it has been moved to the legacy package as I have mentioned in the annoucement. All you need to make sure is to enable legacy bindings (e.g. in the addons.cfg) and you can continue to use the old KNX binding without any problem.
It helps, thanks. In the Paper UI it was not set. It was not necessary because it run’s
In fact, knx1 is legacy since Build #1230, so just before this build, it was the only knx binding and not legacy at all.
Since Build 1230 there are two knx bindings, the new knx2 binding, fully configurable through Paper UI (or *.things text file…) and the old one, now marked as legacy. So if you want to stay at knx1, you have to enable legacy bindings, which will enable all other old (in the meaning of: there is also an OH2 type) bindings as well.
Where “enable” actually means “make them available for installation”, i.e. they are not automatically installed by this - it is just that another repository is added to the system from which add-ons are resolved.
