We are planning to release openHAB 2.3 next Monday (May 28).
In contrast to our plans, we didn’t manage to provide regular milestone builds on our way there (sorry for that), but we now at least have a Release Candidate build available!
The build is also available in the “testing” repos for apt and yum (thanks @Benjy!).
It would be great if as many people as possible could go and test this build - if you come across critical or major issues that must be solved before the release, please report them here asap!
Is that something really worth for a WARN message and to bother the regular user with it? I’d definitely prefer a DEBUG message in such cases unless something is malfunctioning and the user has a chance to correct it.
There are also some warnings for items with tags when you start a new instance and choose the Demo package in the “Initial setup”:
21:48:25.744 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'demo.sitemap'
21:48:25.771 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'demo.things'
21:48:29.388 [INFO ] [del.core.internal.ModelRepositoryImpl] - Loading model 'demo.rules'
21:48:29.420 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.things'
21:48:29.433 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.sitemap'
21:48:29.449 [INFO ] [del.core.internal.ModelRepositoryImpl] - Refreshing model 'demo.items'
21:48:29.458 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Light_GF_Living_Table in ManagedMetadataProviderImpl, because it does not exists.
21:48:29.460 [INFO ] [smarthome.event.ItemUpdatedEvent ] - Item 'Light_GF_Living_Table' has been updated.
21:48:29.460 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Light_C_Workshop in ManagedMetadataProviderImpl, because it does not exists.
21:48:29.461 [INFO ] [smarthome.event.ItemUpdatedEvent ] - Item 'Light_C_Workshop' has been updated.
21:48:29.461 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Light_Garden_Garage in ManagedMetadataProviderImpl, because it does not exists.
21:48:29.462 [INFO ] [smarthome.event.ItemUpdatedEvent ] - Item 'Light_Garden_Garage' has been updated.
21:48:29.462 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Temperature_GF_Kitchen in ManagedMetadataProviderImpl, because it does not exists.
21:48:29.463 [INFO ] [smarthome.event.ItemUpdatedEvent ] - Item 'Temperature_GF_Kitchen' has been updated.
21:48:29.464 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Thermostat in ManagedMetadataProviderImpl, because it does not exists.
21:48:29.465 [INFO ] [smarthome.event.ItemUpdatedEvent ] - Item 'Thermostat' has been updated.
21:48:29.465 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Temperature_Setpoint in ManagedMetadataProviderImpl, because it does not exists.
21:48:29.466 [INFO ] [smarthome.event.ItemUpdatedEvent ] - Item 'Temperature_Setpoint' has been updated.
21:48:29.466 [WARN ] [mmon.registry.AbstractManagedProvider] - Could not update element with key _tags:Thermostat_Mode in ManagedMetadataProviderImpl, because it does not exists.
The URL of the FFH radio station in the Demo is broken:
22:28:43.843 [INFO ] [smarthome.event.ItemStateChangedEvent] - Radio_Station changed from 0 to 3
22:28:43.889 [ERROR] [e.smarthome.core.audio.URLAudioStream] - Cannot set up stream 'http://edge.live.mp3.mdn.newmedia.nacamar.net/radioffh/livestream.mp3.m3u': http://edge.live.mp3.mdn.newmedia.nacamar.net/radioffh/livestream.mp3.m3u
java.io.FileNotFoundException: http://edge.live.mp3.mdn.newmedia.nacamar.net/radioffh/livestream.mp3.m3u
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1890) ~[?:?]
22:28:43.920 [WARN ] [.smarthome.model.script.actions.Audio] - Failed streaming audio url: IO Error
The icon of the Map/Location of the “Brandenburg Gate Berlin” in the Widget Overview does not exist. Browser console logs: GET http://localhost:8080/icon/mapview?format=svg 404 (Not Found)
2018-05-23 00:04:25.541 [ERROR] [me.core.internal.events.EventHandler] - Creation of ESH-Event failed, because one of the registered event factories has thrown an exception: Error invoking #valueOf(String) on class 'org.eclipse.smarthome.core.library.types.QuantityType' with value '0 W/m2'.
java.lang.IllegalStateException: Error invoking #valueOf(String) on class 'org.eclipse.smarthome.core.library.types.QuantityType' with value '0 W/m2'.
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:178) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseType(ItemEventFactory.java:146) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.getState(ItemEventFactory.java:124) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.createStateEvent(ItemEventFactory.java:111) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.createEventByType(ItemEventFactory.java:77) ~[?:?]
at org.eclipse.smarthome.core.events.AbstractEventFactory.createEvent(AbstractEventFactory.java:50) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.createESHEvent(EventHandler.java:121) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.handleEvent(EventHandler.java:95) ~[?:?]
at org.eclipse.smarthome.core.internal.events.EventHandler.handleEvent(EventHandler.java:72) ~[?:?]
at org.eclipse.smarthome.core.internal.events.ThreadedEventHandler.lambda$0(ThreadedEventHandler.java:67) ~[?:?]
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.items.events.ItemEventFactory.parseSimpleClassName(ItemEventFactory.java:169) ~[?:?]
... 10 more
Caused by: java.lang.IllegalArgumentException: unexpected token 8
at tec.uom.se.quantity.Quantities.getQuantity(Quantities.java:80) ~[?:?]
at org.eclipse.smarthome.core.library.types.QuantityType.<init>(QuantityType.java:89) ~[?:?]
at org.eclipse.smarthome.core.library.types.QuantityType.valueOf(QuantityType.java:132) ~[?:?]
... 10 more
2018-05-23 00:04:26.237 [ERROR] [me.core.internal.events.EventHandler] - Creation of ESH-Event failed, because one of the registered event factories has thrown an exception: Error invoking #valueOf(String) on class 'org.eclipse.smarthome.core.library.types.QuantityType' with value '0 W/m2'.
... 10 more
... 10 more
2018-05-23 07:20:52.826 [WARN ] [rm.AbstractFileTransformationService] - Could not transform 'NULL' with the file 'beaufort.scale' : Scale can only be used with numeric inputs
Any way to get rid of that.
Also I get a lot of:
2018-05-23 07:20:15.283 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2018-05-23 07:20:15.307 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2018-05-23 07:20:15.311 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2018-05-23 07:20:15.314 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2018-05-23 07:20:15.387 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type MAP
2018-05-23 07:20:15.391 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'MAP' is not available.
2018-05-23 07:20:15.452 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type SCALE
2018-05-23 07:20:15.465 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'SCALE' is not available.
2018-05-23 07:20:15.533 [WARN ] [.core.transform.TransformationHelper] - Cannot get service reference for transformation service of type JS
2018-05-23 07:20:15.554 [WARN ] [.core.transform.TransformationHelper] - Couldn't transform value because transformation service of type 'JS' is not available.
At start up just after the items files loading.
Is there a way to get the transforms to load before the items?
Not sure how to fix this. Could you enter an issue at ESH for it, please? If anyone has an idea how to fix it, please do so - if not, it should be ok to leave it as is for the release if it does not have any functional impact.
(Likely) same problem for me. Running on Pi3 with Zulu java 1.8.0_152-b76, I have been having to use alsa tools to (statically) set volume. I think it used to work long ago when I was still using Oracle java but can’t tell for sure.
EDIT: However, according to this, the same provlem happens on x86 and Oracle Java.
Calling setMasterVolume(float) gives
2018-05-23 12:11:41.149 [WARN ] [core.audio.internal.AudioManagerImpl] - An exception occurred while getting the volume of sink 'enhancedjavasound' : Cannot determine master volume level
java.io.IOException: Cannot determine master volume level
at org.eclipse.smarthome.io.javasound.internal.JavaSoundAudioSink.getVolume(JavaSoundAudioSink.java:118) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.getVolume(AudioManagerImpl.java:184) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.play(AudioManagerImpl.java:122) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.playFile(AudioManagerImpl.java:164) ~[?:?]
at org.eclipse.smarthome.core.audio.internal.AudioManagerImpl.playFile(AudioManagerImpl.java:144) ~[?:?]
at org.eclipse.smarthome.model.script.actions.Audio.playSound(Audio.java:40) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1085) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1060) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1046) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:991) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:143) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:901) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:864) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:223) ~[?:?]
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:203) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:446) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:227) ~[?:?]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:189) ~[?:?]
at org.eclipse.smarthome.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:82) ~[?:?]
at org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl.lambda$2(RuleEngineImpl.java:345) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
I have some problems with linking items to a channel in PaperUI. I clicked on the blue button to link a channel in the Configuration -> Thing section, selected “Create new item”, confirmed it by clicking on “Link”. Popup remained open and nothing happened. The Item has been created in the background but the link didn’t establish.
Innogy smarthome binding is not working in RC1. OH2 with installed binding is not starting up, removing cache and tmp folders also does not help. After removing the binding from addons.cfg and trying to reinstall the following error messages are displayed:
