Iβve got VoiceRSS working, which is nice, but now wanted to try Google Text to Speech. I am running OpenHAB 2.5.0.M1 on Openhabian. According to what I read in the forums so far, there was a problem with Google TTS on RPI but that was solved since 2.4. So I should be getting the correct version of the binding and it should just work.
I installed and configured Google TTS via Paper UI but see this in the logs:
2019-03-15 09:31:47.257 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.M1 (214)[org.openhab.voice.googletts.internal.GoogleTTSService(237)] : The activate method has thrown an exception
at org.openhab.voice.googletts.internal.GoogleCloudAPI.listVoices(GoogleCloudAPI.java:250) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.initVoices(GoogleCloudAPI.java:222) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.setConfig(GoogleCloudAPI.java:146) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleTTSService.updateConfig(GoogleTTSService.java:215) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleTTSService.activate(GoogleTTSService.java:122) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
2019-03-15 09:31:47.619 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:73) ~[?:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) ~[?:?]
2019-03-15 09:31:48.153 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.M1 (214)[org.openhab.voice.googletts.internal.GoogleTTSService(237)] : The activate method has thrown an exception
2019-03-15 09:31:48.570 [DEBUG] [org.openhab.voice.googletts ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.voice.TTSService}={serviceAccountKey={
"type": "service_account",
"project_id": "homeautomation-234507",
"private_key_id": "*************************",
"private_key": "*************************",
"client_email": "***********************",
"client_id": "***********************",
"auth_uri": "https://accounts.google.com/o/oauth2/auth",
"token_uri": "https://oauth2.googleapis.com/token",
"auth_provider_x509_cert_url": "https://www.googleapis.com/oauth2/v1/certs",
"client_x509_cert_url": "https://www.googleapis.com/robot/v1/metadata/x509/openhab2%40homeautomation-234507.iam.gserviceaccount.com"
}, service.id=407, service.bundleid=214, service.scope=bundle, component.name=org.openhab.voice.googletts.internal.GoogleTTSService, service.config.label=Google Cloud Text-to-Speech, pitch=0.0, component.id=237, purgeCache=false, volumeGain=0.0, speakingRate=1.0, service.config.category=voice, service.config.description.uri=voice:googletts, service.pid=org.openhab.voice.googletts} - org.openhab.voice.googletts
2019-03-15 09:31:48.554 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
thanks for reporting this issue. For me the Google TTS voice is working fine on a Raspberry Pi. I have the slight feeling that there is something wrong with your Google account configuration. I asked @wborn and @gbicskei - the initial contributor - for help.
Additionally I submitted a fix to prevent the NPE:
Any suggestions how to find out what is wrong? @cweitkamp said it might be something with my account configuration. But I have no clue what to look at.
I think the problem is in 2.5.0.
I am running 2.5.0 Snapshot 1575, and google tts throw me the same errors on restart.
Logs:
2019-04-24 08:26:58.312 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.201904202142 (294)[org.openhab.voice.googletts.internal.GoogleTTSService(371)] : The activate method has thrown an exception
java.lang.NoClassDefFoundError: com/google/api/client/json/webtoken/JsonWebSignature$Header
at com.google.auth.oauth2.ServiceAccountCredentials.createAssertion(ServiceAccountCredentials.java:523) ~[?:?]
at com.google.auth.oauth2.ServiceAccountCredentials.refreshAccessToken(ServiceAccountCredentials.java:369) ~[?:?]
at com.google.auth.oauth2.OAuth2Credentials.refresh(OAuth2Credentials.java:181) ~[?:?]
at com.google.auth.oauth2.OAuth2Credentials.getRequestMetadata(OAuth2Credentials.java:167) ~[?:?]
at com.google.auth.Credentials.getRequestMetadata(Credentials.java:73) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.getAuthorization(GoogleCloudAPI.java:176) ~[?:?]
at org.openhab.voice.googletts.internal.GoogleCloudAPI.listVoices(GoogleCloudAPI.java:241) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [42:org.apache.felix.scr:2.1.16]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [?:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [42:org.apache.felix.scr:2.1.16]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [42:org.apache.felix.scr:2.1.16]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
Caused by: java.lang.ClassNotFoundException: com.google.api.client.json.webtoken.JsonWebSignature$Header cannot be found by com.google.auth.google-auth-library-oauth2-http_0.13.0
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:?]
... 93 more
2019-04-24 08:26:58.327 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
2019-04-24 08:26:58.348 [INFO ] [.googletts.internal.GoogleTTSService] - Using cache folder /var/lib/openhab2/cache/org.openhab.voice.googletts
2019-04-24 08:26:58.352 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.201904202142 (294)[org.openhab.voice.googletts.internal.GoogleTTSService(371)] : The activate method has thrown an exception
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [20:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
2019-04-24 08:26:58.381 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
Edit: google TTS was working fine before upgrading to 2.5.0, and i believe S1575 includes #5123, so it should be something more than the NPE here.
Welcome to the community. It looks like some missing dependencies in your environment. Could you run the bundle:list command from Karaf console? It will show you all installed bundles which should include these for Google TTS:
261 β Active β 80 β 1.7.0 β Google API Common
262 β Active β 80 β 1.42.0 β Google API GAX
263 β Active β 80 β 0.13.0 β Google Auth Library Credentials
264 β Active β 80 β 0.13.0 β Google Auth Library OAuth2 HTTP
265 β Active β 80 β 20.0.0 β Guava: Google Core Libraries for Java
266 β Active β 80 β 1.27.0 β Google HTTP Client Library for Java
267 β Active β 80 β 1.27.0 β Google HTTP Client Jackson 2
268 β Active β 80 β 1.10.0 β Apache Commons Codec
269 β Active β 80 β 2.5.0.201904202142 β openHAB Add-ons :: Bundles :: Google Cloud Text-to-Speech
270 β Active β 80 β 1.3.3 β ThreeTen backport
If they do not occur try to uninstall and install the Google TTS binding.
I have the same, itβs starts after build 1563. Google TTS in Karaf console is in waiting state. When i rollback to 1563 every thing works. In Paper UI selectors for default TTS and default voice are missing.
My config:
OS: openHABian
Ubuntu 18.04.2 LTS
Hardware: AAEON UP-CHT01/UP-CHT01, BIOS UPC1DM15 11/09/2018
openjdk version β1.8.0_212β
OpenJDK Runtime Environment (Zulu 8.38.0.13-CA-linux64) (build 1.8.0_212-b04)
OpenJDK 64-Bit Server VM (Zulu 8.38.0.13-CA-linux64) (build 25.212-b04, mixed mode)
May I ask you to run diag <bundleId> to get some diagnostics on the bundle. Or activate DEBUG logging for org.openhab.voice.googletts and do another restart of the bundle. Thanks.
And Debug (Part 1, with obfuscated service account key):
2019-04-25 10:34:29.442 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.201904202142 (333)[org.openhab.voice.googletts.internal.GoogleTTSService(374)] : The activate method has thrown an exception
at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1919) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:458) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:382) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:294) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1242) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1137) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:997) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1176) [42:org.apache.felix.scr:2.1.16]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:927) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:892) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:135) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:969) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:823) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:805) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:584) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:716) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:510) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:429) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:292) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) [42:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) [42:org.apache.felix.scr:2.1.16]
at org.eclipse.osgi.container.Module.doStop(Module.java:634) [?:?]
at org.eclipse.osgi.container.Module.stop(Module.java:498) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:410) [?:?]
at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:44) [45:org.apache.karaf.bundle.core:4.2.4]
at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) [45:org.apache.karaf.bundle.core:4.2.4]
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) [14:org.apache.karaf.shell.core:4.2.4]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) [14:org.apache.karaf.shell.core:4.2.4]
2019-04-25 10:34:29.462 [DEBUG] [org.openhab.voice.googletts ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.core.voice.TTSService}={serviceAccountKey={
"project_id": "<my project id>",
"private_key_id": "<my private key id>",
"private_key": "-----BEGIN PRIVATE KEY-----<trust me, there is my private key here>-----END PRIVATE KEY-----\n",
"client_email": "openhab@<my project id>.iam.gserviceaccount.com",
"client_id": "<my client ID>",
"client_x509_cert_url": "https://www.googleapis.com/robot/v1/metadata/x509/<my project id>.iam.gserviceaccount.com"
}, service.id=564, service.bundleid=333, service.scope=bundle, component.name=org.openhab.voice.googletts.internal.GoogleTTSService, service.config.label=Google Cloud Text-to-Speech, pitch=0.0, component.id=374, purgeCache=true, volumeGain=0.0, speakingRate=1.0, service.config.category=voice, service.config.description.uri=voice:googletts, service.pid=[org.openhab.voice.googletts, org.openhab.voice.googletts]} - org.openhab.voice.googletts
2019-04-25 10:34:29.461 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
at org.apache.felix.scr.impl.manager.DependencyManager.invokeUnbindMethod(DependencyManager.java:1919) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeUnbindMethod(SingleComponentManager.java:458) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:382) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.removedService(DependencyManager.java:294) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1242) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.untrack(ServiceTracker.java:997) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1176) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:222) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:927) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:892) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:135) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.unregisterService(AbstractComponentManager.java:969) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.doDeactivate(AbstractComponentManager.java:823) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.deactivateInternal(AbstractComponentManager.java:805) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.dispose(AbstractComponentManager.java:584) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.disposeComponents(ConfigurableComponentHolder.java:716) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:510) ~[?:?]
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:429) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:292) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.container.Module.doStop(Module.java:634) ~[?:?]
at org.eclipse.osgi.container.Module.stop(Module.java:498) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.stop(EquinoxBundle.java:410) ~[?:?]
at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:44) ~[?:?]
at org.apache.karaf.bundle.command.BundlesCommand.execute(BundlesCommand.java:55) ~[?:?]
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:84) ~[?:?]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68) ~[?:?]
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526) ~[?:?]
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229) ~[?:?]
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:?]
2019-04-25 10:34:29.484 [DEBUG] [org.openhab.voice.googletts ] - BundleEvent STOPPING - org.openhab.voice.googletts
2019-04-25 10:34:29.486 [DEBUG] [org.openhab.voice.googletts ] - ServiceEvent UNREGISTERING - {org.osgi.service.cm.ManagedService}={service.id=563, service.bundleid=333, service.scope=singleton} - org.openhab.voice.googletts
2019-04-25 10:34:29.487 [DEBUG] [org.openhab.voice.googletts ] - BundleEvent STOPPED - org.openhab.voice.googletts
2019-04-25 10:34:29.488 [DEBUG] [org.openhab.voice.googletts ] - BundleEvent STARTING - org.openhab.voice.googletts
2019-04-25 10:34:29.492 [DEBUG] [org.openhab.voice.googletts ] - ServiceEvent REGISTERED - {org.osgi.service.cm.ManagedService}={service.id=574, service.bundleid=333, service.scope=singleton} - org.openhab.voice.googletts
2019-04-25 10:34:29.495 [INFO ] [.googletts.internal.GoogleTTSService] - Using cache folder /var/lib/openhab2/cache/org.openhab.voice.googletts
2019-04-25 10:34:29.495 [DEBUG] [.googletts.internal.GoogleTTSService] - Updating configuration
2019-04-25 10:34:29.497 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.201904202142 (333)[org.openhab.voice.googletts.internal.GoogleTTSService(384)] : The activate method has thrown an exception
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:51) [45:org.apache.karaf.bundle.core:4.2.4]
2019-04-25 10:34:29.514 [INFO ] [.googletts.internal.GoogleTTSService] - Using cache folder /var/lib/openhab2/cache/org.openhab.voice.googletts
2019-04-25 10:34:29.512 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.karaf.bundle.command.Restart.doExecute(Restart.java:51) ~[?:?]
2019-04-25 10:34:29.525 [DEBUG] [.googletts.internal.GoogleTTSService] - Updating configuration
2019-04-25 10:34:29.527 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.201904202142 (333)[org.openhab.voice.googletts.internal.GoogleTTSService(384)] : The activate method has thrown an exception
2019-04-25 10:34:29.545 [DEBUG] [org.openhab.voice.googletts ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.core.voice.TTSService}={serviceAccountKey={
}, service.id=575, service.bundleid=333, service.scope=bundle, component.name=org.openhab.voice.googletts.internal.GoogleTTSService, service.config.label=Google Cloud Text-to-Speech, pitch=0.0, component.id=384, purgeCache=true, volumeGain=0.0, speakingRate=1.0, service.config.category=voice, service.config.description.uri=voice:googletts, service.pid=[org.openhab.voice.googletts, org.openhab.voice.googletts]} - org.openhab.voice.googletts
2019-04-25 10:34:29.544 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
2019-04-25 10:34:29.563 [DEBUG] [org.openhab.voice.googletts ] - BundleEvent STARTED - org.openhab.voice.googletts
In debugging, I now have an error with the missing TTS service, because there are now text fields in the Paper UI instead of selectors with the service and voice. I deleted entries from text fields during reinstallation of TTS. I have yet to test Rpi 3 with an older version of the system, I will check whether it will be possible to recreate the error during the upgrade. I noticed that the REST API also displays an error:
Hello again,
On RPi 3B+ Google TTS with the same API key works, I upgraded OH snapshot from 1554 to 1576 every thing is Ok.
On Aeon I uninstalled TTS and rest api, I cleaned the cache, then reboot. Upgrade from 1575 to 1576 and installation of TTS and Rest api, unfortunately, without luck.
TSS throws the error in the log after restart.
It looks like an authorization problem, but the same api key works on Rpi
2019-04-25 22:10:40.431 [INFO ] [.googletts.internal.GoogleTTSService] - Using cache folder /var/lib/openhab2/cache/org.openhab.voice.googletts
2019-04-25 22:10:40.437 [ERROR] [org.openhab.voice.googletts ] - bundle org.openhab.voice.googletts:2.5.0.201904250429 (289)[org.openhab.voice.googletts.internal.GoogleTTSService(332)] : The activate method has thrown an exception
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [43:org.apache.felix.scr:2.1.16]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) [21:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.setProperties(ServiceRegistrationImpl.java:168) [?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.updateServiceRegistration(SingleComponentManager.java:622) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:819) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:709) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:673) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:316) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$2.configurationEvent(RegionConfigurationSupport.java:118) [43:org.apache.felix.scr:2.1.16]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1704) [9:org.apache.felix.configadmin:1.9.14]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1646) [9:org.apache.felix.configadmin:1.9.14]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [9:org.apache.felix.configadmin:1.9.14]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [9:org.apache.felix.configadmin:1.9.14]
2019-04-25 22:10:40.470 [WARN ] [org.openhab.voice.googletts ] - FrameworkEvent WARNING - org.openhab.voice.googletts
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.setProperties(ServiceRegistrationImpl.java:168) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.updateServiceRegistration(SingleComponentManager.java:622) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.modify(SingleComponentManager.java:819) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:709) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:673) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) ~[?:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:316) ~[?:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$2.configurationEvent(RegionConfigurationSupport.java:118) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1704) ~[?:?]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1646) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) ~[?:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) ~[?:?]
22 β Active β 80 β 18.0.0 β Guava: Google Core Libraries for Java
23 β Active β 80 β 21.0.0 β Guava: Google Core Libraries for Java
150 β Active β 80 β 2.5.0.201905010317 β openHAB Core :: Bundles :: REST Interface
151 β Active β 80 β 2.5.0.201905010321 β openHAB Core :: Bundles :: REST Interface
213 β Active β 80 β 2.4.5 β Jackson-annotations
214 β Active β 80 β 2.9.8 β Jackson-annotations
215 β Active β 80 β 2.4.5 β Jackson-core
216 β Active β 80 β 2.9.8 β Jackson-core
217 β Active β 80 β 2.4.5 β jackson-databind
218 β Active β 80 β 2.9.8 β jackson-databind
I think thatβs the reason why Google TTS does not work.
First, I tried bundle:uninstall old bundle, clear cache, reboot but after this old versions still persist. Found in /usr/share/openhab2/runtime/system/com/google/guava/guava/18.0 and deleted it, all old versions of bundles what i find also. After restart Karaf throws errors so I install openHAB Snapshot manualy via openhabian-config. Finaly end with this error where openHAB try to install Guava 18.0 instead of loading existing version 21.0 :
2019-05-02 12:05:57.139 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.apache.karaf.features.internal.util.MultiException: Error:
Error downloading mvn:com.google.guava/guava/18.0
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager.createDownloader(MavenDownloadManager.java:72) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:457) ~[?:?]
at org.apache.karaf.features.internal.region.Subsystem.downloadBundles(Subsystem.java:452) ~[?:?]
at org.apache.karaf.features.internal.region.SubsystemResolver.resolve(SubsystemResolver.java:224) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:388) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1058) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:994) ~[?:?]
Suppressed: java.io.IOException: Error downloading mvn:com.google.guava/guava/18.0
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:77) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
Caused by: java.io.IOException: Error resolving artifact com.google.guava:guava:jar:18.0: [Could not find artifact com.google.guava:guava:jar:18.0 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/)]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.configureIOException(AetherBasedResolver.java:803) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:774) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:657) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:598) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:565) ~[?:?]
at org.apache.karaf.features.internal.download.impl.MavenDownloadTask.download(MavenDownloadTask.java:52) ~[?:?]
at org.apache.karaf.features.internal.download.impl.AbstractRetryableDownloadTask.run(AbstractRetryableDownloadTask.java:60) ~[?:?]
... 7 more
Suppressed: shaded.org.eclipse.aether.transfer.ArtifactNotFoundException: Could not find artifact com.google.guava:guava:jar:18.0 in openhab (https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/)
at shaded.org.eclipse.aether.connector.basic.ArtifactTransportListener.transferFailed(ArtifactTransportListener.java:48) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$TaskRunner.run(BasicRepositoryConnector.java:368) ~[?:?]
at shaded.org.eclipse.aether.util.concurrency.RunnableErrorForwarder$1.run(RunnableErrorForwarder.java:75) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector$DirectExecutor.execute(BasicRepositoryConnector.java:642) ~[?:?]
at shaded.org.eclipse.aether.connector.basic.BasicRepositoryConnector.get(BasicRepositoryConnector.java:262) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.performDownloads(DefaultArtifactResolver.java:489) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:390) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifacts(DefaultArtifactResolver.java:215) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolveArtifact(DefaultArtifactResolver.java:192) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.resolveArtifact(DefaultRepositorySystem.java:247) ~[?:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.resolve(AetherBasedResolver.java:767) ~[?:?]
Caused by: shaded.org.eclipse.aether.resolution.ArtifactResolutionException: Error resolving artifact com.google.guava:guava:jar:18.0
at shaded.org.eclipse.aether.internal.impl.DefaultArtifactResolver.resolve(DefaultArtifactResolver.java:413) ~[?:?]
... 7 more
el00ruobuob can You check please boundle:list for duplicated bundles?
Another question is, how to uninstall duplicated bundles .
I had no duplicate.
Unfortunately i had some stability issues on the snapshot build and reverted to M1, so i canβt test it anymore. 2.5.0.M1 is working like a charm.
Iβm seeing the same errors with the Google TTS plugin.
And Iβm also seeing duplicate addons in my bundle:list
Back on Snapshot for some reasons, and the problem raised again.
I confirm i donβt have duplicates, but i canβt choose the Text-To-Speech engine on PapaerUI Config > System > Voice.
this is not critical to me, but if anyone wants me to post some logs & debugs, feels free to ask.
