All,
I’m running into an issue where an item cannot be found by the rule engine, while it does exist.
Steps to reproduce / explanation of issue:
Define item: EersteVerdiepingComputerkamerRolluik_BlindsControl by going to things > selecting a channel > choose new item > provide the name: EersteVerdiepingComputerkamerRolluik_BlindsControl
Using the item in a sitemap works fine. The basic UI can then be used to control the roller shutter.
Using the item in a rule yields the following error when executing the rule:
2019-12-16 17:30:00.973 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule ‘rolluiken nacht dicht’: The name ‘EersteVerdiepingComputerkamerRolluik_BlindsControl’ cannot be resolved to an item or type; line 24, column 3, length 50
Workaround / lead to root cause
If i do the exact steps as above, but with a different item name e.g. “EersteVerdiepingComputerkamerRolluik”. all is well and the item .“EersteVerdiepingComputerkamerRolluik” can be used in the rule.
Alternatively, switching on “simple mode” and using the generated thing name also works fine in the rule.
- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- OS: Raspbian GNU/Linux 10 (buster) Linux 4.19.57-v7+
- openHAB version: 2.5.0-1
Could be that I’m overlooking something. Does anyone else observe this behavior? Is there an issue with long item names or special characters in item names?
Best regards.
