Thanks. For some reason all the searches I was doing didn’t find that. Really this is the kind of thing that should be in the release notes imho. It doesn’t seem like an insignificant change.
Sure. But this also prevents installation of new bindings.
I agree that it is a but unexpected, that installing or uninstalling one binding updates the version of another binding or that installing 2.5.4 and cleaning cache results in 2.5.5.
It is meant to automatically provide critical patches. It will make more sense for upcoming 3.0.x releases - with 2.5.x we are not sticking nicely to patches, but there are indeed unexpected feature changes.
I like this option, I think it is a good thing!
A suggestion that I think is on topic would be an exclusion list maybe. @J-N-K would that solve the problem?
I may not fully understand the problem and technology here, but wanted to suggest.
I think we are getting a bit off-topic here. This thread was meant to announce the patch releases.
Updated to 2.5.6 and I get an exception when I try to access BasicUI:
java.lang.NullPointerException
at org.openhab.transform.javascript.internal.JavaScriptEngineManager.getScript(JavaScriptEngineManager.java:68)
at org.openhab.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:74)
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.transform(ItemUIRegistryImpl.java:537)
at org.eclipse.smarthome.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:449)
at org.openhab.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:123)
at org.openhab.ui.basic.internal.render.TextRenderer.renderWidget(TextRenderer.java:61)
at org.openhab.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:194)
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:160)
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:181)
at org.openhab.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:124)
at org.openhab.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:189)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:494)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918)
at java.lang.Thread.run(Thread.java:748)
Restarting several times and clearing cache did not help, so this might be some problem in this release I think, but someone else should test it…
Also accessing /rest/items produces another exception. I have seen this before, but maybe now more frequently and now I’m sure that the REST API is causing this:
2020-06-21 21:08:30.983 [ERROR] [ersey.server.ServerRuntime$Responder] - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: java.lang.NullPointerException
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[?:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [bundleFile:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [bundleFile:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [bundleFile:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [bundleFile:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [bundleFile:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [bundleFile:?]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [bundleFile:?]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [bundleFile:?]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [bundleFile:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:852) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:544) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:536) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1581) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1307) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) [bundleFile:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:482) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1549) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1204) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [bundleFile:9.4.20.v20190813]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [bundleFile:?]
at org.eclipse.jetty.server.Server.handle(Server.java:494) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:374) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:268) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:367) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:782) [bundleFile:9.4.20.v20190813]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:918) [bundleFile:9.4.20.v20190813]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
Caused by: java.lang.NullPointerException
at org.openhab.transform.javascript.internal.JavaScriptEngineManager.getScript(JavaScriptEngineManager.java:68) ~[?:?]
at org.openhab.transform.javascript.internal.JavaScriptTransformationService.transform(JavaScriptTransformationService.java:74) ~[?:?]
at org.eclipse.smarthome.core.transform.TransformationHelper.transform(TransformationHelper.java:125) ~[?:?]
at org.eclipse.smarthome.core.transform.TransformationHelper.transform(TransformationHelper.java:100) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:124) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:67) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:61) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.item.ItemResource.lambda$0(ItemResource.java:230) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:1.8.0_222]
at java.util.HashMap$KeySpliterator.tryAdvance(HashMap.java:1577) ~[?:1.8.0_222]
at java.util.stream.StreamSpliterators$WrappingSpliterator.lambda$initPartialTraversalState$0(StreamSpliterators.java:295) ~[?:1.8.0_222]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.fillBuffer(StreamSpliterators.java:207) ~[?:1.8.0_222]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.doAdvance(StreamSpliterators.java:170) ~[?:1.8.0_222]
at java.util.stream.StreamSpliterators$WrappingSpliterator.tryAdvance(StreamSpliterators.java:301) ~[?:1.8.0_222]
at java.util.Spliterators$1Adapter.hasNext(Spliterators.java:681) ~[?:1.8.0_222]
at org.eclipse.smarthome.io.rest.Stream2JSONInputStream.fillBuffer(Stream2JSONInputStream.java:93) ~[?:?]
at org.eclipse.smarthome.io.rest.Stream2JSONInputStream.read(Stream2JSONInputStream.java:69) ~[?:?]
at java.io.InputStream.read(InputStream.java:179) ~[?:1.8.0_222]
at java.io.InputStream.read(InputStream.java:101) ~[?:1.8.0_222]
at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:115) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[bundleFile:?]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[bundleFile:?]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[?:?]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[?:?]
... 53 more
Downgraded back to 2.5.5, everything seems to be working again, both error is gone.
That’s it, I’m absolutely sick and tired of these breaking changes, I don’t have the time nor inclination any longer to go chasing my tail everytime I upgrade. I’ve rolled back to 2.5.5-1 and locked it at that version, it works and that’s all that matters.
Modbus is not working in 2.5.6.
I get no updated values.
Rolled back to 2.5.5…
2020-06-21 23:03:10.056 [WARN ] [mmon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
at org.openhab.binding.modbus.internal.Transformation.transform(Transformation.java:144) ~[?:?]
at org.openhab.binding.modbus.internal.Transformation.transformState(Transformation.java:190) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.lambda$10(ModbusDataThingHandler.java:841) ~[?:?]
at java.util.HashMap$KeySpliterator.forEachRemaining(HashMap.java:1556) ~[?:1.8.0_231]
at java.util.stream.ReferencePipeline$Head.forEach(ReferencePipeline.java:580) ~[?:1.8.0_231]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.processUpdatedValue(ModbusDataThingHandler.java:809) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusDataThingHandler.onRegisters(ModbusDataThingHandler.java:689) ~[?:?]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.lambda$0(ModbusPollerThingHandlerImpl.java:95) ~[?:?]
at java.util.concurrent.CopyOnWriteArrayList.forEach(CopyOnWriteArrayList.java:891) ~[?:1.8.0_231]
at org.openhab.binding.modbus.internal.handler.ModbusPollerThingHandlerImpl$ReadCallbackDelegator.onRegisters(ModbusPollerThingHandlerImpl.java:95) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusLibraryWrapper.invokeCallbackWithResponse(ModbusLibraryWrapper.java:313) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.lambda$1(ModbusManagerImpl.java:214) ~[?:?]
at org.openhab.io.transport.modbus.internal.SimpleStopWatch.timeRunnable(SimpleStopWatch.java:152) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:213) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl$PollOperation.accept(ModbusManagerImpl.java:1) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.executeOperation(ModbusManagerImpl.java:620) ~[?:?]
at org.openhab.io.transport.modbus.internal.ModbusManagerImpl.lambda$14(ModbusManagerImpl.java:749) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:1.8.0_231]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:1.8.0_231]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:1.8.0_231]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:1.8.0_231]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_231]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_231]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_231]
All, I see a few have already discovered the 2.5.6 release - to be complete, here are the release notes with the changes: https://github.com/openhab/openhab-distro/releases/tag/2.5.6
Wrt JS transformation, there weren’t really any code changes since 2.5.5 - let’s follow up on the according issue on Github: https://github.com/openhab/openhab-addons/issues/7880.
It’s not the Modbus, it is the javascript transformations
Is the issue :
still present?
I’m not sure if I can update…
Looking at the Github link posted by Kai would have revealed the issue is still open .
OK, but if I’m not using Java Script tranformation the error shouldn’t occur?
Version 2.5.6 installed manually (as usual for me).
Basic UI is working well. In fact everything is working well
I should admit that at the first startup of the new version, the Z-Wave binding was OFFLINE. After a restart, everything is ONLINE.
9 new bindings in one month and several enhancements, that is great.
Hi together,
same problem here, but i’m sure it’s not a transformation problem, but a rest api problem. Just use the rest api view and try to get all items with the "items/get/“try it out!” and you will see, that no valid response is shown. No problem with 2.5.5. This breaks my openhab-exporter for prometheus.
I went back to 2.5.5 since 2.5.6 is too buggy!!!
LG
Georg
As far as I can see, there are no changes regarding the rest api, but there MUST be some changes, since it doesn’t work with 2.5.6. I’m running the openhab image from docker hub on a raspberry pi 4 and after the last “pull” the rest api ist brocken. Try to get all items using the rest api view and you will see the problem.
2.5.6 breaks HomeKit
All commands for HomeKit settings in the OpenHab Console are gone.
we can not reset the pairings etc.
Good news, https://github.com/openhab/openhab-addons/issues/7880 (JS transformation issue) has been fixed (thanks @wborn for providing the fix!) and we have pushed a new package 2.5.6-2 to the linux repos (thanks @Benjy). It should also be very easy for anyone to fix it locally, in case you’d like to do so - all it takes is to remove a single line.
All, please leave this topic here for doing the announcements - any bugs that you might experience should please directly be reported on Github, thanks.
