openHAB 2.5.x Patch Releases
I have tried to update from 2.5.0 to 2.5.1-2 on RPi4 on Fedora31 and I’m observing the following error during update:
error: unpacking of archive failed on file /var/lib/openhab2/tmp/README: cpio: chown
    error: openhab2-0:2.5.1-2.noarch: install failed
A full log (please ignore the everything related to mosquitto - it has no impact on openhab2 installation):
$ sudo dnf update
[sudo] password for dw:
Last metadata expiration check: 1:13:29 ago on Mon 13 Jan 2020 09:46:01 CET.
Dependencies resolved.
 Problem: package mosquitto-1.6.8-1.fc30.armv7hl requires libwebsockets.so.14, but none of the providers can be installed
  - cannot install both libwebsockets-3.2.1-1.fc30.armv7hl and libwebsockets-3.1.0-2.fc30.armv7hl
  - cannot install both libwebsockets-3.1.0-2.fc30.armv7hl and libwebsockets-3.2.1-1.fc30.armv7hl
  - cannot install the best update candidate for package mosquitto-1.6.8-1.fc30.armv7hl
  - cannot install the best update candidate for package libwebsockets-3.1.0-2.fc30.armv7hl
 Package                                                     Architecture                                        Version                                                     Repository                                                  Size
Upgrading:
 openhab2                                                    noarch                                              2.5.1-2                                                     openHAB-Stable                                              79 M
 openhab2-addons                                             noarch                                              2.5.1-2                                                     openHAB-Stable                                             181 M
Skipping packages with conflicts:
(add '--best --allowerasing' to command line to force their upgrade):
 libwebsockets                                               armv7hl                                             3.2.1-1.fc30                                                updates                                                    197 k
Transaction Summary
Upgrade  2 Packages
Skip     1 Package
Total download size: 261 M
Is this ok [y/N]: y
Downloading Packages:
(1/2): openhab2-2.5.1-2.noarch.rpm        3.8 MB/s |  79 MB     00:21
(2/2): openhab2-addons-2.5.1-2.noarch.rpm        5.8 MB/s | 181 MB     00:31
Total        8.3 MB/s | 261 MB     00:31
Running transaction check
Transaction check succeeded.
Running transaction test
Transaction test succeeded.
Running transaction
  Running scriptlet: openhab2-2.5.1-2.noarch        1/1
  Running scriptlet: openhab2-addons-2.5.1-2.noarch        1/1
  Preparing        :        1/1
  Running scriptlet: openhab2-2.5.1-2.noarch        1/4
  Upgrading        : openhab2-2.5.1-2.noarch        1/4
Error unpacking rpm package openhab2-2.5.1-2.noarch
  Running scriptlet: openhab2-addons-2.5.1-2.noarch        2/4
  Upgrading        : openhab2-addons-2.5.1-2.noarch        2/4
  Running scriptlet: openhab2-addons-2.5.0-1.noarch        3/4
  Cleanup          : openhab2-addons-2.5.0-1.noarch        3/4
warning: file /usr/share/openhab2/addons/openhab-addons-2.5.0.kar: remove failed: No such file or directory
  Running scriptlet: openhab2-2.5.0-1.noarch        4/4
  Cleanup          : openhab2-2.5.0-1.noarch        4/4
  Running scriptlet: openhab2-addons-2.5.1-2.noarch        4/4
  Verifying        : openhab2-2.5.1-2.noarch        1/4
  Verifying        : openhab2-2.5.0-1.noarch        2/4
  Verifying        : openhab2-addons-2.5.1-2.noarch        3/4
  Verifying        : openhab2-addons-2.5.0-1.noarch        4/4
Upgraded:
Skipped:
Failed:
Error: Transaction failed
Interestingly, the same error happened earlier, when I tried to update from 2.4.0 to 2.5.0 using dnf, (I had to update it manually using rpm).
Same for me.
Then, I reported it directly to github as unpacking of archive failed on file /var/lib/openhab2/tmp/README: cpio: chown · Issue #154 · openhab/openhab-linuxpkg · GitHub
It seems the linux repo metadata was somehow screwed up - I have rebuilt it and now it seems to be there:
➜  curl -L "https://dl.bintray.com/openhab/apt-repo2/dists/stable/main/binary-amd64/Packages" | grep " 2.5"
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 11876  100 11876    0     0  81342      0 --:--:-- --:--:-- --:--:-- 81342
Version: 2.5.0-1
Version: 2.5.1-1
Version: 2.5.0-1
Version: 2.5.1-1
Version: 2.5.0-1
Version: 2.5.1-1
@Kai
hi, yes now 2.5.1-1 is there, but shouldn’t it be 2.5.1-2?
apt-cache madison openhab2
openhab2 | 2.5.1-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.5.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.4.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.3.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.2.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.1.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
openhab2 | 2.0.0-1 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
I had the exact same problem and it worked fine on a second attempt. I’ve had it happen to me many times in the past for upgrades between 2.4 and 2.5 milestones, but not consistently. I can’t find the consistency in this issue, so it’s challenging to report the bug. I’ve done a lot of RPM work for other projects over the past 20 years, and I’ve never seen it with anything else (other than when I had an RPM that didn’t pass checksum tests).
Which version did you install 2.5.1-1 or 2.5.1-2 ?
(I only get offered 2.5.1-1 )
Hi all, it doesn’t look like APT’s 2.5.1-2 made it to Bintray.
I’m looking into it now and I’ll sort it out as soon as I can.
I was offered 2.5.1-2, and I have it successfully installed and
working as expected (although it took two attempts due to the cpio
error that was logged in github. That cpio problem has been happening
for a long time, but I can’t determine the consistency to it (it
doesn’t happen every time, just many times).
As a note, stable releases get pushed to every repo, so those using the unstable and testing repositories will be able to see 2.5.1-2 but those using only the stable (ironic, I know) repositories cannot.
I think I’ve found the cause of the issue but will let you know when this is available on the stable repo again.
@Benjy I had removed 2.5.1 from Bintray and republished it - therefore only 2.5.1-1 exists. Imho everything should just be fine (and yes, on testing there is still a 2.5.1-2, which is identical, very sorry for the mess…).
After sudo apt-get update now both versions are shown:
openhab2 | 2.5.1-2 | https://dl.bintray.com/openhab/apt-repo2 stable/main armhf Packages
Could i upgrade now?
No worries @kai.
Yes, I’ve distributed 2.5.1-2 to Bintray and this is available for everyone to upgrade to. I thought it best to publish 2.5.1-2 so that we can guarantee everyone has a working version. If we come into space issues on Bintray again, then we can remove 2.5.1-1.
This was an issue with the release job using a different username to the one bintray expects for metadata calculation. This has also been fixed for the next releases (of openhab2-addons).
@Kai @J-N-K I have found a problem.
Previously working rules (doesn’t matter if it’s DSL or JSR) behave strangely on the MQTT binding (I have only found it in Dimmer type).
Sending a command to the Dimmer item (for example 70 (%)) will only send 7. Controlling the value from sitemap is correct.
The outgoing value transform is active in this case, I have this (int) value sent as “%s”. However it works as before from sitemap, so I don’t know what changed and what is causing this…
This looks weird… (I have sent a 70 command):
2020-01-13 18:12:31.303 [ome.event.ItemCommandEvent] - Item 'Living_Room_Floor_Lamp_Brightness' received command 70
2020-01-13 18:12:31.305 [.event.RuleStatusInfoEvent] - a0923642-287f-4a3d-be1d-0e26c7e9eedf updated: IDLE
2020-01-13 18:12:31.470 [nt.ItemStatePredictedEvent] - Living_Room_Floor_Lamp_Brightness predicted to become 70
2020-01-13 18:12:31.518 [vent.ItemStateChangedEvent] - Living_Room_Floor_Lamp_Brightness changed from 85 to 70
2020-01-13 18:12:31.520 [vent.ItemStateChangedEvent] - Living_Room_Floor_Lamp_Brightness changed from 70 to 7
So it sends the 70 value but somehow it changes to 7…
Sending the same command from console, the same result…
Sniffing the output from MQTT, this is sent at 70 value:
"brightness": 7E+1
So openHAB recognizes the value in this normalized format but the device not (that’s why its bouncing the state at 70 and then 7).
The problem was caused by this:
And I could solve it by using “%.0f” instead of “%s”.
Update to 2.5.1-2 worked with openhabian-config function.
Had done a sudo apt-get update before to refresh repos.
After Upgrade I had to clean cache and I rebooted twice.
Now everything should work as expected
$OPENHAB_RUNTIME/bin/client -p habopen
Logging in as openhab
2.5.1
Release Build
versio.properties:
openHAB Distribution Version Information
build-no : Release Build
online-repo : JFrog
Repository        Version
openhab-distro  : 2.5.1
openhab-core    : 2.5.0
openhab1-addons : 1.14.0
openhab2-addons : 2.5.1
karaf           : 4.2.7
Information at openhabian Login Screen:
openHAB 2.5.1-2 (Release Build)
Excellent, what a relief :sweat_smile: .
:smiley:
Please open an issue on github. This is a bug.
Here it is:
The onyl message I get frequently is, but don’t know what it means…:
2020-01-13 19:18:28.227 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.i
nternal.CommunicationManager@1ea10ed' takes more than 5000ms.
