I have been building my home automation openhab 2. Thanks for the great tool!
I have been able to add my zwave door sensors to openhab. And those are working fine. Now I’m stuck with the rules.
Items:
Group:Contact:OR(OPEN,CLOSED) Doors “Ovi tunnistemet” (All)
Contact DoorTakaoviAlatupa “Takaovi Alatupa [MAP(door.map):%s]” (Doors) {channel=“zwave:device:91c09578:node4:sensor_door”}
Rules:
// Imports
import org.openhab.core.library.types.*
import org.openhab.core.persistence.*
import org.openhab.model.script.actions.*
rule "Doors opened"
Item Doors changed
logInfo(“door sensors”, “door sensors changed state”)
Here is the Log:
2016-05-25 18:04:18.518 [INFO ] [marthome.event.ItemStateChangedEvent] - DoorTakaoviAlatupa changed from CLOSED to OPEN
2016-05-25 18:04:18.527 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_device_91c09578_node4_sensor_door changed from CLOSED to OPEN
2016-05-25 18:04:19.563 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_serial_zstick_91c09578_serial_sof changed from 82 to 83
2016-05-25 18:04:19.567 [INFO ] [marthome.event.ItemStateChangedEvent] - DoorTakaoviAlatupa changed from OPEN to CLOSED
2016-05-25 18:04:19.573 [INFO ] [marthome.event.ItemStateChangedEvent] - zwave_device_91c09578_node4_sensor_door changed from OPEN to CLOSED
-> I can’t see my logging line. Am i doing something wrong?
Second question is the grouping. First I just used the Items that was made for me by discovery in Paper UI. I did not found a way to group them -> This was the reason to add those items manually to items file and made also the groups there. Is there any other way?
Third question is related to Eclipse Smart Home Designer. I installed to that to my Windows and launched. It opens, but how I should connect this to my openhab environment running on Raspberry PI? Or is this even possible? So currently I’m just using notepad++ to maintain sitemaps etc.
I’m using the Openhab 2 beta 3 release.
