Hi all,
At the moment I’m trying to setup homekit on my home server with OpenHAB 2 b3.
The problem I’m facing right now is that the discovery bij Elgato Eve or iDevices isn’t succeeding.
So actually, both applications don’t find OpenHAB.
When I run the same setup (exact copy) on my laptop the discovery is working without any issues.
I’m using exact the same network with the same settings. The multicast settings are correct on my router.
I’ve been sniffing around in the code of HAP-Java and as far as I understand the discovery is disabled for my server (sf = 0, see screenshot below).
Does anybody has an idea why my server is not discoverable and my laptop is?
What causes exactly this “sf”-parameter to be set to 0?
Thanks a lot!
Greetings,
Frederic
