Openhab 2 losing cloud connection
see also here: Link
and here: Link2
I also had this error yesterday evening (21:29), too.
2017-11-23 21:24:47.714 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxx, base URL = http://localhost:8080)
2017-11-23 21:29:17.591 [ERROR] [io.openhabcloud.internal.CloudClient] - Socket.IO error: {}
io.socket.engineio.client.EngineIOException: xhr poll error
	at io.socket.engineio.client.Transport.onError(Transport.java:71) [219:org.openhab.io.openhabcloud:2.2.0.201709152241]
	at io.socket.engineio.client.transports.PollingXHR.access$100(PollingXHR.java:19) [219:org.openhab.io.openhabcloud:2.2.0.201709152241]
	at io.socket.engineio.client.transports.PollingXHR$6$1.run(PollingXHR.java:124) [219:org.openhab.io.openhabcloud:2.2.0.201709152241]
	at io.socket.thread.EventThread$2.run(EventThread.java:80) [219:org.openhab.io.openhabcloud:2.2.0.201709152241]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:?]
	at java.lang.Thread.run(Thread.java:745) [?:?]
Caused by: java.net.SocketTimeoutException: connect timed out
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
	at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1890) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection$10.run(HttpURLConnection.java:1885) ~[?:?]
	at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getChainedException(HttpURLConnection.java:1884) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1457) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1441) ~[?:?]
	at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480) ~[?:?]
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:338) ~[?:?]
	at io.socket.engineio.client.transports.PollingXHR$Request$1.run(PollingXHR.java:214) ~[?:?]
	... 1 more
	at java.net.DualStackPlainSocketImpl.waitForConnect(Native Method) ~[?:?]
	at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:85) ~[?:?]
	at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
	at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
	at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
	at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) ~[?:?]
	at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
	at java.net.Socket.connect(Socket.java:589) ~[?:?]
	at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668) ~[?:?]
	at sun.net.NetworkClient.doConnect(NetworkClient.java:175) ~[?:?]
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:432) ~[?:?]
	at sun.net.www.http.HttpClient.openServer(HttpClient.java:527) ~[?:?]
	at sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:781) ~[?:?]
	at sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:647) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1536) ~[?:?]
	at sun.net.www.protocol.http.HttpURLConnection.getHeaderFields(HttpURLConnection.java:2966) ~[?:?]
	at sun.net.www.protocol.https.HttpsURLConnectionImpl.getHeaderFields(HttpsURLConnectionImpl.java:283) ~[?:?]
	at io.socket.engineio.client.transports.PollingXHR$Request$1.run(PollingXHR.java:211) ~[?:?]
	... 1 more
2017-11-23 21:29:17.691 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxxxx, base URL = http://localhost:8080)
2017-11-23 21:30:20.392 [ERROR] [io.openhabcloud.internal.CloudClient] - Socket.IO error: {}
	... 1 more
	... 1 more
2017-11-23 21:30:20.411 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = xxxxxxx, base URL = http://localhost:8080)
2017-11-23 21:31:42.385 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = xxxxxxx, base URL = http://localhost:8080)
I did a bundle:list , then I identified the cloud service binding (mine = Nr. 219)
then bundle:stop 219
then bundle:start 219
After this cloud-service was up again!
