I’ve setup the nest binding using developer.nest.com and i get the url and the secret successfully and then retrieve my pin. I put the pin in openhab and all my nest stuff shows up. I can adjust temperatures, turn the fan on and off…all the good stuff. but it only works for about a week and then i start getting this in the logs:
2017-04-10 09:27:00.550 [WARN ] [st.internal.messages.AbstractRequest] - Method failed: HTTP/1.1 403 Forbidden
2017-04-10 09:27:00.553 [ERROR] [ab.binding.nest.internal.NestBinding] - Error retrieving access token: AccessTokenResponse[accessToken=<null>,expiresIn=<null>,error=client_not_active,errorDescription=client is not active]'
2017-04-10 09:27:00.554 [WARN ] [ab.binding.nest.internal.NestBinding] - Periodic poll skipped.
every few minutes those 3 lines scroll by. If i go to the url and get a new pin and put it in the binding everything works again for about a week. I don’t see anyone else complaining about this so i must have done something wrong. surely you don’t have to update this once a week?
