Hi all,
I have installed openHab2 on my Synology DS416Play and openCloud addons.
The problem is that after 1 hour or less openHab go down and I have to restart manually using start.sh I have the same problem also after I restart the NAS.
Sounds like you installed openHAB manually right? Did you watch CPU, RAM etc. if something strange happens during the crash? Did you check the openHAB Logs ?
If you don’t care for the crash and just want it to restart automatically take a look at the Service documentation
So i have the same synology you have with OH2 running, the main problem I have had is RAM and occasionally CPU. While I have not had it crash completely, its has become unresponsive as CPU and Swap started to increase, and I have had to restart the service. How big is your OH installation? I’m in the process this weekend of moving back to a Rasperry Pi 3 or one of my ordroid u3.
Thank you, I have no problem with CPU and RAM. I use putty to connect to my NAS via ssh, I start openHab using start.sh, when putty lost connection openHab go down. I try to follow the guide to configure openHab as a service but in Synology systemd not exists, I tried using synoservice --enable but always return me “Service [openhab2.service] does not exist”.
I’m using the official openHAB synology package described here http://docs.openhab.org/installation/synology.html , this installs openhab as a synology service so it starts and stop automatically. I have a large amount of bindings and items which is why my load is so high.
I’m also using the official openHAB synoloy package, but if I restart my NAS, the openHAB service not start. I have to go via ssh to /volume1/@appstore/openHAB/ and execute “sudo sh start.sh” manually.
But if I close connection openHAB go down.
Do you know how I can check witch are the services enabled in synology os? Thank you.
Sorry, I did not have that problem, mine always started automatically. You might try uninstalling the synology package and installing it again? Unfortunately I don’t know much about how Synology services work.
Ok I understand and fixed the problem! After reinstall openHAB, I noticed that in the popup after installation is write to press “Launch button after installation”. So I click launch button in the package center in the card of openHAB to start opeHAB and now work.
But now I have another problem, after installation I had to re configure all settings and reinstall all bindings.
After installation of Zwave I have many problem to set port of my Aeon Z-Wave stick, now always return me that the port not exist…seems a permission problem, so I execute “sudo chmod 777 /dev/ttyACM0”, delete stick from things and re add, so is online, but it doesn’t found any things and also after restart of NAS or after 1 hour the stick go offline and return error of port not exist…
