Hey guys. I found the answer on another topic.
Seems Opehabian default location for stiemaps and items is /etc/openhab2
So the open question now is quite different… how to make openhab generator creating files at right place?
I have matched my sitemap code to all requirements in the sitemap documentation as I understand it. I am fairly new so maybe I miss-understood something but as of right now…
I am also getting the “No available sitemaps” issue. please help - and posting the link to the documentation is not helpful as I have been following the rules there already.
Could you verify the following:
Did you look at the logs (myserver:9001)? Do they say some something?
Is your mysitemap.sitemap file located in the conf/sitemap -folder?
Are you using http://myserver:8080/basicui/app?sitemap=mysitemap where mysitemap is reflected in the mysitemap.sitemap-file ?
like so in the file "sitemap mysitemap label=“My Sitemap”
Please note that this is not a default feature of openHAB.
That logging function is only available vie openHABian or manually installed frontail feature.
It could cause confusion if a user tries to open that port and does not find anything
Hi , I am new to this. Mine is blank, what do i put here?
The sitemap you want to load if you click on BasicUI on your dashboard:
Note that you can also load your sitemaps via:
http://hostname:8080/classicui/app?sitemap=sitemapname
http://hostname:8080/basicui/app?sitemap=sitemapname
i am writing default sitemap= home. when restarted raspberry pi default sitemap is changing to demo. i can’t understand.
