openHAB 3.0 Milestone 2 discussion
I really like where Openhab is going with these releases! Some quirks that I have observed so far:
  • time to boot openhab up is significantly longer than it was with openhab 2 (now ~5 minutes, before ~30 seconds)
  • overall a tad less snappy than OH2, especially latency between physical interaction and reaction of the system
  • sometimes most of my rules just stop working. Right now I can’t make them work anymore, but since its in the middle of the night now I give up :slight_smile:
    All rules have been imported from OH2 rules files.
Relevant Log entries (interesting: Caused by: java.lang.IllegalStateException: Cannot create a duplicate value ‘newState’.):
[ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule ‘licht-2’: Fail to execute action: script
[DEBUG] [e.automation.internal.RuleEngineImpl] -
java.lang.RuntimeException: Fail to execute action: script
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1187) ~[bundleFile:?]
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:987) [bundleFile:?]
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:91) [bundleFile:?]
at java.lang.Thread.run(Thread.java:834) [?:?]
at org.eclipse.xtext.xbase.interpreter.impl.DefaultEvaluationContext.newValue(DefaultEvaluationContext.java:46) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.createEvaluationContext(DSLScriptEngine.java:143) ~[?:?]
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:118) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.lambda$0(ScriptActionHandler.java:62) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:59) ~[?:?]
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1179) ~[bundleFile:?]
… 7 more
Running on build #2009
Edit: #2009 seems to be broken acc. to Rule causes high load and queue issues - #5 by Lolodomo
