I am aware of this and you know what i meant by config tool. This can also be deduced from the screenshot. As i mentioned in the post, the point is that i can’t install OH3 M4 via openhabian-config.
If you @Bruce_Osborne don’t want to help me, then that’s fine with me.
Maybe there is someone who can and would like to help me, thank you!
I think that what Bruce and Hans-Jörg are saying is not that we can’t help you on this forum. But your request is off topic for this thread and would be better seen and more likely to get help if it were posted as a separate thread.
I usually watch the logs from the command line.
Either short-term via openhab-cli or long-term by accessing them directly.
They should be in /var/log/openhab.
In the Brightness option I have a slider and can change the light.
In the ColorTemperature I set the option to color picker but I cannot change the color temperature shown on top. Clicking on the number just opens a history graph. What do I need to configure to get a color picker option?
Hi, I have probably found a small bug on little badges:
If I use the invert-text color (black) texts and bulbs are becoming black while temperature and drop icons are remain white
Got this, thanks @J-N-K . The deconz binding configured it as number from default (should have been dimmer, right?). I noticed that OH3 configures the same item (here a Philips color light) differently in hue and deConz bindings.
Thanks for looking at the color issue. I did further testing with OH3 and Deconz binding.
Consumption, Power, Temperature and Illuminance are created correctly.
For humidity I encountered another problem. The item is defined as Number:Dimensionless
and the widget reports: “0,46 one” (expected value from OH2 would be: “46.0 %”).
Name or label ?
If it is item or group name, I think this is normal behaviour. See the same with german „Umlauts“.
Since using openHAB, I avoid using special charakters apart from labels.
