It will be coming back, and it should still work with WSL1.
Docker does not work well with WSL1 & Windows 10 Home, does it? I have been focussing lately on using Docker for OH.
A quick google search brought up this: Setting Up Docker for Windows and WSL to Work Flawlessly — Nick Janetakis
Hopefully they fix WSL2. Having a true Linux kernel helps a lot with compatibility.
That link is a workaround for the default flawed Docker installation though.
I’m not sure if this is the correct place to ask this question, but…
Installed OH3 M5.
When I try to add equipment (or point) to model I get a pop-up stating I have to select at least one channel. The channel (HUE brightness) is selected though. Am I doing something wrong, or is this a bug?
I’m trying to convert some of my DSL V1 rules to OH3. I would like to have an option to modify the item value in the following screen
In the rule I use as action
OU_Weather_Actual_Rain_avg.postUpdate(OU_Weather_Actual_Rain.averageSince(now().minusMinutes(120),"rrd4j"))
If I use this code in a execute a given script
it gives an error, but if I copy the .rules
file to conf\rules
it works.
I copy the .rules file to conf\rules it works.
Try copying in the .riles file and check what the UI or REST API state for the rule. That may give some insight. That is what I would try anyway.
I will do that for debugging purposes. But I think that besides the 3 “core actions” it would make sense to also include an “update item value” action.
Feature requests should be opened as Issues on GitHub. That permits developers who are not here to work on things too.
That’s ok, because it seems that such an action actually does not exist at all - so @ysc would have a hard time to add it in the UI .
Looks like a bug, you should have a form below the checkbox item to complete the item details. If you can share reproduction steps please do so.
Maybe a really small issue: If you follow the docker link on next.openhab.org, the text will link to Milestone 4 (instead of 5).
I have the same problem.
In Location add a new location (room).
In that room i select Create Equipment from thing.
I select a thing and also a channel but i still get this message.
I’m also having this issue when trying to create equipment from point. So far it’s only occurring with Hue devices.
Has anyone created an issue yet?
Thank you Scott!
I’ll clean up and try to reproduce.
Let you all know the outcome
