It looks like the System started rules are running twice at startup. Once after reaching start level 40, and again after reaching start level 100. I have a very simple rule that simply logs that its running. If this has been reported somewhere already, I apologize.
2020-12-15 18:57:19.687 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'US/Eastern'.
2020-12-15 18:57:19.745 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to 'XXXXX,YYYYY'.
2020-12-15 18:57:19.749 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'.
2020-12-15 18:57:20.061 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 10
2020-12-15 18:57:28.385 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zoneminder.items'
2020-12-15 18:57:29.234 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ambientweather.items'
2020-12-15 18:57:29.573 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'globalcache.items'
2020-12-15 18:57:29.587 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.items'
2020-12-15 18:57:29.628 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'main.items'
2020-12-15 18:57:29.782 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'squeezebox.items'
2020-12-15 18:57:29.846 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ecobee-upstairs.items'
2020-12-15 18:57:30.985 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ecobee-main.items'
2020-12-15 18:57:31.950 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'bhyve.items'
2020-12-15 18:57:31.998 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'doorbird.items'
2020-12-15 18:57:32.048 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'weathercompany.items'
2020-12-15 18:57:32.143 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'bigassfan.items'
2020-12-15 18:57:32.191 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'sunsetwx.items'
2020-12-15 18:57:32.473 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'jdbc.persist'
2020-12-15 18:57:32.579 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2020-12-15 18:57:32.920 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2020-12-15 18:57:33.076 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'loadgen.sitemap'
2020-12-15 18:57:33.716 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'all-things.things'
2020-12-15 18:57:36.544 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.rules'
2020-12-15 18:57:38.298 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2020-12-15 18:57:45.057 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 20
2020-12-15 18:57:45.304 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
2020-12-15 18:57:46.775 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:sun:local' to inbox.
2020-12-15 18:57:46.786 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'astro:moon:local' to inbox.
2020-12-15 18:57:48.337 [INFO ] [persistence.jdbc.internal.JdbcMapper] - JDBC::openConnection: Driver is available::Yank setupDataSource
2020-12-15 18:57:48.449 [WARN ] [.zaxxer.hikari.util.DriverDataSource] - Registered driver with driverClassName=com.mysql.jdbc.Driver was not found, trying direct instantiation.
2020-12-15 18:57:50.065 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 30
2020-12-15 18:57:50.069 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 40
2020-12-15 18:57:50.286 [INFO ] [openhab.core.model.script.test.rules] - Test "System started" rule is running
2020-12-15 18:57:50.289 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2020-12-15 18:57:55.065 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 50
2020-12-15 18:57:55.068 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 70
2020-12-15 18:57:55.069 [DEBUG] [enhab.core.service.StartLevelService] - Reached start level 100
2020-12-15 18:57:55.839 [INFO ] [openhab.core.model.script.test.rules] - Test "System started" rule is running
2020-12-15 18:57:57.720 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
not sure if this is the right place, but will give it a shot
3.0.0.RC1
in Model UI Item is shown only in ONE location, even if it is part of couple. Same applies to other Location-Groups.
It’s not very handy, should be displayed in every group where Item is member of.
But I’m not sure if it is feature or bug tho.
I have the same problem, I have one item in multiple groups (to be able to show status of group with aggregated value). But it only shows in one group now which means the Locations Tab is not showing all my items
There’s been multiple threads on this topic.
The conclusion was that there should be 1 group in the Model (location/equipment-based) and the other group(s) created as Item groups (functional - ie. first floor lights). This way, you will see the items in both groups and the Model is satisfied.
I’ve noticed that the load averages are consistently higher with RC1 than the prior M releases. Before, I’d consistently see load averages around 0.10, now they are closer to 0.25 - 0.30.
I’d like to make a couple of observations regarding my experience in migrating from OH2 to OH3. All of my Items and Rules are created using text based files using OH2, and all Things were created using the OH2 UI. I use Dockers for both OH2 and now OH3 and have been successful in federating OH2 with OH3 for those items and bindings not currently supported in OH3. In OH3 when attempting to create links between text based Items and Things I finding that if I select an Item, many items maybe 10-15%, contain no Link Button option, only the Metatdata button. I see no pattern for this behavior as to why some items and not others exhibit this behavior. For example 2 essentially identical String Items, 1 has the Link Button and the other does not. Conversely if I select a Thing and attempt to link an Item to a Channel, only a few text based Items, 10 Items to be exact, are listed as being link eligible, even though I have almost 400 text based Items, thus forcing me to create a new Item using the UI. Is this expected behavior by design? Or is this a bug due to the migration of Items from OH2 to OH3? OR is this a local issue for my setup only?
I wanted to bring this to attention so that if changes need to be made they may be made in advance of the final release, and if this is a “feature” it needs to be highlighted in the documentation for users Migrating from OH2 to OH3 so that a lot of time is not wasted by the user in trying to mitigate the behavior.
Most of my text based Rules migrated without issue, however as expected time based rules are a mess with the move from Joda.time to Java.time and I’m still trying to work my way through this. I have even just resorted to using the UI system for rule creation without any success in recreating these Joda.time rules. Further it seems to be very slow and tedious. For me I find it unsuitable when looking to create a large number of similar type rules, but maybe it just the newness of the process I need to get to used to. Change is always hard, but I have learned to be open to new ways of doing things.
We need to have more information on what items are linkable to what thing and the ones not linkable. Please post examples, without, it will be hard to guess any reason.
As an example here are 2 String Items both created using a text file. The 1st has a Link Button and the 2nd does not. Perhaps it is related to a semantic model, but if so that would be very limiting for those that choose not use such a model.
As for Thing Channel Linking, it really doesn’t matter what Thing or Thing Channel I wish to link to, when I choose Link to Existing Item, the UI always lists the same 10 items and ignores the other approx…390 Items. Just for reference my Things include Astro, Shelly, DenonMarantz, DarkSky, Panasonic, OpenSprinkler, Kodi, and more.
Not sure there is much more I can add. As I said it seems to be random and no specific discernible pattern, but if there are other specifics I can provide please let me know.
