openHAB 3.0 Release Candidates discussion
openHABian will now do that for you. But it’s still an ugly hack, isn’t it.
A post was split to a new topic: Installation stuck
How can a single Item be in multiple locations? I think that is by design.
because groups are now locations, and item surely have to be in several of those … like
All lights
First floor lights
Workroom lights
… you have already three location of the one single switch
or maybe i’ve got whole model location/group/point wrong, might be the case
There’s been multiple threads on this topic.
The conclusion was that there should be 1 group in the Model (location/equipment-based) and the other group(s) created as Item groups (functional - ie. first floor lights). This way, you will see the items in both groups and the Model is satisfied.
ok so instead of creating location-group, i should be doing item-group without location?
it’s bit confusing to be honest
All lights
First floor lights
Workroom lights
All lights would be for control. Control groups ar enot part of the semantic model.
Workroom should be a child group of First Floor.
I’ve noticed that the load averages are consistently higher with RC1 than the prior M releases. Before, I’d consistently see load averages around 0.10, now they are closer to 0.25 - 0.30.
I’d like to make a couple of observations regarding my experience in migrating from OH2 to OH3. All of my Items and Rules are created using text based files using OH2, and all Things were created using the OH2 UI. I use Dockers for both OH2 and now OH3 and have been successful in federating OH2 with OH3 for those items and bindings not currently supported in OH3. In OH3 when attempting to create links between text based Items and Things I finding that if I select an Item, many items maybe 10-15%, contain no Link Button option, only the Metatdata button. I see no pattern for this behavior as to why some items and not others exhibit this behavior. For example 2 essentially identical String Items, 1 has the Link Button and the other does not. Conversely if I select a Thing and attempt to link an Item to a Channel, only a few text based Items, 10 Items to be exact, are listed as being link eligible, even though I have almost 400 text based Items, thus forcing me to create a new Item using the UI. Is this expected behavior by design? Or is this a bug due to the migration of Items from OH2 to OH3? OR is this a local issue for my setup only?
I wanted to bring this to attention so that if changes need to be made they may be made in advance of the final release, and if this is a “feature” it needs to be highlighted in the documentation for users Migrating from OH2 to OH3 so that a lot of time is not wasted by the user in trying to mitigate the behavior.
Most of my text based Rules migrated without issue, however as expected time based rules are a mess with the move from Joda.time to Java.time and I’m still trying to work my way through this. I have even just resorted to using the UI system for rule creation without any success in recreating these Joda.time rules. Further it seems to be very slow and tedious. For me I find it unsuitable when looking to create a large number of similar type rules, but maybe it just the newness of the process I need to get to used to. Change is always hard, but I have learned to be open to new ways of doing things.
We need to have more information on what items are linkable to what thing and the ones not linkable. Please post examples, without, it will be hard to guess any reason.
As an example here are 2 String Items both created using a text file. The 1st has a Link Button and the 2nd does not. Perhaps it is related to a semantic model, but if so that would be very limiting for those that choose not use such a model.
String vDENONAVR4520_MainZone_InputSource "Input Source AVR4520[MAP(denon.map):%s]"  <receiver>  (gDenonFR, Group_HabPanel_Dashboard)
String vHABPanelSwitchItem "HABPanel Switch" (Group_HabPanel_Dashboard)
As for Thing Channel Linking, it really doesn’t matter what Thing or Thing Channel I wish to link to, when I choose Link to Existing Item, the UI always lists the same 10 items and ignores the other approx..390 Items. Just for reference my Things include Astro, Shelly, DenonMarantz, DarkSky, Panasonic, OpenSprinkler, Kodi, and more.
Not sure there is much more I can add. As I said it seems to be random and no specific discernible pattern, but if there are other specifics I can provide please let me know.
I believe the Main UI is based on you using the semantic model.
I understand that Pages makes extensive use of the a semantic model, but I didn’t thing that linking Items to Things was or should be restricted by a semantic model. To me that doesn’t make a lot of sense, but you could be right. Further I was just speculating about the potential difference in the two items I was using an example. In one case the Link Button is present and in the other it is not.
I think, the issue is your mapping in the item label.
Mappings are done trough meatadata in oh3, not in the label.
Interesting, because it is the mapped Item that has a Link Button.
Sorry, mixed it up in your text, so that cant be the issue. Anyway, there should be no mapping in the label.
Just as na FYI. Mapping in the label using the text file seems to cause no problems for me and it would mean that for those of us migrating from OH2 we would need to re-work all of our text based .Items and recreate mappings in the UI. Is that really the expectation?
You misunderstood, mappings can still be done, but they have to be defined as metadata, not in the label. Even in the Ui, mappings and state description (pattern) are part of the metadata section.
Ahh. Yes I did misunderstand. My text file based mappings do show in the UI as metadata.
Great, did not know that mappings in the labels are transformed correct for the UI.
But this does not bring as a step closer to solve your issue.
@ysc Any clue what the culprit could be or how to debug ?
