Looks like the current download page www.openhab.org/download is not currently working. I could not select the platform. I used next instead and got the Windows file I wanted. Also, I could not reach the download page from the top menu. I had to use a direct link.
KR, Martin
yesterday i started with a fresh OH3 and so far so good.
(too many troubles with the upgrade from 2.5)
my thoughts:
i add a new thing -> channels -> add equipment to model = here i can only choose 1 Parent Group. this needs to be a multi-selection. (e.g. Hue Bulb, i want to have it in a “HUE” Parent Group and as well as in the specific “Room” Location) - i need to edit the model again to get it into 2 groups.
Dashboard -> Locations = when i click on “Bedroom” it pops up and this new window is way to small, e.g. using a 4K Monitor and i need to adjust stuff in this little window, endless scrolling needed. makes no sense. also the color/image-header takes way too much space and the Icons in there are to big and clunky. make them in size adjustable or smaller please. and last but not least, a Thing should be written in White (Primary) and all those Items below should be grey (Secondary Stuff), its hard to distinguish Things quickly. overall this window/popup needs a redesign imo.
Model Cards = should be possible to use HEX Color Codes or a ColorPicker, instead of just some (ugly) preset colors. Also text color should be changeable. e.g. on yellow BG its hard to read white text.
Add Items from Thing = add new MODERN Icons to Category/OH. maybe make it possible to use those new “f7:icons” here too, they look way better then those oldschool 3D/Color Icons.
Hiding an Item in the Dashboard would also be great. ( e.g. i want to change stuff with rules, where i need the item, but i don’t need the item to be seen in the Dashboard. (e.g. ALARM for Hue Bulbs)
Overall i would wish i could change the styling of different Dashboard stuff myself, so that i can customize it to my likings. (BG-Colors, Font & Font-Colors, Size, Graph-/Chart-Color, etc.) i know its possible here and there, but its not consistent and not enough
i think there is great potential in this new Dashboard, can’t wait to see where this is all going
cheers and thanks for the great Update!
The HUE parent Group should not be in the model. Not all Groups or Items are required to nor are they expected to be a part of the model. From the model’s perspective, what is the HUE group anyway? It’s not a location. It’s not an Equipment.
Just to be clear, that is the Equipment, not the Thing. Equipment can have Items linked to more than one Thing or even more than one binding.
This is already possible. Click the pencil icon in the upper right hand corner of the tab on the overview page you want to edit. From there you can reorder and check only those entities you want to show.
I found the following issues and do not know where to report them:
Using of item-Search: If I put in a part of some items it will present me the items I am looking for. But if I go into a Item and get back the search entry is still there but not the search result. Then I have to reenter it so switch to the next item.
For any reason it is replicable that in the semantic model some points switch out of their equipment. When I delete the Equipment and reenter all Points it occurs that another Equipment is going to be split
The editor for the Sitemap is very nice. But why would them not be saved in the ‘Sitemaps’-Folder and used by the system. This have to be done manually. This makes no sence to me to say it clear - but I know that scheme is correct
At least: Very good work. Thank you very to everybody for the invested time.
For 1 and 2 I suggest filing an issue. For 3, it’s the same reason why Things are not written out to .things files, Items are not written to .items files, Rules are not written to .rules files when done through the UI.
There is no code today that is capable of writing out to these file formats and sorting this data in the JSONDB is the more natural format for OH.
If you want to use those other files you can and are encouraged to do so. But that means you can’t use the Ui to do anything with them. So if you want to use. sitemap files, you can do so. But you’ll have to write the fingers yourself, you can’t use the UI.
Thanks Rich for your fast reply.
1 and 2 I figure out how to do.
Yes I understand. But it was a good way to save the work done fast and easily. Tell me when I am wrong the constructed sitemap should available in the mobile device app, right?! Not at my installation. Only if I export the sitemap to a file.
Is there a possibility to use the new Home UI on the (Android) App? Or do one need to choose if he wants to use the Sitemaps in the App or the new Home UI in a browser?
As was covered in the release notes, Joda DateTime was replaced with ZonedDateTime
Joda is an old third party library and there is no reason to depend on it when Java comes with it’s own library to do the same thing.
I knew that it was replaced but not very familiar with Java. Didn’t knew I could use getMonthValue.
Still don’t understand why a number item is represented in a log file as JANUARY but that doesn’t matter now. I replaced getMonth with getMonthValue succesfully.
When getMonth() is called on a ZonedDateTime object, a Month enum value is returned. So it is not a number. If you log this Month, the logging implementation calls toString on it, which will return “JANUARY”. Instead of calling getMonthValue() on the ZonedDateTime you can also call getValue() on the Month enum value.
I just updated to 3.0.0 and I am thinking to get rid of at least some of my config files. Actually I was using paperui for things and configfile for items so far. I recognized now in 3.0.0 that once I ignore things in my inbox they are not ignored anymore after a openhab reboot. So I guess some of my config files have a higher prio then OH3 db things and therefor the files are used on OH reboot.
I am wondering now and sorry if I have missed some guideline on this how would be the smartest way to get rid of my config text files. Background I run OH in a docker and always kept on updates the “userdata”, “config” and “addons” folder which I also did now with the update to 3.0.0.
Would be the following workflow be the best way to switch to fully 3.0 UI:
Use the Bulk import for items in the new 3 UI
Shutdown OH and delete my items and things (just mail action and amazonechocontrol thing in there anyhow) file and restart OH
Is this the right approach?
Which other files do I need to delete to ensure 3.0 db is used for things and items and a behaviour like described above with ignored things re-apperaring after a reboot is fixed?
What about my rules which i like to further create/modify in Visual Studio Code. Do I need to somehow import them as well and can still use VSCode with the same syntax?
I would like to still use my sitemap until I got a new page created (and decide then which one I like more). Is this still possible after I imported my items?
Sigh many questions sorry but I am a bit worried that the work I put in the setup so far might be lost and I would have to start from scratch (like many hours just for my rules). The update to 3.0 was kinda ok so far (just some modification for pushover, ZonedDateTime Joda and influxdb was required). But changing to the new world in 3 completly now worries me a bit since everything is working ok so far …
Files always take precedence. One you move stuff to the ui you must remove the files.
Rename the files first and then import them. There is no need to restart OH.
Anything in the conf folder.
This is probably not related to the files. The Inbox shoes discovered Things, not Things from files.
You can continue to use any text config with the the exact same syntax as 2.5. There are just some minor changes for rules outlined in the release notes.
Sitemaps still work as does BasicUI.
You don’t have to move anything to the ui. You can leave them all in the same config files they are in now.
