Hi community,
I’m struggeling with zigbee binding and my CC2531 USB stick. I tested the scan with following ZigBee devices:
- Tradfri Motion Sensor E1745
- Tradfri Simple Switch/Dimmer (I/O)
- Tradfri Bulb
All devices have been reset → (pressed before 4 x the pairing button).
But no luck no devices are being found in the INBOX of Openhab 3.0.1
Any other troubleshooting suggestions are appreciated!
flashed firmware on CC2531
CC2531ZNP-Prod.hex
dmesg out:
cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
# list if the device has a port
ls -l /dev/serial/by-id
usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0018E1ABA5-if00 -> …/…/ttyACM0
# testing the access to port ttyACM0
test -w /dev/ttyACM0 && echo success || echo failure
success
Output after reboot of raspberry pi 4 openhab debug logging:
2021-01-24 16:46:39.332 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBeeDiscoveryService
2021-01-24 16:46:45.092 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to ‘127.0.0.1’ with clientid openhab
2021-01-24 16:46:45.388 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initializing ZigBee network [zigbee:coordinator_cc2531:Zigbee].
2021-01-24 16:46:45.390 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Channel 11
2021-01-24 16:46:45.392 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - PANID 65534
2021-01-24 16:46:45.394 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - EPANID 00124B0018E1ABA5
2021-01-24 16:46:45.398 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key 54328E85C171FCA551676EFAD23A9F8D
2021-01-24 16:46:45.399 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key 5A6967426565416C6C69616E63653039
2021-01-24 16:46:45.401 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Config: zigbee_initialise found, initializeNetwork=false
2021-01-24 16:46:45.413 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network Key String 54328E85C171FCA551676EFAD23A9F8D
2021-01-24 16:46:45.416 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Network key final array 54328E85C171FCA551676EFAD23A9F8D
2021-01-24 16:46:45.427 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link Key String 5A6967426565416C6C69616E63653039
2021-01-24 16:46:45.430 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Link key final array 5A6967426565416C6C69616E63653039
2021-01-24 16:46:45.432 [DEBUG] [.zigbee.cc2531.handler.CC2531Handler] - Initializing ZigBee CC2531 serial bridge handler.
2021-01-24 16:46:45.583 [DEBUG] [.zigbee.cc2531.handler.CC2531Handler] - ZigBee CC2531 Coordinator opening Port:’/dev/ttyACM0’ PAN:fffe, EPAN:00124B0018E1ABA5, Channel:11
2021-01-24 16:46:45.611 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Scheduling ZigBee start
2021-01-24 16:46:46.617 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee network starting
2021-01-24 16:46:46.618 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Initialising ZigBee coordinator
2021-01-24 16:46:46.762 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=INITIALISING
2021-01-24 16:46:46.841 [INFO ] [rnal.service.RemoteControllerService] - Using None interface
2021-01-24 16:46:46.945 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 00124B0018E1ABA5: ZigBee reading network state complete.
2021-01-24 16:46:46.980 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Connecting to serial port [/dev/ttyACM0] at 38400 baud, flow control FLOWCONTROL_OUT_RTSCTS.
2021-01-24 16:46:47.295 [DEBUG] [nding.zigbee.serial.ZigBeeSerialPort] - Serial port [/dev/ttyACM0] is initialized.
2021-01-24 16:46:48.281 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - Mesh Update Period 86400
2021-01-24 16:46:48.732 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee Initialise: Previous device configuration was: channel=CHANNEL_11, PanID=10257, EPanId=00124B0018E1ABA5
2021-01-24 16:46:49.224 [INFO ] [.cc2531.network.ZigBeeNetworkManager] - Initialized ZigBee network with existing network state.
2021-01-24 16:46:49.325 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee initialise done. channel=CHANNEL_11, PanId=10257 EPanId=00124B0018E1ABA5
2021-01-24 16:46:49.543 [DEBUG] [bee.handler.ZigBeeCoordinatorHandler] - null: networkStateUpdated called with state=ONLINE
2021-01-24 16:46:49.895 [DEBUG] [ding.zigbee.internal.ZigBeeDataStore] - 00124B0018E1ABA5: ZigBee saving network state complete.
2021-01-24 16:48:53.261 [DEBUG] [bee.discovery.ZigBeeDiscoveryService] - Starting ZigBee scan for zigbee:coordinator_cc2531:Zigbee
Thing in OH3:
Zigbee LogViewer
