Dear Community,
My setup is based on OpenHAB 3.2.0 and InfluxDB 1.0. While I had no particular issues, I now see error messages invoked by org.influxdb.impl.BatchProcessor in regular time intervals, every few minutes:
2022-03-30 09:50:08.950 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBIOException: java.net.SocketTimeoutException: connect timed out
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:831) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: java.net.SocketTimeoutException: connect timed out
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:412) ~[?:?]
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:255) ~[?:?]
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:237) ~[?:?]
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
at java.net.Socket.connect(Socket.java:615) ~[?:?]
at okhttp3.internal.platform.Platform.connectSocket(Platform.java:130) ~[bundleFile:?]
at okhttp3.internal.connection.RealConnection.connectSocket(RealConnection.java:263) ~[bundleFile:?]
at okhttp3.internal.connection.RealConnection.connect(RealConnection.java:183) ~[bundleFile:?]
at okhttp3.internal.connection.ExchangeFinder.findConnection(ExchangeFinder.java:224) ~[bundleFile:?]
at okhttp3.internal.connection.ExchangeFinder.findHealthyConnection(ExchangeFinder.java:108) ~[bundleFile:?]
at okhttp3.internal.connection.ExchangeFinder.find(ExchangeFinder.java:88) ~[bundleFile:?]
at okhttp3.internal.connection.Transmitter.newExchange(Transmitter.java:169) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:41) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
What I did lately was adding a few bindings without having already configured them. In the meantime, I removed the unconfigured bindings again, and only pulseaudio and marytts remain as new bindings while the rest of the configuration remained unchanged.
So I wonder what the cause is for this sudden appearance of this error message. I checked the resources on the OpenHAB server. While CPU usgae was quite low, there was a shortage of memory. However, even after increasing the memory to 8 GB with a current usage of below 4 GB, the error messages remained and appear every few minutes.
Adding memory seemed to an improvement, as the following warning disappeared from then:
2022-03-30 08:49:40.394 [WARN ] [ence.internal.PersistenceManagerImpl] - Querying persistence service 'influxdb' takes more than 5000ms.
Unfortunately, the error as initially reported is still there.
Best regards,
Peter
