- Platform information:
- Docker
- Broker binding connecting to mosquitto.
- openHAB version: 3.2
I am manually migrating my openhab 2.5 to 3.2. (GUI-only)
So i created a dimmer item which should send the value to an MQTT item.
But somehow it sends the value in the Dimmer item to MQTT divided by 100.
In this case i need it to send from 0 to 100, (0 - 1024 needed later). How can i manage that?
One thing which is also strange: i can only link from the Dimmer Item to the MQTT thing, not the other way around…
Eventlog says:
2022-02-23 21:05:37.545 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘GF_Hall_StairwayDimmer’ received command 88
2022-02-23 21:05:37.547 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘GF_Hall_StairwayDimmer’ predicted to become 88
2022-02-23 21:05:37.552 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘GF_Hall_StairwayDimmer’ changed from 56 to 88
In the binding i can see the value is 88%. But in MQTT it sends
Fusebox/light/pwm1 0.88
This is the Channel configuration
- id: GF_Hall_Stairwaylight
channelTypeUID: mqtt:dimmer
label: GF_Hall_Stairwaylight
description: “”
configuration:
commandTopic: Fusebox/light/pwm1
min: 0
formatBeforePublish: ‘“%.2f”’
max: 100
The channeltypeUID is afterwards manually set to dimmer. When creating the Channel there was no possibility to create a dimmer channel. For my issue described it does not make any difference…
Why is MQTT sending 0.88 instead of 88 ? I also read this post: OH3: Generic MQTT thing - Channel Item Dimmer It would be genius if it works like that…
and this one.. Weird behavior of Dimmer in combination with a Generic MQTT Thing - #4 by hafniumzinc The solution provided here seems not to work for me.. Added the State Description Metadata..
totally lost here.. anyone?
