openHAB 3.2 Release discussion
Thanks for your efforts to get 3.2 out!
After the upgrade from a snapshot version to 3.2 final I get the following:
2021-12-20 20:48:13.157 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-heliosventilation, openhab-binding-modbus, openhab-binding-tr064, openhab-binding-fronius, openhab-binding-dwdunwetter, openhab-persistence-jdbc-mysql, openhab-binding-xmppclient, openhab-binding-avmfritz, openhab-transformation-javascript, openhab-ui-habpanel, openhab-transformation-jsonpath, openhab-binding-shelly, openhab-binding-mqtt, openhab-transformation-map, openhab-ui-basic, openhab-binding-astro, openhab-binding-dwdpollenflug, openhab-binding-resol, openhab-binding-snmp': Error:
	Error downloading mvn:org.igniterealtime.smack/smack-experimental/4.3.3
And most of the bindings I use are not working
 Anyone else seeing this?
Mh, blindly removing the line
<bundle dependency="true">mvn:org.igniterealtime.smack/smack-extensions/4.3.3</bundle>
from the openhab-binding-xmppclient section in file /var/lib/openhab/tmp/kar/openhab-addons-3.2.0/org/openhab/distro/openhab-addons/3.2.0/openhab-addons-3.2.0-features.xml magicly improves the situation
Yes this is openhab-addons#11560. Now that these changes are also in the release it might be a good idea to upload the artifacts to the online repo @Kai.
Interesting ist, that a lot of unrelated bindings were affected and that might be worth a look for the future to make the loading of bindings more independent
Thanks! I guess I will test with a more linear upgrade path.
Thank you to all those that made version 3.2 possible.
Just to double check. Do the upgrade issues affect docker installation only?
Are there any issues reported with non-docker installations?
Anyone else having a problem with their Mail binding after the upgrade? I’m getting:
14:49:46.473 [WARN ] [hab.binding.mail.internal.SMTPHandler] - Sending the email to the following server failed : redacted.redacted.net:25
14:49:46.476 [WARN ] [hab.binding.mail.internal.SMTPHandler] - javax.mail.MessagingException: IOException while sending message;
  nested exception is:
	javax.activation.UnsupportedDataTypeException: text/plain; charset=UTF-8
Thing configuration:
Thing mail:smtp:redacted [ hostname="redacted.redacted.net", sender="redacted@redacted.com" ]
JavaScript code:
actions.get("mail", "mail:smtp:redacted").sendMail("redacted@redacted.com", "Test", "Test")
Actual addresses / IDs redacted. This was working in 3.1 on a manual install at /opt/openhab. It broke after running the upgrade script. I tried a fresh install to see if that made a difference but same problem on a fresh install too.
Yes and I opened a new thread at Mail binding errors sending mail UnsupportedDataTypeException: text/plaijn; charset=UTF=8.
Are you by chance running with JSScripting or using a different rules language?
It’s probably prudent to have most of the discussion over on the thread I started though.
Circling back, I’ve opened an issue for this: [Mail] sendMail and sendHtmlFail errors for UI rules · Issue #11838 · openhab/openhab-addons · GitHub It seems to impact all UI based rules regardless of language.
@rlkoshak Thanks, I did a search for this topic but didn’t stumble across your existing one. I will continue the conversation there.
Thanks for the ping, @wborn and sorry for not having it uploaded yet. @ramack, it’s done now and the xmppclient binding should now smoothly install (and not have any negative impact on other add-ons either).
Hello Kai,
thanks for your efforts. I just started built up OH3.2 from scratch using docker on my synology. But I am not sure whether the fixed version is already available in the docker repository (openhab:latest). Anyway, binding upload doesn’t work. How can I check whether your fixes are already available? Or is it what you mean “to upload the artifacts to the online repo”. Thnaks for any advice.
A huge thanks and a merry christmas to all involved in development, forums/help,documentation and organisation! Been using OH for years and I really appreciate all the work and effort! :clap: :christmas_tree: :slightly_smiling_face:
Just wanted to say here that update went without an hitch (apt based installation on raspbian). Thanks!
Same here, updated from 3.1.1 to 3.2.0 stable on openhabian. Worked perfect. I only had to replace Amazon Echo Binding with 3.2.8 version due to “socket errors” in openhab.log
After upgrading to 3.2 my powerview hub stays offline. I should mention that I am on docker. My network mode is host. The error message I see on the UI is:
BRIDGE_OFFLINE
java.util.concurrent.ExecutionException: "java.io.EOFException: HttpConnectionOverHTTP@1756b71::SocketChannelEndPoint@7e74a2{l=/10.0.0.3:40494,r=/10.0.0.52:80,ISHUT,fill=-,flush=-,to=10/0}{io=1/0,kio=1,kro=1}->HttpConnectionOverHTTP@1756b71(l:/10.0.0.3:40494 <-> r:/10.0.0.52:80,closed=false)=>HttpChannelOverHTTP@1e1013c(exchange=HttpExchange@1907899{req=HttpRequest[GET /api/sceneCollections/ HTTP/1.1]@138be39[TERMINATED/null] res=HttpResponse[null 0 null]@401a18[PENDING/null]})[send=HttpSenderOverHTTP@10d1c4d(req=QUEUED,snd=COMPLETED,failure=null)[HttpGenerator@183e345{s=START}],recv=HttpReceiverOverHTTP@1505c7a(rsp=IDLE,failure=null)[HttpParser{s=CLOSED,0 of -1}]]"
Does anybody have an idea how to fix this?
Hi there,
it seems, that in the nuki-binding of 3.2 are some breaking changes because they have changed all the lockstate-codes to lock and unlock the nuki.
i think, it would be good, if you could add this in the ‘breaking-changes’ enumeration of the release-announcement. it tooks me a couple of “magic minutes” in the cold to explore this
thanks! Ralph
Hi. Thanks for the update!
I updated from the RC1 to the 3.2 Release and now I found a bug. I am not 100% sure that it wasn’t already in the RC1 version, but it wasn’t in the 3.2 M5 Release.
This occures when I open a specific group in my sitemap.
2021-12-22 08:43:11.018 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
	at org.openhab.core.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:450) ~[?:?]
	at org.openhab.core.io.rest.sitemap.internal.SitemapResource.createWidgetBean(SitemapResource.java:517) ~[?:?]
	at org.openhab.core.io.rest.sitemap.internal.SitemapResource.createPageBean(SitemapResource.java:475) ~[?:?]
	at org.openhab.core.io.rest.sitemap.internal.SitemapResource.getPageBean(SitemapResource.java:371) ~[?:?]
	at org.openhab.core.io.rest.sitemap.internal.SitemapResource.getPageData(SitemapResource.java:284) ~[?:?]
	at jdk.internal.reflect.GeneratedMethodAccessor346.invoke(Unknown Source) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
	at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179) ~[bundleFile:3.4.5]
	at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96) ~[bundleFile:3.4.5]
	at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201) ~[bundleFile:3.4.5]
	at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104) ~[bundleFile:3.4.5]
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59) ~[bundleFile:3.4.5]
	at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96) ~[bundleFile:3.4.5]
	at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:308) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:298) ~[bundleFile:3.4.5]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222) ~[bundleFile:3.4.5]
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[bundleFile:3.1.0]
	at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:273) ~[bundleFile:3.4.5]
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:550) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:602) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1434) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:294) ~[bundleFile:?]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1349) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[bundleFile:9.4.43.v20210629]
	at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:82) ~[bundleFile:?]
	at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:388) ~[bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:633) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:380) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:386) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) [bundleFile:9.4.43.v20210629]
	at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) [bundleFile:9.4.43.v20210629]
Sitemap:
Group item=Wetterstation label="Wetterstation" icon="sun_clouds"
Items:
Group                           Wetterstation                                   "Wetterstation"                         <sun>                   (Aussenbereich)
Number:Pressure                 HttpListenerWetterstation_BaromIn               "Luftdruck [%.1f hPa]"                  <pressure>              (Wetterstation, gHistory)          ["Measurement", "Pressure"]                 { channel="httplistener:HttpListener:weatherstation:BaromIn" }
Number:Temperature              HttpListenerWetterstation_TempF                 "Temperatur [%.1f °C]"                  <temperature>           (Wetterstation, gHistory)          ["Measurement", "Temperature"]              { channel="httplistener:HttpListener:weatherstation:TempF" }
Number:Temperature              HttpListenerWetterstation_DewPointF             "Taupunkt [%.1f °C]"                    <temperature>           (Wetterstation, gHistory)          ["Measurement", "Temperature"]              { channel="httplistener:HttpListener:weatherstation:DewPointF" }
Number                          HttpListenerWetterstation_Humidity              "Luftfeuchtigkeit [%.1f %%]"            <humidity>              (Wetterstation, gHistory)          ["Measurement", "Humidity"]                 { channel="httplistener:HttpListener:weatherstation:Humidity" }
Number:Speed                    HttpListenerWetterstation_WindSpeedMph          "Windgeschwindigkeit [%.1f km/h]"       <wind>                  (Wetterstation, gHistory)          ["Measurement", "Wind"]                     { channel="httplistener:HttpListener:weatherstation:WindSpeedMph" }
Number:Speed                    HttpListenerWetterstation_WindGustMph           "Windböe [%.1f km/h]"                   <wind>                  (Wetterstation)                    ["Measurement", "Wind"]                     { channel="httplistener:HttpListener:weatherstation:WindGustMph" }
Number:Angle                    HttpListenerWetterstation_WindDir               "Windrichtung"                          <wind>                  (Wetterstation)                    ["Point"]                                   { channel="httplistener:HttpListener:weatherstation:WindDir" }
Number                   HttpListenerWetterstation_RainIn                "Regenmenge [%.1f mm/h]"                <rain>                  (Wetterstation, gHistory)          ["Measurement", "Rain"]                     { channel="httplistener:HttpListener:weatherstation:RainIn" }
Number:Length                   HttpListenerWetterstation_DailyRainIn           "Regenmenge (Tag)"                      <rain>                  (Wetterstation, gHistory)          ["Measurement", "Rain"]                     { channel="httplistener:HttpListener:weatherstation:DailyRainIn" }
Number:Intensity                HttpListenerWetterstation_SolarRadiation        "Sonnenstrahlung [%.1f W/mÂČ]"           <sun>                   (Wetterstation, gHistory)          ["Point"]                                   { channel="httplistener:HttpListener:weatherstation:SolarRadiation" }
Number                          HttpListenerWetterstation_UV                    "UV"                                    <sun>                   (Wetterstation, gHistory)          ["Measurement", "Ultraviolet"]              { channel="httplistener:HttpListener:weatherstation:UV" }
Number:Temperature              HttpListenerWetterstation_IndoorTempF           "Innentemperatur [%.1f °C]"             <temperature>           (Wetterstation, gHistory)          ["Measurement", "Temperature"]              { channel="httplistener:HttpListener:weatherstation:IndoorTempF" }
Number                          HttpListenerWetterstation_IndoorHumidity        "Innenluftfeuchtigkeit [%.1f %%]"       <humidity>              (Wetterstation, gHistory)          ["Measurement", "Humidity"]                 { channel="httplistener:HttpListener:weatherstation:IndoorHumidity" }
Update to 3.2 went smoothly for apt based install on Raspberry Pi 4.
No bugs found so far.
Many thanks :folded_hands:
I updated from 3.1.1 to 3.2 on openhabian 1.7, I had a filepermission issue. But after fixing that it works smoothly now.
Thx devs!
