Hi
I mean the settings refered to her:
My openHAB settings are correct, since the audio is played on my PC browser. So I have no idea why I can not get it working on Android or Firefox.
Would be nice if it worked in the Andorid App too.
Hi
Sorry, I don’t find the page containing these settings !!!
A feature request should be created in the Git repo of the Android app.
I think browser dependent. And different on PC and Android. I assume you mean the actual browser settings and not the page referring to these settings (that is the GITHub article as top of thread,)
The Main UI “Web Audio enabled” setting is saved in the browser local storage, so it should be configured in each browser.
Sorry, I misunderstood that from the docs. I read that as a server setting and then that you have to make sure the browser settings are enabled as well.
After turning on on my Android Browser it now works.
Sorry about the misunderstanding.
EDIT: And with the setting enabled in the Android App it works there too
Looking at the files details, I see that barking.mp3 is a mono MP3 @ 64 kbps while doorbell.mp3 is a joint stereo MP3 @ 128 kbps.
So for doorbell, we have the most common bitrate, I can’t believe this can be the problem. Maybe an incompatibility of Firefox with joint stereo ???
today I tried to update to 3.4.0 M1, but when restarting openHAB after the update I get the following error:
2-08-16 20:16:27.988 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue,
openhab-binding-tr064, openhab-persistence-mapdb, openhab-binding-exec, openhab-binding-ftpupload,
openhab-binding-avmfritz, openhab-binding-pushover, openhab-binding-network, openhab-ui-habpanel,
openhab-binding-denonmarantz, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-logreader,
openhab-transformation-scale, openhab-binding-icalendar, openhab-binding-km200, openhab-binding-mail,
openhab-transformation-regex, openhab-automation-jythonscripting, openhab-ui-basic,
openhab-persistence-jdbc-postgresql, openhab-misc-homekit, openhab-binding-openweathermap, openhab-binding-http,
openhab-binding-astro, openhab-binding-knx, openhab-binding-snmp': Error:
Error downloading mvn:org.postgresql/postgresql/42.4.1
I tried restarting several times over the course of the day, so this does not seem to be a temporary glitch. After downgrading to 3.3.0 everything works as ecpected.
I am using an installation via apt on a Debian 11.
I did some more research regarding the error above.
Ist is caused by the PostgreSQL JDBC persistence service. I tried to place the postgresql-42.4.1.jar in the /usr/share/openhab/addons folder and it is loaded, as the output of bundle:list shows:
100 │ Active │ 80 │ 42.4.1 │ PostgreSQL JDBC Driver
But I still get the error.
Probably I am missing something, but I can not figure out what it is…
Hi @juelicher,
I’ve just checked, this is due to the upgrade of the postgres driver in [jdbc] Update PostgreSQL JDBC driver to 42.4.1 by dependabot[bot] · Pull Request #13221 · openhab/openhab-addons · GitHub.
I have now uploaded the new jar to our remote repository, so that the Feature installer should no longer fail downloading it. I hope this solves the issue for you!
Hi @Kai ,
thanks for your help! I just tested it and the issue is resolved.
I am still not sure, why placing the jar file in the addons folder did not work, but I found an old threads describing the exact same problem. So this is not an issue with the current 3.4 Milestone release.
Hi, I upgraded from 3.3, after the upgrade all my “things” disappeared and stopped responding (items were in place).
I restored from backup, all “items” are working now, but the “things” screen is in constant loading state, any ideas?
What is in the logs?
2022-08-21 00:20:48.265 [ERROR] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - Problem with writing the data, class org.openhab.core.io.rest.Stream2JSONInputStream, ContentType: application/json
2022-08-21 00:20:48.581 [ERROR] [internal.JSONResponseExceptionMapper] - Unexpected exception occurred while processing REST request.
That‘s everything? Do you use the Homematic binding? There is a separate thread about that.
when I encounter that, it usually means the UI has logged you out…go to the main page…
This is not a Milestone issue. Please delete the Thing and let it be rediscovered.
Looks like some libraries are not uploaded to the maven repository for 3.4M2:
Error downloading mvn:com.github.oshi/oshi-core/6.2.2
Error downloading mvn:net.java.dev.jna/jna-platform/5.12.1
Error downloading mvn:net.java.dev.jna/jna/5.12.1
Just updated to M2 today, and now on every restart I am seeing 40 or 50 “Added new thing ‘…’ to inbox.” messages in my log. And even if I mark the things as ignored, they still reappear in the next restart. The issue relates to all of my bindings so it is not a binding issue but rather a core issue.
