Issue of the topic: connect to cloud connecter (myOpenhab)
Hi All,
Just installed the Openhab 3 version on my Raspberry.
(just a clean installation).
now I have already some items/things in the configuration.
before I transfer every thing to Openhab 3, I just want the basic setup running.
Now I want to try to connect the Openhab 3 to myOpenhab and try to find the UUID and SECRET.
It seems that you canât get the UUID and SECRET in the same way as it was with OpenHab 2.
(at least as I try to search for /var/lib/openhab2/uuid (or /var/lib/openhab3/uuid and /var/lib/openhab2/openhabcloud/secret I donât find anything).
Hi folks,
iâm looking for the uuid and the secret, too.
In my case a using openhab 3 within docker on a Synology NAS.
I mounted the userdata and conf folder to my windows pc but there is no uuid or openhabcloud directroy within there. Also there is no openhab directory within /var/lib/ on the host. I have tried out to looking for the file (find . -name uuid) without any success.
Is it nessesary to add a binding or thing after installation of the misc through the web page?
Or may be the openhab instance is not allowed to create the directory?
Thx for your advise.
Sascha
In the image the userdata folder is /openhab/userdata. But if youâve mounted a folder from your host to that location you will see the contents of that folder from that folder just as easily from inside the container. All I can offer in terms of debugging is it works for me running in Docker.
Hi agian,
iâve cheked once agian that the cifs file permission on the share (NAS) are set correctly. Iâve also cheked that i mentioned the correct uid of the Synology user within the docker environment variables (and also the group id).
Iâve cleared the OH cache and restarted the docker image several times without success.
After that, i started with a clean docker image of OH3. The image a used before was a result of an update process from OH2.5.5 to OH3. After installation of the openhabcloud misc, the uuid and the secret appears emediately and it works.
