Hello all,
I have openHAB 3 running on a Raspberry Pi 4.
- Release = Raspbian GNU/Linux 10 (buster)
- Kernel = Linux 5.10.103-v7l+
- Platform = Raspberry Pi 4 Model B Rev 1.4
- CPU Usage = 2.76% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
- CPU Load = 1m: 0.21, 5m: 0.18, 15m: 0.11
- Memory = Free: 6.80GB (88%), Used: 0.95GB (12%), Total: 7.76GB
- Root = Free: 49.59GB (87%), Used: 6.80GB (13%), Total: 58.26GB
- openjdk version “11.0.13” 2021-10-19 LTS
- OpenJDK Runtime Environment Zulu11.52+13-CA (build 11.0.13+8-LTS)
- OpenJDK Client VM Zulu11.52+13-CA (build 11.0.13+8-LTS, mixed mode)
Again and again the system stops, sometimes after a few days, sometimes after 1 - 2 weeks. I can’t see a pattern. Then I turn the RPi off and on again and everything runs again.
Now I had such a case again. SSH to the RPi is running. So only openHAB hangs.
In openhab.log is nothing at all to a problem or a cause. Via PC or smartphone I can open the UI interface but changes to items or things are not executed, no items or things are updated.
I have recorded the following with htop
1 [ 0.0%] Tasks: 34, 236 thr; 1 running
2 [ 0.0%] Load average: 0.00 0.02 0.01
3 [||| 2.6%] Uptime: 2 days, 10:50:05
4 [ 0.0%]
Mem[|||||||||||||| 453M/7.76G]
Swp[ 0K/2.00G]
PID USER PRI NI VIRT RES SHR S CPU% MEM% TIME+ Command
7576 root 20 0 9820 4076 2252 R 2.6 0.1 0:00.87 htop
667 openhab 20 0 625M 374M 10140 S 0.0 4.7 1h30:37 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
20963 openhab 20 0 625M 374M 10140 S 0.0 4.7 1:02.06 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1659 openhab 20 0 625M 374M 10140 S 0.0 4.7 3:02.71 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
7551 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:00.08 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1496 openhab 20 0 625M 374M 10140 S 0.0 4.7 4:32.67 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1481 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:37.82 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1485 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:38.80 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
7083 openhabia 20 0 12240 3636 2848 S 0.0 0.0 0:00.03 sshd: openhabian@pts/0
1624 openhab 20 0 625M 374M 10140 S 0.0 4.7 2:07.45 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1658 openhab 20 0 625M 374M 10140 S 0.0 4.7 3:08.70 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1498 openhab 20 0 625M 374M 10140 S 0.0 4.7 4:31.68 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1544 openhab 20 0 625M 374M 10140 S 0.0 4.7 4:39.06 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
806 openhab 20 0 625M 374M 10140 S 0.0 4.7 6:57.96 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1552 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:23.65 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
926 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:24.34 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1556 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:22.79 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1559 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:24.27 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1233 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:11.58 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
2347 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:01.83 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1488 openhab 20 0 625M 374M 10140 S 0.0 4.7 0:48.39 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.
1 root 20 0 33828 8168 6456 S 0.0 0.1 0:37.58 /sbin/init
122 root 20 0 62280 10768 9876 S 0.0 0.1 0:09.61 /lib/systemd/systemd-journald
159 root 20 0 18156 3920 3108 S 0.0 0.0 0:00.94 /lib/systemd/systemd-udevd
342 messagebu 20 0 6648 3512 3012 S 0.0 0.0 0:08.20 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
349 root 39 19 3692 720 612 S 0.0 0.0 0:00.10 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
353 root 20 0 8312 2292 2080 S 0.0 0.0 0:00.98 /usr/sbin/cron -f
360 root 20 0 13136 5760 5076 S 0.0 0.1 0:03.29 /lib/systemd/systemd-logind
389 root 20 0 25512 2668 2356 S 0.0 0.0 0:00.65 /usr/sbin/rsyslogd -n -iNONE
390 root 20 0 25512 2668 2356 S 0.0 0.0 0:00.78 /usr/sbin/rsyslogd -n -iNONE
391 root 20 0 25512 2668 2356 S 0.0 0.0 0:00.00 /usr/sbin/rsyslogd -n -iNONE
363 root 20 0 25512 2668 2356 S 0.0 0.0 0:01.50 /usr/sbin/rsyslogd -n -iNONE
370 root 20 0 10744 3700 3328 S 0.0 0.0 0:01.38 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
375 avahi 20 0 5900 2632 2380 S 0.0 0.0 0:28.31 avahi-daemon: running [openhabian.local]
393 avahi 20 0 5768 252 0 S 0.0 0.0 0:00.00 avahi-daemon: chroot helper
398 root 20 0 27656 80 0 S 0.0 0.0 0:03.16 /usr/sbin/rngd -r /dev/hwrng
399 root 20 0 27656 80 0 S 0.0 0.0 0:00.06 /usr/sbin/rngd -r /dev/hwrng
400 root 20 0 27656 80 0 S 0.0 0.0 0:00.25 /usr/sbin/rngd -r /dev/hwrng
After the kill of PID 667 openHAB was running again.
How can I debug this more. I would like to know where the problem is.
Greetings Holger
