Hi all,
for no reason homegear stopped working. I reinstalled it through openhabian-config and the bridge is “online”, but the homegear servers page says “Homegear CCU isn´t ready yet”. Any idea what is wrong here?
edit:
a piece from my log:
2021-06-06 12:34:10.826 [ERROR] [very.HomematicDeviceDiscoveryService] - html
java.io.IOException: html
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScript(CcuGateway.java:220) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScriptByName(CcuGateway.java:190) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScriptByName(CcuGateway.java:178) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.loadDeviceNames(CcuGateway.java:103) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.getDeviceDescriptions(AbstractHomematicGateway.java:452) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.communicator.AbstractHomematicGateway.loadAllDeviceMetadata(AbstractHomematicGateway.java:372) ~[bundleFile:?]
at org.openhab.binding.homematic.internal.discovery.HomematicDeviceDiscoveryService.lambda$0(HomematicDeviceDiscoveryService.java:209) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: com.thoughtworks.xstream.mapper.CannotResolveClassException: html
at com.thoughtworks.xstream.mapper.DefaultMapper.realClass(DefaultMapper.java:81) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.DynamicProxyMapper.realClass(DynamicProxyMapper.java:55) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.PackageAliasingMapper.realClass(PackageAliasingMapper.java:88) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.ClassAliasingMapper.realClass(ClassAliasingMapper.java:79) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.ArrayMapper.realClass(ArrayMapper.java:74) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:71) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:133) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1404) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1383) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1268) ~[bundleFile:1.4.13]
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1259) ~[bundleFile:1.4.13]
at org.openhab.binding.homematic.internal.communicator.CcuGateway.sendScript(CcuGateway.java:218) ~[bundleFile:?]
... 12 more
also:
2021-06-06 12:34:11.031 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:bridge:3014F711A061A7D5699DB2E3' changed from INITIALIZING to ONLINE
2021-06-06 12:34:11.153 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:PEQ0011156' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.192 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:OEQ1299504' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.213 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:PEQ0011156' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address 'PEQ0011156' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.236 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A1709A64377' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.243 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:OEQ1299504' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address 'OEQ1299504' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.250 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A1709A64300' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.295 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A1709A64377' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address '000A1709A64377' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.309 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:PEQ0011671' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.324 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:NEQ1366599' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.350 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A1709A64307' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.353 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:PEQ0011671' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address 'PEQ0011671' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.361 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A1709A64300' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address '000A1709A64300' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.384 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:NEQ1366599' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address 'NEQ1366599' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.391 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A1709A64307' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address '000A1709A64307' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.406 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:PEQ0011728' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.409 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A18A9A3A2E9' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.423 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A18A9A3A2E9' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address '000A18A9A3A2E9' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.427 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HM-LC-Bl1PBU-FM:3014F711A061A7D5699DB2E3:PEQ0011728' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address 'PEQ0011728' not found on gateway '3014F711A061A7D5699DB2E3'
2021-06-06 12:34:11.442 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A18A9A3A29E' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-06-06 12:34:11.461 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'homematic:HmIP-eTRV-2:3014F711A061A7D5699DB2E3:000A18A9A3A29E' changed from INITIALIZING to OFFLINE (CONFIGURATION_ERROR): Device with address '000A18A9A3A29E' not found on gateway '3014F711A061A7D5699DB2E3'
the Bidcos device and the gateway were in error state, so I deleted them and now they´re gone and not coming back again:
