Openhab 3 / homematic binding / CCU (raspberryMatic) not connection / Jetty start failed
The log shows an exception that I have never seen before at this position :-(.
Can you give me some information about your environment:
  • in wich environment is OH running?
  • do you have one or two CCU resp. Raspberrymatic installations active?
  • can you login to the Karaf console and issue the following command bundle:list | grep Homematic. The output contains the exact version of the binding. This would help me to find the correct position in the source code.
