Openhab 3 / homematic binding / CCU (raspberryMatic) not connection / Jetty start failed
Hello I am running OH 3.0.1 on 1 server and raspberryMatic on server 2.
The target is to import the homematic devices in openhab
openhab server: IP 192.168.178.70
here is the routing table:
root@openHABianDevice:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.178.1 0.0.0.0 UG 202 0 0 eth0
192.168.1.0 0.0.0.0 255.255.255.0 U 304 0 0 wlan0
192.168.178.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
raspberrymatic: 192.168.178.50
Binding: homematic
Openhab find the bridge and the device, but it is running into problems and then a communication error comes up.
2021-02-28 10:13:26.021 [WARN ] [core.thing.internal.ThingManagerImpl] - Disposing handler for thing ‘homematic:bridge:34a2b67edc’ takes more than 5000ms.
2021-02-28 10:13:26.046 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘homematic:bridge:34a2b67edc’ changed from UNINITIALIZED to UNINITIALIZED (DISABLED)
2021-02-28 10:13:26.048 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘homematic:HMIP-PS:34a2b67edc:00021A498E18B5’ changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to UNINITIALIZED (BRIDGE_UNINITIALIZED)
2021-02-28 10:13:33.620 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘homematic:bridge:34a2b67edc’ changed from UNINITIALIZED (DISABLED) to INITIALIZING
2021-02-28 10:13:43.864 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler HomematicBridgeHandler tried updating its configuration although the handler was already disposed.
2021-02-28 10:13:43.867 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler HomematicBridgeHandler tried updating its configuration although the handler was already disposed.
2021-02-28 10:13:43.954 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘WIRED’ on gateway ‘34a2b67edc’ not available, disabling support
2021-02-28 10:13:43.984 [INFO ] [ternal.communicator.client.RpcClient] - Interface ‘CUXD’ on gateway ‘34a2b67edc’ not available, disabling support
2021-02-28 10:13:44.029 [INFO ] [ommunicator.AbstractHomematicGateway] - HmGatewayInfo[id=CCU,type=CCU2,firmware=3.55.10.20210213,address=QEQ0695118,rf=true,wired=false,hmip=true,cuxd=false,group=true]
2021-02-28 10:13:59.050 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler HomematicBridgeHandler tried updating the thing status although the handler was already disposed.
2021-02-28 10:14:58.988 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘homematic:HMIP-PS:34a2b67edc:00021A498E18B5’ changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2021-02-28 10:14:59.001 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing ‘homematic:HMIP-PS:34a2b67edc:00021A498E18B5’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): HomematicGateway not yet available!
The ports should be open to raspberryMatic
Thanks for your help.
Markus
