After 1 day working with OpenHab 3 i can not login at the MainUI.
Tried it on different devices but always the same.
I use a clean openhabian 1.6.2
Everything else is working fine, no errors in the log.
When i refresh the page after a login try: http://ip:8080 → i am not logged in.
Has something like that already happened to anyone?
I have the same issue at the moment. New installation of openhabian 1.6.2 with openhab 3.1.0-SNAPSHOT - Build #2147.
I get this in the log:
2021-01-18 18:12:38.110 [INFO ] [rg.apache.cxf.jaxrs.utils.JAXRSUtils] - Resource class org.openhab.core.io.rest.sse.SseResource does not support HEAD http method, method listen supporting GET http method will be invoked
Without logging in, everything is fine. when I log in, I only get a blang page. Although openhab is set to darkmode, the pages are white.
