Reading responses from top to bottom… If I installed openHabin through the link you shared, I assume it will just install openHAB as an app in Debian 11?
I don’t want it to install as it did on my Pi where its running like an os.
If it does install like an app, then I’ll just do that, as it looks easy and I don’t know what I’m missing out on vs installing the way @chrismast suggested.
… Now would be a great time to hear the pros and cons of each method
PS slow reply as have been busy migrating to a new Debian install on new hardware…lots to install and configuration to do…
Debian 11
Node-RED
Lots of NR contrib
NR Uibuilder
VSC
Parcel
Influxdb
Grafana
MQTT
Satel
Plus more…
Now I’m ready to dabble with ooenHAB. I have 4x zwave sticks, 2x Pis and a Debian PC to setup multiple zwave networks on… Aiming for 8x networks across 4x physical devices in the end (3x Pi and 1x Debian PC)… Its going to be a long journey!
For me the major difference is in automation.
ooenhabian (which I also used at the beginning) offers a nice menu and automation of a lot of steps while apt is a simple package manager and does not do so.
Example 1: frontail log viewer can be installed via openhabian with a simple click and is automatically configured for openhab while with apt you will have to do so manually (i.e. edit a config file, not Rocket science but an extra job).
Example 2: backups can be done via the menu while with the apt way you will need to execute the CLI command (openhab-cli backup) manually/via cron.
A lot of people here use openhabian therefore.
I preferred apt as I am used to debian CLI (I do run a HA (high availability) cluster of 5 enterprise servers and a PI with about 15 - 20 LXCs, all debian) but I think there is no right or wrong, both options are valid.
Sounds like you have been dabbling with HA for a while with your setup!
Thanks for the explanation. It’s a no-brainer for me, I’ll go openhabian on the basis that I’m not sure how much I will use openhab at the moment, more than as a zwave interface, as I do almost everything in Node-RED these days, so the easier option is probable the better.
Give it a few minutes to startup for the first time.
I use the following commands frequently:
//To see the status of openHAB
sudo systemctl status openhab.service
//To enter the openHAB console
openhab-cli console
//password is habopen
//Once in the openHAB console, to monitor the logs
log:tail
Quite a few of us tinker with the thing beyond repair. Having the program containerised (and good backups, of course) makes ‘re-installing’ less painful - it turns all the commands shown above into (sometimes) one single command.
Docker allows you to isolate environments and re-create them whenever you want.
This is especially helpful with tools that change a lot (i.e. if you want to test new versions).
In addition it can simplify, as @hafniumzinc mentioned, deployments of very complex systems (for instance with multiple services) into one combined command/docker-compose file.
I use docker extensively across my services as, as mentioned, simplifies deployments.
Docker though also got some complexities, for instance in how it manages networks and you need to make sure to mount the right directories as otherwise you have to exec into the container all the time.
If you want to go the docker route and you are not yet familiar with it, you can watch a few videos to get started, there is a lot of content on YouTube.
That is also the main reason why I, take into account here many people run OH in docker (!), went with bare metal debian for openhab via apt as this takes out this potential (!) networking complexity (esp. with a service that relies on connection a vast list of devices across different protocols) with docker.
I also installed frontail bare metal as I do not have a docker instance running on the same LXC for now.
At the end its completely up to you, apt, docker, openhabian are all good ways of getting OH up and running.
For reliable home automation you should minimise complexity and interdependencies as much as possible.
We recommend running a dedicated box for OH i.e. no container or other virtualization.
Docker has its strengths in Cloud and Enterprise environments but a typical Home Automation installation is not where it can put these to use.
You don’t have mass or frequent (re) deployments or upgrades.
Choice is yours. I’d go with openHABian. Note it is not only an image for Raspis but can be deployed on top of x86 Debian as well.
If you run openhabian-config with the “unattended” parameter it’ll automatically install and configure a ready to use OpenHAB system (read the docs before). Like the image for Raspberry or Docker do, just a lot more of what what you will useful.
