- Platform information:
- Hardware: HP Microserver AMD Athlon™ II Neo N36L Dual-Core Processor, 2GB RAM
- OS:Ubuntu Server 20.04 LTS
- Java Runtime Environment:Zulu 11
- openHAB version: 3
- Issue of the topic: Openhab ports not opening
Fresh install of OpenHAB3, was working on it yesterday fine.
Manually migrating from openhab2 on a full fresh install of OS and OH.
Since this is a multi-use server, I also installed Unifi controller software (for Ubiquiti network device management, previously installed alongside openhab fine).
Unifi Controller uses ports:1443 and 8081 which are working fine.
Now the openhab service starts but it does not open any ports. No errors (nothing at all) in openhab.log.
Stopped/disabled unifi software, no change after restarting openhab and the server.
I was hoping to find something in the logs but can’t find any reason it’s not working.
● openhab.service - openHAB - empowering the smart home
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2021-01-23 09:32:33 ACDT; 42s ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 959 (java)
Tasks: 38 (limit: 2129)
Memory: 348.9M
CGroup: /system.slice/openhab.service
└─959 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/openhab -Dop>
Jan 23 09:32:33 nas systemd[1]: Started openHAB - empowering the smart home.
lines 1-12/12 (END)
#>nmap localhost
Starting Nmap 7.80 ( https://nmap.org ) at 2021-01-23 09:35 ACDT
Nmap scan report for localhost (127.0.0.1)
Host is up (0.00021s latency).
Not shown: 996 closed ports
PORT STATE SERVICE
22/tcp open ssh
139/tcp open netbios-ssn
445/tcp open microsoft-ds
10000/tcp open snet-sensor-mgmt
Nmap done: 1 IP address (1 host up) scanned in 0.15 seconds
