Earlier, the roller shutters in the office and on the terrace worked, and then nothing worked when I tried to integrate the 3rd roller shutter in the living room couch. Again, no error message is displayed, but no commands are sent to the Arduino except for the STOP functions.
.rule 1
var Timer t_Rolllaeden = null
rule "KG Rollladen Buero HOCH/RUNTER/STOP"
Item KG_Rollladen_Buero received command
switch(receivedCommand.toString.toUpperCase){
case "UP": {
KG_Rollladen_Buero_UP.postUpdate(1)
logInfo ("KG-R-B-UP - check", "Variablenstatus ist: " + KG_Rollladen_Buero_UP.state)
case "STOP": {
KG_Rollladen_Buero_UP.postUpdate(0)
KG_Rollladen_Buero_DOWN.postUpdate(0)
logInfo ("KG-R-B-DOWN - check", "Variablenstatus ist: " + KG_Rollladen_Buero_DOWN.state)
sendCommand (ArduMEGA, "<KG_Rollladen_Buero_STOP,>");
KG_Rollladen_Buero_STOP.postUpdate(1)
logInfo ("KG-R-B-STOP - check", "Variablenstatus ist: " + KG_Rollladen_Buero_STOP.state)
case "DOWN": {
KG_Rollladen_Buero_DOWN.postUpdate(1)
rule "EG Rollladen Terrasse HOCH/RUNTER/STOP"
Item EG_Rollladen_Terrasse received command
case "UP": {
EG_Rollladen_Terrasse_UP.postUpdate(1)
logInfo ("EG-R-T-UP - check", "Variablenstatus ist: " + EG_Rollladen_Terrasse_UP.state)
case "STOP": {
EG_Rollladen_Terrasse_UP.postUpdate(0)
EG_Rollladen_Terrasse_DOWN.postUpdate(0)
logInfo ("EG-R-T-DOWN - check", "Variablenstatus ist: " + EG_Rollladen_Terrasse_DOWN.state)
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_STOP,>");
t_Rolllaeden = null
t_Rolllaeden = createTimer (now.plusSeconds(1), [
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_U_E,>");
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_D_E,>");
t_Rolllaeden = null
EG_Rollladen_Terrasse_STOP.postUpdate(1)
logInfo ("EG-R-T-STOP - check", "Variablenstatus ist: " + EG_Rollladen_Terrasse_STOP.state)
case "DOWN": {
EG_Rollladen_Terrasse_DOWN.postUpdate(1)
.rule 2
rule "KG_Rollladen_Buero_UPDOWN"
Item KG_Rollladen_Buero_UP changed or
Item KG_Rollladen_Buero_DOWN changed or
Time cron "0 0/1 * 1/1 * ? *"
t_Rolllaeden = createTimer (now.plusSeconds(2), [
if (KG_Rollladen_Buero_UP.state == 1 && KG_Rollladen_Buero_STOP.state == 1 && EG_Rollladen_Terrasse_STOP.state == 1 && EG_Rollladen_Wohnzimmer_Couch_STOP.state == 1 && EG_Rollladen_Esszimmer_STOP.state == 1 && EG_Rollladen_Kueche_Einfahrt_STOP.state == 1 && EG_Rollladen_Kueche_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Garten_STOP.state == 1 && OG_Rollladen_Bad_STOP.state == 1 && DG_Rollladen_Schlafzimmer_STOP.state == 1 && DG_Rollladen_Bad_STOP.state == 1){
t_Rolllaeden = null
KG_Rollladen_Buero_STOP.postUpdate(0)
logInfo ("KG-R-B-UP if ausgeführt", "Variablenstatus ist: " + KG_Rollladen_Buero_UP.state )
sendCommand (ArduMEGA, "<KG_Rollladen_Buero_UP,>");
t_Rolllaeden = createTimer (now.plusSeconds(40), [
sendCommand (KG_Rollladen_Buero, STOP)
t_Rolllaeden = null
else if (KG_Rollladen_Buero_DOWN.state == 1 && KG_Rollladen_Buero_STOP.state == 1 && EG_Rollladen_Terrasse_STOP.state == 1 && EG_Rollladen_Wohnzimmer_Couch_STOP.state == 1 && EG_Rollladen_Esszimmer_STOP.state == 1 && EG_Rollladen_Kueche_Einfahrt_STOP.state == 1 && EG_Rollladen_Kueche_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Garten_STOP.state == 1 && OG_Rollladen_Bad_STOP.state == 1 && DG_Rollladen_Schlafzimmer_STOP.state == 1 && DG_Rollladen_Bad_STOP.state == 1){
t_Rolllaeden = null
logInfo ("KG-R-B-DOWN if ausgeführt", "Variablenstatus ist: " + KG_Rollladen_Buero_DOWN.state )
sendCommand (ArduMEGA, "<KG_Rollladen_Buero_DOWN,>");
t_Rolllaeden = null
rule "EG_Rollladen_Terrasse_UPDOWN"
Item EG_Rollladen_Terrasse_UP changed or
Item EG_Rollladen_Terrasse_DOWN changed or
t_Rolllaeden = null
t_Rolllaeden = createTimer (now.plusSeconds(3), [
if (EG_Rollladen_Terrasse_UP.state == 1 && KG_Rollladen_Buero_STOP.state == 1 && EG_Rollladen_Terrasse_STOP.state == 1 && EG_Rollladen_Wohnzimmer_Couch_STOP.state == 1 && EG_Rollladen_Esszimmer_STOP.state == 1 && EG_Rollladen_Kueche_Einfahrt_STOP.state == 1 && EG_Rollladen_Kueche_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Garten_STOP.state == 1 && OG_Rollladen_Bad_STOP.state == 1 && DG_Rollladen_Schlafzimmer_STOP.state == 1 && DG_Rollladen_Bad_STOP.state == 1){
t_Rolllaeden = null
EG_Rollladen_Terrasse_STOP.postUpdate(0)
logInfo ("EG-R-T-UP if ausgeführt", "Variablenstatus ist: " + EG_Rollladen_Terrasse_UP.state )
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_U_V,>");
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_D_V,>");
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_UP,>");
t_Rolllaeden = null
sendCommand (EG_Rollladen_Terrasse, STOP)
t_Rolllaeden = null
else if (EG_Rollladen_Terrasse_DOWN.state == 1 && KG_Rollladen_Buero_STOP.state == 1 && EG_Rollladen_Terrasse_STOP.state == 1 && EG_Rollladen_Wohnzimmer_Couch_STOP.state == 1 && EG_Rollladen_Esszimmer_STOP.state == 1 && EG_Rollladen_Kueche_Einfahrt_STOP.state == 1 && EG_Rollladen_Kueche_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Strasse_STOP.state == 1 && OG_Rollladen_Zimmer_Garten_STOP.state == 1 && OG_Rollladen_Bad_STOP.state == 1 && DG_Rollladen_Schlafzimmer_STOP.state == 1 && DG_Rollladen_Bad_STOP.state == 1){
t_Rolllaeden = null
logInfo ("EG-R-T-DOWN if ausgeführt", "Variablenstatus ist: " + EG_Rollladen_Terrasse_DOWN.state )
sendCommand (ArduMEGA, "<EG_Rollladen_Terrasse_DOWN,>");
t_Rolllaeden = null
t_Rolllaeden = null
