OpenHab 4.0.0 Zwave Unknown device
Since upgrading to OpenHab4, I have one Z-Wave node that is now unknown. I have excluded, powered down, powered up and reincluded the node with no improvement. I can control the node from the Z-Wave PC Controller software when the stick is plugged into my windows PC. This specific device was and still appears to be included in the database (Jasco ZW1002 wall outlet). One oddity, the manufacturerID is not listed in the thing properties, but is included in the XML. Any ideas or pointers are appreciated!
<node>
  <homeId>0xfce64694</homeId>
  <nodeId>49</nodeId>
  <version>4</version>
  <manufacturer>0x63</manufacturer>
  <deviceId>0x3234</deviceId>
  <deviceType>0x4952</deviceType>
  <listening>true</listening>
  <frequentlyListening>false</frequentlyListening>
  <routing>true</routing>
  <security>false</security>
  <beaming>true</beaming>
  <maxBaudRate>40000</maxBaudRate>
  <sleepDelay>500</sleepDelay>
  <nodeInformationFrame>
    <commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
    <commandClass>COMMAND_CLASS_SWITCH_BINARY</commandClass>
    <commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
    <commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
    <commandClass>COMMAND_CLASS_VERSION</commandClass>
    <commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
    <commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
    <commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
    <commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
    <commandClass>COMMAND_CLASS_CENTRAL_SCENE</commandClass>
    <commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
    <commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
    <commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
    <commandClass>COMMAND_CLASS_SCENE_ACTUATOR_CONF</commandClass>
    <commandClass>COMMAND_CLASS_SCENE_ACTIVATION</commandClass>
    <commandClass>COMMAND_CLASS_APPLICATION_STATUS</commandClass>
    <commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
  </nodeInformationFrame>
  <associationGroups class="concurrent-hash-map">
    <entry>
      <int>1</int>
      <associationGroup>
        <index>1</index>
        <maxNodes>0</maxNodes>
        <name>Lifeline</name>
        <profile1>0x0</profile1>
        <profile2>0x1</profile2>
        <commands>
        </commands>
        <associations>
          <associationMember>
            <node>1</node>
          </associationMember>
        </associations>
      </associationGroup>
    </entry>
    <entry>
      <int>2</int>
      <associationGroup>
        <index>2</index>
        <name>Group2 On/Off/Dim control</name>
        <profile1>0x20</profile1>
        <commands>
          <commandClass>COMMAND_CLASS_BASIC</commandClass>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
    <entry>
      <int>3</int>
      <associationGroup>
        <index>3</index>
        <name>Group3 On/Off/Dim control</name>
        <profile2>0x2</profile2>
        <commands>
        </commands>
        <associations/>
      </associationGroup>
    </entry>
  </associationGroups>
  <endpoints class="concurrent-hash-map">
    <entry>
      <int>0</int>
      <endPoint>
        <deviceClass>
          <basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
          <genericDeviceClass>GENERIC_TYPE_SWITCH_BINARY</genericDeviceClass>
          <specificDeviceClass>SPECIFIC_TYPE_POWER_SWITCH_BINARY</specificDeviceClass>
        </deviceClass>
        <endpointId>0</endpointId>
        <secureCommandClasses/>
        <supportedCommandClasses class="concurrent-hash-map">
          <entry>
            <commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
            <COMMAND__CLASS__NO__OPERATION>
              <version>1</version>
              <instances>1</instances>
              <control>false</control>
              <versionSupported>1</versionSupported>
            </COMMAND__CLASS__NO__OPERATION>
          </entry>
          <entry>
            <COMMAND__CLASS__BASIC>
              <versionSupported>2</versionSupported>
              <isGetSupported>true</isGetSupported>
            </COMMAND__CLASS__BASIC>
          </entry>
          <entry>
            <COMMAND__CLASS__APPLICATION__STATUS>
            </COMMAND__CLASS__APPLICATION__STATUS>
          </entry>
          <entry>
            <COMMAND__CLASS__SWITCH__BINARY>
            </COMMAND__CLASS__SWITCH__BINARY>
          </entry>
          <entry>
            <COMMAND__CLASS__SCENE__ACTIVATION>
            </COMMAND__CLASS__SCENE__ACTIVATION>
          </entry>
          <entry>
            <COMMAND__CLASS__SCENE__ACTUATOR__CONF>
            </COMMAND__CLASS__SCENE__ACTUATOR__CONF>
          </entry>
          <entry>
            <COMMAND__CLASS__ASSOCIATION__GRP__INFO>
              <autoSubscribeGroups>
                <int>1</int>
              </autoSubscribeGroups>
            </COMMAND__CLASS__ASSOCIATION__GRP__INFO>
          </entry>
          <entry>
            <COMMAND__CLASS__DEVICE__RESET__LOCALLY>
            </COMMAND__CLASS__DEVICE__RESET__LOCALLY>
          </entry>
          <entry>
            <COMMAND__CLASS__CENTRAL__SCENE>
              <version>3</version>
              <versionSupported>3</versionSupported>
              <sceneCount>1</sceneCount>
            </COMMAND__CLASS__CENTRAL__SCENE>
          </entry>
          <entry>
            <COMMAND__CLASS__ZWAVEPLUS__INFO>
              <zwPlusVersion>1</zwPlusVersion>
              <zwPlusRole>ROLE_TYPE_SLAVE_ALWAYS_ON</zwPlusRole>
              <zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
            </COMMAND__CLASS__ZWAVEPLUS__INFO>
          </entry>
          <entry>
            <COMMAND__CLASS__CONFIGURATION>
              <versionSupported>4</versionSupported>
              <configParameters/>
            </COMMAND__CLASS__CONFIGURATION>
          </entry>
          <entry>
            <COMMAND__CLASS__MANUFACTURER__SPECIFIC>
              <initSerialNumber>false</initSerialNumber>
              <deviceManufacturer>99</deviceManufacturer>
              <deviceType>18770</deviceType>
              <deviceId>12852</deviceId>
            </COMMAND__CLASS__MANUFACTURER__SPECIFIC>
          </entry>
          <entry>
            <COMMAND__CLASS__POWERLEVEL>
              <powerLevel>0</powerLevel>
              <powerTimeout>0</powerTimeout>
            </COMMAND__CLASS__POWERLEVEL>
          </entry>
          <entry>
            <COMMAND__CLASS__FIRMWARE__UPDATE__MD>
            </COMMAND__CLASS__FIRMWARE__UPDATE__MD>
          </entry>
          <entry>
            <COMMAND__CLASS__ASSOCIATION>
              <version>2</version>
              <maxGroups>3</maxGroups>
            </COMMAND__CLASS__ASSOCIATION>
          </entry>
          <entry>
            <COMMAND__CLASS__VERSION>
              <libraryType>LIB_SLAVE_ENHANCED</libraryType>
              <protocolVersion>6.8</protocolVersion>
              <applicationVersion>5.51</applicationVersion>
              <hardwareVersion>255</hardwareVersion>
            </COMMAND__CLASS__VERSION>
          </entry>
        </supportedCommandClasses>
      </endPoint>
    </entry>
  </endpoints>
  <nodeNeighbors>
    <int>1</int>
    <int>5</int>
    <int>8</int>
    <int>9</int>
    <int>13</int>
    <int>14</int>
    <int>15</int>
    <int>16</int>
    <int>17</int>
    <int>37</int>
    <int>40</int>
    <int>44</int>
  </nodeNeighbors>
  <lastReceived>2023-04-10 18:43:11.279 UTC</lastReceived>
</node>
I suspect the issue is the 5.51 version. There are two entries for ZW1002 One is for set for <5.5. the other >5.51 The problem is 4952:3234 are on the <5.5 version, not the >5.51. Apparently they need to be added to the 5.51 version. Not sure how it worked before.
