Hi all,
i have installed the new version 4.0.1 and since this it is filling up the event.log with the following entries
023-08-03 19:16:17.420 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam1_MotionAlarm' updated to OFF
2023-08-03 19:16:17.540 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam2_MotionAlarm' updated to OFF
2023-08-03 19:16:17.541 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam2_MotionAlarm' updated to OFF
2023-08-03 19:16:17.730 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam1_MotionAlarm' updated to OFF
2023-08-03 19:16:17.731 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam1_MotionAlarm' updated to OFF
2023-08-03 19:16:17.849 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam2_MotionAlarm' updated to OFF
2023-08-03 19:16:17.850 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam2_MotionAlarm' updated to OFF
2023-08-03 19:16:17.851 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam2_MotionAlarm' updated to OFF
2023-08-03 19:16:18.039 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam1_MotionAlarm' updated to OFF
2023-08-03 19:16:18.040 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam1_MotionAlarm' updated to OFF
2023-08-03 19:16:18.158 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'HikvisionCam2_MotionAlarm' updated to OFF
This behavior was not existing before upgrade with older versions. Does anyone know if i have to change the config that the updates are no more logged?
This makes that it is filling all eventlog and all 7 gz instances of former event.logs in halve a day.
Can someone help me to disable the update-logs and only the changes?
Best regards
Andreas
