Platform information:
Hardware: Raspberry Pi 4 / 2GB ram / 32GB USB Key (Sandisk)
OS: Debian 11
Java Runtime Environment: openjdk version “17.0.7” 2023-04-18 (build 17.0.7+7-Raspbian-1deb11u1rpt1)
openHAB version: 4.0.1
Issue of the topic: OpenHAB not serving a webpage locally and disconected from cloud.
It stops running rules. It does not repair itself.
I upgraded from OH3, it started dropping the connection to the cloud, a month ago, like every day. OH3 never locked up locally, it worked for a year before, needieng a restart maybe monthly to recover cloud conection. I still have a backup of OH3, but OH3 seemed to also data hog on my 4G data plan ocasionally.
I upgraded to OH4, and it worked for few days, but whenewer i update config or change menues on sitemap too fast it locks up. After restart it works fine for a day again.
There may be more issues compounded.
I understand that i shoould have less erors in my config, but some are tricky to fix. Like even tho i removed jsonpath filters in items errors persist.
Main portion of erors are from rules being trigered in time without condition that devices are connected, but they recover when connected, i fix those when i have time, but i have a lot of devices and lots of rules.
Some errors are form me having old mqtt binding config, but it is working fine.
No mather what errors i have the openhab should handle them like it did in OH2 and OH3 times.
I have OH2 at other place, runing fine for months, even tho my config has some errors it handles them properly. It reconects to cloud fine, i only have it on a befier HP machine i5 with 8G ram and SSD.
I use OH for 4 years now and we become dependant on it to monitor remote location, now it is causing more trouble than ever before.
I added some more devices this summer but it cant be an issue if they work fine on OH while OH is working.
Can it be that USB key having bad sectors, tho OS is stable, key i 1 year old.
I always fix erors that cause functionality issues interfacing my devices, but how can i find erors that cause openhab core to crash.
I am quite disapointed with error handling, i just want it to work reasonably like i know it can, not that i need to fix it constantly, and restart and hope i dont crash it while using sitemap.
Please help me decide what to do and how to fix this craching issue.
Here i will provide logs from Linux service and openhab.log. Other things, items, rules and sitemap are quite big, i will provide them later , if needed.
I see that java VM is running out of RAM and such but i dont understand the reason, as the errors are not consistent.
Cheers
Matej
org.ops4j.pax.logging.pax-logging-api [log4j2] ERROR : An exception occurred processing Appender OSGI
Aug 08 16:05:03 pi3-dule karaf[565]: Exception in thread "JmDNS(192-168-1-100.local.).State.Timer" io.reactivex.exceptions.UndeliverableException: The exception could not be delivered to t>
Aug 08 16:05:03 pi3-dule karaf[565]: at io.reactivex.plugins.RxJavaPlugins.onError(RxJavaPlugins.java:367)
Aug 08 16:05:03 pi3-dule karaf[565]: at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:69)
Aug 08 16:05:03 pi3-dule karaf[565]: at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57)
Aug 08 16:05:03 pi3-dule karaf[565]: at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
Aug 08 16:05:03 pi3-dule karaf[565]: at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
Aug 08 16:05:03 pi3-dule karaf[565]: at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136)
Aug 08 16:05:03 pi3-dule karaf[565]: at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635)
Aug 08 16:05:03 pi3-dule karaf[565]: at java.base/java.lang.Thread.run(Thread.java:833)
Aug 12 21:17:14 pi3-dule karaf[572]: java.lang.OutOfMemoryError: Java heap space
Aug 12 21:18:59 pi3-dule karaf[572]: io.reactivex.exceptions.UndeliverableException: The exception could not be delivered to >
Aug 12 21:20:07 pi3-dule karaf[572]: at io.reactivex.plugins.RxJavaPlugins.onError(RxJavaPlugins.java:367)
Aug 12 21:20:29 pi3-dule karaf[572]: at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java>
Aug 12 21:20:29 pi3-dule karaf[572]: at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.jav>
Aug 12 21:20:31 pi3-dule karaf[572]: at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
Aug 12 21:20:54 pi3-dule karaf[572]: Exception in thread "JmDNS(192-168-1-100.local.).State.Timer" at java.base/java.>
Aug 12 21:20:54 pi3-dule karaf[572]: at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecuto>
Aug 12 21:20:54 pi3-dule karaf[572]: at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecut>
Aug 12 21:20:54 pi3-dule karaf[572]: at java.base/java.lang.Thread.run(Thread.java:833)
2023-08-12 21:26:43.045 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.0.1 (build Release Build)
2023-08-12 21:26:43.767 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Budapest'.
2023-08-12 21:26:43.787 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '45.76217978132109,15.115038593070082'.
2023-08-12 21:26:43.790 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'sl_SI'.
2023-08-12 21:26:46.073 [WARN ] [g.dispatch.internal.ConfigDispatcher] - The file /etc/openhab/services/mqtt.cfg subsequently defines the exclusive PID 'org.openhab.mqtt'. Overriding existing configuration now.
2023-08-12 21:26:49.965 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'HiGrow_Rastlinjak_1.items'
2023-08-12 21:26:50.519 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'CisterneDule.items'
2023-08-12 21:26:50.697 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Sirena_Dule.items'
2023-08-12 21:26:50.767 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Ogrevanje_Vtic_10.items'
2023-08-12 21:26:50.816 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VticR3.items'
2023-08-12 21:26:50.911 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Varnost_Dule2.items'
2023-08-12 21:26:51.014 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Vodnjak.items'
2023-08-12 21:26:51.104 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MeritveTemperatur.items'
2023-08-12 21:26:51.124 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VrtDule.items'
2023-08-12 21:26:51.145 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'TelekomInternet.items'
2023-08-12 21:26:51.173 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'HiGrow_Rastlinjak_2.items'
2023-08-12 21:26:51.241 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MerilnikToka.items'
2023-08-12 21:26:51.274 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'S1_Sonoff4_Dule.items'
2023-08-12 21:26:51.292 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Zalivanje_Ventili2.items'
2023-08-12 21:26:51.364 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'KrmiljeLucVE_TermostatZG.items'
2023-08-12 21:26:51.448 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Solarni_Krmilnik_GH.items'
2023-08-12 21:26:51.551 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'CisterneDule_3TE.items'
2023-08-12 21:26:51.601 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Sistem ( Raspberry_Pi ).items'
2023-08-12 21:26:51.656 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VticR2.items'
2023-08-12 21:26:51.724 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Luci.items'
2023-08-12 21:26:51.773 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Ura.items'
2023-08-12 21:26:51.789 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Zalivanje_Vtic4.items'
2023-08-12 21:26:51.840 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VticAthom1.items'
2023-08-12 21:26:52.244 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2023-08-12 21:26:52.749 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dule.sitemap'
2023-08-12 21:26:53.310 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MQTT.things'
2023-08-12 21:26:53.385 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'MQTT.things', using it anyway:
Provide a thing type ID and a thing ID in this format:
<thingTypeId> <thingId>
2023-08-12 21:26:59.354 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2023-08-12 21:26:59.667 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'MerilnikToka_Pretvori.rules'
2023-08-12 21:27:02.385 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VarnostDule2.rules'
2023-08-12 21:27:04.853 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Sirena_Dule.rules'
2023-08-12 21:27:06.001 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'CisterneDule.rules'
2023-08-12 21:27:11.721 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Izklopi_VelikTok.rules'
2023-08-12 21:27:13.208 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'HiGrow_Rastlinjak_2.rules'
2023-08-12 21:27:15.328 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Prisotnost.rules'
2023-08-12 21:27:16.818 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Ura.rules'
2023-08-12 21:27:17.236 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Ura.rules', using it anyway:
The value of the local variable Sekunde_ is not used
2023-08-12 21:27:17.246 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VticR3_Hidrofor.rules'
2023-08-12 21:27:19.447 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Zalivanje.rules'
2023-08-12 21:27:20.657 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'HiGrow_Rastlinjak_1.rules'
2023-08-12 21:27:22.823 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Vodnjak.rules'
2023-08-12 21:27:25.329 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'TelekomDule.rules'
2023-08-12 21:27:26.563 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Ogrevanje_Vtic_10.rules'
2023-08-12 21:27:27.950 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model 'Ogrevanje_Vtic_10.rules', using it anyway:
The value of the local variable St4 is not used
2023-08-12 21:27:27.971 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Zalivanje_Ventili.rules'
2023-08-12 21:27:28.605 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'CisterneDule_3TE.rules'
2023-08-12 21:27:30.386 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'KrmiljeLucVE_TermostatZG.rules'
2023-08-12 21:27:32.893 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Solarni_Krmilnik_GH.rules'
2023-08-12 21:27:37.131 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Obvestila_Ogrevanja_VT10.rules'
2023-08-12 21:27:39.037 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VticR2_Pomivalec.rules'
2023-08-12 21:27:41.396 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'VticAthom1.rules'
2023-08-12 21:27:43.793 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'Luci.rules'
2023-08-12 21:27:48.203 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = d8...4b, base URL = http://localhost:8080)
2023-08-12 21:27:48.307 [INFO ] [ab.ui.habpanel.internal.HABPanelTile] - Started HABPanel at /habpanel
2023-08-12 21:27:48.753 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'localhost' with clientid 3b56bc9b-5d68-408e-b888-88e9d2c55edb
2023-08-12 21:27:51.839 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'localhost' with clientid 127ffefd-ec39-4b53-a78e-e3d937c23007
2023-08-12 21:27:52.828 [WARN ] [o.internal.handler.SysteminfoHandler] - No information for channel display#information with device index: 0
2023-08-12 21:27:55.619 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:04.847 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2023-08-12 21:28:06.599 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:10.623 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:10.626 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:28:10.628 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:28:10.630 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:28:17.592 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:24.433 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 269, column 46, length 47 in CisterneDule
2023-08-12 21:28:24.436 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 269, column 46, length 47 in CisterneDule
2023-08-12 21:28:24.440 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 253, column 54, length 47 in CisterneDule
2023-08-12 21:28:24.444 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 253, column 54, length 47 in CisterneDule
2023-08-12 21:28:28.587 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:31.329 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:31.331 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:28:31.332 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:28:31.333 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:28:34.390 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:28:34.394 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:28:34.459 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 269, column 46, length 47 in CisterneDule
2023-08-12 21:28:34.469 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 253, column 54, length 47 in CisterneDule
2023-08-12 21:28:34.596 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Irms' cannot be resolved to an item or type; line 35, column 9, length 17 in MerilnikToka_Pretvori
2023-08-12 21:28:34.626 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 50, length 45 in CisterneDule
2023-08-12 21:28:34.666 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:34.669 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:28:34.670 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:28:34.679 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:28:34.697 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.752 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.755 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.785 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.788 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.791 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.794 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.795 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 50, length 45 in CisterneDule
2023-08-12 21:28:34.797 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.912 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 50, length 45 in CisterneDule
2023-08-12 21:28:34.939 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.942 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:34.945 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:35.009 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Sistem' cannot be resolved to an item or type; line 10, column 29, length 19 in MerilnikToka_Pretvori
2023-08-12 21:28:35.011 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.014 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.044 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.047 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.072 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.075 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.077 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.141 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.143 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.145 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.148 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.182 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.185 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.187 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.335 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.359 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:35.362 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'MerilnikToka_Pretvori-1' failed: The name 'MerilnikToka_Meritve' cannot be resolved to an item or type; line 9, column 26, length 20 in MerilnikToka_Pretvori
2023-08-12 21:28:38.620 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:40.279 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 270, column 7, length 47 in CisterneDule
2023-08-12 21:28:40.290 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:28:40.295 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Solarni_Krmilnik_GH-6' failed: Could not cast NULL to java.lang.Number; line 170, column 56, length 60 in Solarni_Krmilnik_GH
2023-08-12 21:28:40.326 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:28:40.399 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'Varovanje_Gib_VE' cannot be resolved to an item or type; line 29, column 5, length 16 in VarnostDule2
2023-08-12 21:28:40.433 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.436 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.459 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.461 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.492 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.500 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.520 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.533 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.556 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.570 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.588 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.605 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 255, column 54, length 47 in CisterneDule
2023-08-12 21:28:40.605 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.606 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 270, column 7, length 47 in CisterneDule
2023-08-12 21:28:40.613 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.630 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.646 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.652 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 50, length 45 in CisterneDule
2023-08-12 21:28:40.696 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.709 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.739 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.797 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.809 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.822 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.841 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.843 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.848 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.851 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.860 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.862 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.864 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.876 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.886 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:40.933 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'VarnostDule2-1' failed: The name 'VarovanjeStatus' cannot be resolved to an item or type; line 9, column 29, length 15 in VarnostDule2
2023-08-12 21:28:41.443 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.450 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve_Timer_Sirene' cannot be resolved to an item or type; line 29, column 4, length 32 in Sirena_Dule
2023-08-12 21:28:41.466 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.480 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.493 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.513 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.541 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.553 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve_VklopSirene' cannot be resolved to an item or type; line 26, column 4, length 31 in Sirena_Dule
2023-08-12 21:28:41.590 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.607 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.616 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.640 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem_ST0' cannot be resolved to an item or type; line 50, column 4, length 22 in Sirena_Dule
2023-08-12 21:28:41.650 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem' cannot be resolved to an item or type; line 43, column 25, length 18 in Sirena_Dule
2023-08-12 21:28:41.652 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve_ST0' cannot be resolved to an item or type; line 17, column 4, length 23 in Sirena_Dule
2023-08-12 21:28:41.662 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-2' failed: The name 'Sirena_Dule_Sistem' cannot be resolved to an item or type; line 43, column 25, length 18 in Sirena_Dule
2023-08-12 21:28:41.720 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve_ST0' cannot be resolved to an item or type; line 17, column 4, length 23 in Sirena_Dule
2023-08-12 21:28:41.736 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.751 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.792 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.803 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.811 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.818 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.826 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.828 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.831 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:41.833 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Sirena_Dule-1' failed: The name 'Sirena_Dule_Meritve' cannot be resolved to an item or type; line 6, column 25, length 19 in Sirena_Dule
2023-08-12 21:28:42.051 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:42.052 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:28:42.054 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:28:42.055 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:28:45.030 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-2' failed: The name 'CisterneZgoraj_Meritve' cannot be resolved to an item or type; line 46, column 26, length 22 in CisterneDule
2023-08-12 21:28:45.030 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-1' failed: The name 'CisterneSpodaj_Meritve' cannot be resolved to an item or type; line 12, column 26, length 22 in CisterneDule
2023-08-12 21:28:45.033 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-2' failed: The name 'CisterneZgoraj_Meritve' cannot be resolved to an item or type; line 46, column 26, length 22 in CisterneDule
2023-08-12 21:28:46.279 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-1' failed: The name 'CisterneSpodaj_Meritve' cannot be resolved to an item or type; line 12, column 26, length 22 in CisterneDule
2023-08-12 21:28:46.582 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-1' failed: The name 'CisterneSpodaj_Meritve' cannot be resolved to an item or type; line 12, column 26, length 22 in CisterneDule
2023-08-12 21:28:46.582 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-2' failed: The name 'CisterneZgoraj_Meritve' cannot be resolved to an item or type; line 46, column 26, length 22 in CisterneDule
2023-08-12 21:28:47.124 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Izklopi_VelikTok-1' failed: The name 'MerilnikToka_Irms' cannot be resolved to an item or type; line 8, column 41, length 17 in Izklopi_VelikTok
2023-08-12 21:28:47.124 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Izklopi_VelikTok-2' failed: The name 'MerilnikToka_Irms' cannot be resolved to an item or type; line 34, column 43, length 17 in Izklopi_VelikTok
2023-08-12 21:28:47.126 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Izklopi_VelikTok-3' failed: The name 'MerilnikToka_Irms' cannot be resolved to an item or type; line 61, column 42, length 17 in Izklopi_VelikTok
2023-08-12 21:28:49.705 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:56.792 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 270, column 7, length 47 in CisterneDule
2023-08-12 21:28:56.806 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 98, length 45 in CisterneDule
2023-08-12 21:28:56.808 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 255, column 54, length 47 in CisterneDule
2023-08-12 21:28:56.853 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Cas_Ure_Minute' cannot be resolved to an item or type; line 15, column 7, length 14 in Ura
2023-08-12 21:28:56.856 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.858 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.868 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.907 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.912 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.914 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.916 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.918 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.947 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Ura-1' failed: The name 'Sedaj' cannot be resolved to an item or type; line 5, column 5, length 5 in Ura
2023-08-12 21:28:56.995 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:28:56.996 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:28:56.997 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:28:57.001 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:28:57.796 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_Ventil2_Tmr2_Changed' cannot be resolved to an item or type; line 26, column 5, length 30 in Zalivanje
2023-08-12 21:28:57.823 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:28:57.830 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:28:57.839 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:28:57.851 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:28:57.857 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:28:57.862 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: An error occurred during the script execution: Feature was null in Zalivanje
2023-08-12 21:28:57.865 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:28:57.875 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Zalivanje-2' failed: The name 'Zalivnaje_VT4_Power_Changed' cannot be resolved to an item or type; line 24, column 5, length 27 in Zalivanje
2023-08-12 21:29:00.645 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:01.319 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 270, column 7, length 47 in CisterneDule
2023-08-12 21:29:01.320 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 255, column 54, length 47 in CisterneDule
2023-08-12 21:29:01.321 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-6' failed: Could not cast NULL to java.lang.Number; line 183, column 29, length 45 in CisterneDule
2023-08-12 21:29:01.404 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:01.406 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:29:01.407 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:29:01.409 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:29:05.212 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: The name 'HiGrow_Rastlinjak_1_Sistem' cannot be resolved to an item or type; line 61, column 25, length 26 in HiGrow_Rastlinjak_1
2023-08-12 21:29:05.212 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: The name 'HiGrow_Rastlinjak_1_Meritve' cannot be resolved to an item or type; line 6, column 25, length 27 in HiGrow_Rastlinjak_1
2023-08-12 21:29:05.385 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 98, length 45 in CisterneDule
2023-08-12 21:29:05.618 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Vodnjak-1' failed: The name 'Vodnjak_VolumenVode_Num' cannot be resolved to an item or type; line 39, column 33, length 23 in Vodnjak
2023-08-12 21:29:05.621 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Vodnjak-1' failed: The name 'Float' cannot be resolved to an item or type; line 11, column 46, length 5 in Vodnjak
2023-08-12 21:29:05.622 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Vodnjak-1' failed: The name 'Float' cannot be resolved to an item or type; line 11, column 46, length 5 in Vodnjak
2023-08-12 21:29:05.624 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Vodnjak-1' failed: The name 'Float' cannot be resolved to an item or type; line 11, column 46, length 5 in Vodnjak
2023-08-12 21:29:05.626 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Vodnjak-1' failed: The name 'Float' cannot be resolved to an item or type; line 11, column 46, length 5 in Vodnjak
2023-08-12 21:29:05.689 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'Vodnjak-1' failed: The name 'Float' cannot be resolved to an item or type; line 11, column 46, length 5 in Vodnjak
2023-08-12 21:29:06.574 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-10' failed: Could not cast NULL to java.lang.Number; line 285, column 30, length 39 in CisterneDule
2023-08-12 21:29:09.721 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule_3TE-5' failed: The name 'CisterneDule_3TE_SilomerPlovca_Teza_Grami' cannot be resolved to an item or type; line 114, column 28, length 41 in CisterneDule_3TE
2023-08-12 21:29:11.689 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:15.543 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-9' failed: Could not cast NULL to java.lang.Number; line 256, column 58, length 49 in CisterneDule
2023-08-12 21:29:15.561 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-1' failed: The name 'KrmilnikLucVE_Cas_MQTT' cannot be resolved to an item or type; line 20, column 5, length 22 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.563 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-1' failed: The name 'KrmilnikLucVE_Status' cannot be resolved to an item or type; line 5, column 29, length 20 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.565 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-1' failed: The name 'KrmilnikLucVE_Status' cannot be resolved to an item or type; line 5, column 29, length 20 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.581 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-3' failed: The name 'KrmilnikLucVE_T_Zrak' cannot be resolved to an item or type; line 86, column 5, length 20 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.598 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-3' failed: The name 'KrmilnikLucVE_TermostatZGVT10' cannot be resolved to an item or type; line 71, column 29, length 29 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.613 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-2' failed: The name 'KrmilnikLucVE_TimerIzklopa' cannot be resolved to an item or type; line 48, column 5, length 26 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.630 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'CisterneDule-8' failed: Could not cast NULL to java.lang.Number; line 242, column 98, length 45 in CisterneDule
2023-08-12 21:29:15.634 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-2' failed: The name 'KrmilnikLucVE_KrmiljeLucVE' cannot be resolved to an item or type; line 28, column 29, length 26 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.636 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-2' failed: The name 'KrmilnikLucVE_KrmiljeLucVE' cannot be resolved to an item or type; line 28, column 29, length 26 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.647 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'KrmiljeLucVE_TermostatZG-3' failed: The name 'KrmilnikLucVE_TermostatZGVT10' cannot be resolved to an item or type; line 71, column 29, length 29 in KrmiljeLucVE_TermostatZG
2023-08-12 21:29:15.699 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:15.700 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:29:15.701 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:29:15.702 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:29:23.304 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:32.353 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:32.355 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:29:32.356 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:29:32.357 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:29:32.403 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:32.405 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:29:32.407 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:29:33.567 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:29:33.602 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:44.703 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:29:54.731 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:06.466 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:16.926 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:27.615 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:29.739 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.742 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.744 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.747 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.755 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.767 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.770 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.773 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:29.776 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'TelekomDule-1' failed: Index 2 out of bounds for length 1 in TelekomDule
2023-08-12 21:30:31.445 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:33.847 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:33.851 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:33.859 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:30:33.878 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:33.893 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:33.909 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:33.919 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:30:33.937 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:33.943 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:35.550 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:37.551 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:30:37.562 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:37.570 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:37.571 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:39.129 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:30:39.294 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:39.296 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:39.298 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:39.335 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:30:39.352 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:41.223 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:41.229 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:30:42.913 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:42.914 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:42.915 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:42.916 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:30:50.065 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:53.842 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:30:53.844 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:30:53.845 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:30:53.846 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:31:00.910 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:31:01.159 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:31:02.976 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:31:10.629 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:31:21.651 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:31:21.770 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:31:21.779 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:31:32.605 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:31:37.870 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dule.sitemap'
2023-08-12 21:31:41.674 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:31:41.697 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:31:43.570 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:31:54.372 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:01.620 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:32:01.627 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:32:04.993 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:14.170 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:14.173 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:32:15.958 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:32:16.180 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:32:16.192 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:16.210 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:32:17.696 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:32:17.701 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:32:17.707 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:21.180 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:32:21.205 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:32:23.323 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:23.328 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T3' and format '%s'
2023-08-12 21:32:23.330 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T2' and format '%s'
2023-08-12 21:32:23.336 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"POWER":"OFF"}' with function '$.T1' and format '%s'
2023-08-12 21:32:26.682 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:37.628 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:32:40.958 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:32:40.994 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:32:49.515 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:33:00.358 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:33:00.562 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:33:00.571 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:33:10.765 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dule.sitemap'
2023-08-12 21:33:10.859 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:33:20.902 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:33:20.924 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:33:22.534 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:33:32.514 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:33:40.581 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:33:40.585 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:33:48.684 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":9,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:33:53.637 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:34:01.684 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:34:01.689 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:34:06.611 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:34:17.993 [WARN ] [ofiles.JSonPathTransformationProfile] - Could not transform state '{"T1":0,"T2":0,"T3":10,"T4":0,"T5":0,"T6":0,"T7":0,"T8":0}' with function '$.Timer1.Time' and format '%s'
2023-08-12 21:34:21.005 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:34:21.008 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:34:44.736 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:34:46.287 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:34:58.725 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.thing.internal.CommunicationManager@17fee8' takes more than 5000ms.
2023-08-12 21:35:03.619 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'TelekomDule-1' failed: Index 2 out of bounds for length 1 in TelekomDule
2023-08-12 21:35:05.169 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:35:08.549 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:35:21.091 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.thing.internal.CommunicationManager@17fee8' takes more than 5000ms.
2023-08-12 21:35:25.610 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@15f63ee' takes more than 5000ms.
2023-08-12 21:35:27.127 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:35:27.141 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:35:38.008 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.thing.internal.CommunicationManager@17fee8' takes more than 5000ms.
2023-08-12 21:35:48.469 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:35:56.284 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@15f63ee' takes more than 5000ms.
2023-08-12 21:35:56.287 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.thing.internal.CommunicationManager@17fee8' takes more than 5000ms.
2023-08-12 21:36:16.282 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@15f63ee' takes more than 5000ms.
2023-08-12 21:36:20.745 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:36:47.984 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:36:52.745 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:36:54.246 [WARN ] [io.openhabcloud.internal.CloudClient] - Socket.IO disconnected: ping timeout
2023-08-12 21:36:54.247 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = d8...4b, base URL = http://localhost:8080)
2023-08-12 21:37:02.096 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.thing.internal.CommunicationManager@17fee8' takes more than 5000ms.
2023-08-12 21:37:02.098 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:37:08.112 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:37:22.009 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-2' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:37:22.011 [ERROR] [internal.handler.ScriptActionHandler] - Script execution of rule with UID 'HiGrow_Rastlinjak_1-1' failed: Index 1 out of bounds for length 1 in HiGrow_Rastlinjak_1
2023-08-12 21:37:37.370 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@15f63ee' takes more than 5000ms.
2023-08-12 21:37:46.208 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.thing.internal.CommunicationManager@17fee8' takes more than 5000ms.
