After switching to 4.0 my /automation/js/ scripts are not working
Version: 4.0.0 (Build)
java: openjdk version “17.0.7” 2023-04-18
even if i created a simple empty script it’s still not working ;(
2023-09-06 16:27:49.340 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script '/etc/openhab/automation/js/cleanup.js': null
2023-09-06 16:27:49.341 [WARN ] [ort.loader.AbstractScriptFileWatcher] - Script loading error, ignoring file '/etc/openhab/automation/js/cleanup.js'
2023-09-06 16:27:49.343 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/ItemCreator V2.js'
2023-09-06 16:27:49.372 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: java.lang.NoClassDefFoundError: Could not initialize class com.oracle.truffle.regex.RegexObjectGen
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Class.java:467) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory$ResolvedDispatch.loadGeneratedClass(LibraryFactory.java:987) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory$ResolvedDispatch.resolveClass(LibraryFactory.java:963) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory$ResolvedDispatch.lookup(LibraryFactory.java:905) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory.lookupExport(LibraryFactory.java:689) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory.getUncachedSlowPath(LibraryFactory.java:410) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory.getUncached(LibraryFactory.java:402) ~[?:?]
at com.oracle.truffle.api.library.DynamicDispatchLibraryGen$UncachedDispatch.dispatch(DynamicDispatchLibraryGen.java:297) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory.dispatch(LibraryFactory.java:541) ~[?:?]
at com.oracle.truffle.api.library.LibraryFactory.getUncached(LibraryFactory.java:396) ~[?:?]
at com.oracle.truffle.api.interop.InteropLibraryGen$UncachedDispatch.isNull(InteropLibraryGen.java:6683) ~[?:?]
at com.oracle.truffle.js.runtime.RegexCompilerInterface.compile(RegexCompilerInterface.java:65) ~[?:?]
at com.oracle.truffle.js.nodes.access.RegExpLiteralNode.execute(RegExpLiteralNode.java:83) ~[?:?]
at com.oracle.truffle.js.nodes.function.JSFunctionCallNode$InvokeNNode.executeFillObjectArray(JSFunctionCallNode.java:885) ~[?:?]
at com.oracle.truffle.js.nodes.function.JSFunctionCallNode$InvokeNNode.createArguments(JSFunctionCallNode.java:878) ~[?:?]
at com.oracle.truffle.js.nodes.function.JSFunctionCallNode$InvokeNode.execute(JSFunctionCallNode.java:732) ~[?:?]
at com.oracle.truffle.js.nodes.binary.JSAddNodeGen.execute_generic4(JSAddNodeGen.java:396) ~[?:?]
at com.oracle.truffle.js.nodes.binary.JSAddNodeGen.execute(JSAddNodeGen.java:223) ~[?:?]
at com.oracle.truffle.js.nodes.control.IfNode.execute(IfNode.java:161) ~[?:?]
at com.oracle.truffle.js.nodes.access.JSWriteScopeFrameSlotNodeGen.execute_generic4(JSWriteScopeFrameSlotNodeGen.java:166) ~[?:?]
at com.oracle.truffle.js.nodes.access.JSWriteScopeFrameSlotNodeGen.execute(JSWriteScopeFrameSlotNodeGen.java:89) ~[?:?]
at com.oracle.truffle.js.nodes.access.JSWriteScopeFrameSlotNodeGen.executeVoid(JSWriteScopeFrameSlotNodeGen.java:326) ~[?:?]
at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeVoid(AbstractBlockNode.java:80) ~[?:?]
at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeVoid(AbstractBlockNode.java:55) ~[?:?]
at com.oracle.truffle.api.impl.DefaultBlockNode.executeVoid(DefaultBlockNode.java:73) ~[?:?]
at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeVoid(AbstractBlockNode.java:70) ~[?:?]
at com.oracle.truffle.js.nodes.control.VoidBlockNode.execute(VoidBlockNode.java:61) ~[?:?]
at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeGeneric(AbstractBlockNode.java:85) ~[?:?]
at com.oracle.truffle.js.nodes.control.AbstractBlockNode.executeGeneric(AbstractBlockNode.java:55) ~[?:?]
at com.oracle.truffle.api.impl.DefaultBlockNode.executeGeneric(DefaultBlockNode.java:65) ~[?:?]
at com.oracle.truffle.js.nodes.control.AbstractBlockNode.execute(AbstractBlockNode.java:75) ~[?:?]
at com.oracle.truffle.js.nodes.function.BlockScopeNode.execute(BlockScopeNode.java:80) ~[?:?]
at com.oracle.truffle.js.nodes.function.FunctionBodyNode.execute(FunctionBodyNode.java:73) ~[?:?]
at com.oracle.truffle.js.nodes.function.FunctionRootNode.executeInRealm(FunctionRootNode.java:143) ~[?:?]
at com.oracle.truffle.js.runtime.JavaScriptRealmBoundaryRootNode.execute(JavaScriptRealmBoundaryRootNode.java:92) ~[?:?]
at <js>.:anonymous(Unknown) ~[?:?]
at <js>.:program(@jsscripting-globals.js:3) ~[?:?]
at org.graalvm.polyglot.Context.eval(Context.java:399) ~[?:?]
at org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine.beforeInvocation(OpenhabGraalJSScriptEngine.java:281) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:89) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocableAndAutocloseable.eval(DelegatingScriptEngineWithInvocableAndAutocloseable.java:58) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.eval(InvocationInterceptingScriptEngineWithInvocableAndAutoCloseable.java:90) ~[?:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.loadScript(ScriptEngineManagerImpl.java:165) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.AbstractScriptFileWatcher.createAndLoad(AbstractScriptFileWatcher.java:336) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.AbstractScriptFileWatcher.lambda$14(AbstractScriptFileWatcher.java:310) ~[?:?]
at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1804) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
2023-09-06 16:27:49.389 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script '/etc/openhab/automation/js/ItemCreator V2.js': null
2023-09-06 16:27:49.390 [WARN ] [ort.loader.AbstractScriptFileWatcher] - Script loading error, ignoring file '/etc/openhab/automation/js/ItemCreator V2.js'
2023-09-06 16:27:49.391 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/Motion.js'
2023-09-06 16:27:49.415 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
2023-09-06 16:27:49.432 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script '/etc/openhab/automation/js/Motion.js': null
2023-09-06 16:27:49.432 [WARN ] [ort.loader.AbstractScriptFileWatcher] - Script loading error, ignoring file '/etc/openhab/automation/js/Motion.js'
2023-09-06 16:27:49.434 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/etc/openhab/automation/js/rulesCreator.js'
2023-09-06 16:27:49.454 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
2023-09-06 16:27:49.471 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script '/etc/openhab/automation/js/rulesCreator.js': null
2023-09-06 16:27:49.472 [WARN ] [ort.loader.AbstractScriptFileWatcher] - Script loading error, ignoring file '/etc/openhab/automation/js/rulesCreator.js'
2023-09-06 16:27:53.842 [WARN ] [core.karaf.internal.FeatureInstaller] - The transformation add-on 'javascript' does not exist - ignoring it.
2023-09-06 16:28:50.251 [WARN ] [.server.impl.connections.HttpSession] - Unrecognized request for /accessories
