Since I migrated to OH4 M2 I am having problems with item updates (pushs) in the webui (chrome/firefox) and android/apple devices with the basic-ui.
Meaning: When I change a item on one device I do not get this pushed anymore on another device. I have to do a refresh on the device to see the changes.
With MainUI (the basic generated cards) its working fine.
I am inside kubernetes with the buildin nginx, but this was the same setup as before on OH3.
Maybe someone can help me. I can’t get the Enocean gateway to work under OH 4.0.0.M2.
Windows 10, Enocean USB300. The same settings work fine with OH 3.4.4. Port is correct.
The logfile tells me that the transceiver keeps resetting itself. Even with a completely new OH 4.0.0.M2 the same thing happens.
I moved my OpenHAB over to a new server on the weekend, and decided to roll the dice and upgrade to 4.0.0.M2 once the migration was completed. Overall I’m pretty stoked - seems to be working well so far, with only one or two very minor issues, which I need to further investigate before I post on here (may be my config rather than OH4.0).
Anyway, one thing I have noticed after a reboot tonight (hasn’t featured in any previous reboots) are the following messages:
2023-05-22 21:54:02.063 [WARN ] [core.thing.internal.ThingManagerImpl] - A thing handler factory claims to support 'systeminfo:computer-fnlctl' for thing 'systeminfo:computer:fnlctl' for more than 120s, but the thing type can't be found in the registry. This should be fixed
in the binding.
2023-05-22 21:54:02.064 [WARN ] [core.thing.internal.ThingManagerImpl] - Could not normalize configuration for 'systeminfo:computer:fnlctl' because the thing type was not found in registry.
2023-05-22 21:54:04.178 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'daikin:ac_unit:DaikinAirconRumpus' are missing in the respective registry for more than 120s. This should be fixed in the binding.
2023-05-22 21:54:04.180 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'daikin:ac_unit:DaikinAirconRumpus': {thing/channel=Type description for {0} not found although we checked the presence before.}
2023-05-22 21:54:04.188 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'daikin:ac_unit:DaikinAirconLounge' are missing in the respective registry for more than 120s. This should be fixed in the binding.
2023-05-22 21:54:04.189 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'daikin:ac_unit:DaikinAirconLounge': {thing/channel=Type description for {0} not found although we checked the presence before.}
2023-05-22 21:54:04.193 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'daikin:ac_unit:DaikinAirconBedroom1' are missing in the respective registry for more than 120s. This should be fixed in the binding.
2023-05-22 21:54:04.193 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'daikin:ac_unit:DaikinAirconBedroom1': {thing/channel=Type description for {0} not found although we checked the presence before.}
2023-05-22 21:54:04.197 [WARN ] [core.thing.internal.ThingManagerImpl] - Channel types or config descriptions for thing 'daikin:ac_unit:DaikinAirconLiving' are missing in the respective registry for more than 120s. This should be fixed in the binding.
2023-05-22 21:54:04.197 [WARN ] [core.thing.internal.ThingManagerImpl] - Failed to normalize configuration for thing 'daikin:ac_unit:DaikinAirconLiving': {thing/channel=Type description for {0} not found although we checked the presence before.}
It doesn’t seem to be affecting anything, and the binding in question, seems to have all channels present any accounted for (and works ok).
2023-05-24 16:03:15.962 [WARN ] [penhab.core.library.items.NumberItem] - Unit 'db' could not be parsed to a known unit. Keeping old unit 'one' for item 'nIndoorNoise'.
Reverting back to the original gives me values that are completely wrong (5012 db) when it should be approximately 39db.
I seem to have a problem with the “analyze” function in 4.0M3 with windows edge. Just a blank screen. Everything displays ok on iPad. (Also can’t seem to get to the Settings; Pages or Rules). Anyone else?
Edit: Chrome displays ok
Edit2: Nevermind Edge works this morning
[ERROR] [rketplace.AbstractRemoteAddonService] - Failed to read JSON database, trying to purge it. You might need to re-install [] from the 'marketplace' service.
How to solve it?
In addition also this warnings
[WARN ] [core.karaf.internal.FeatureInstaller] - The transformation add-on 'javascript' does not exist - ignoring it.
I read the release notes and know that javascript Transformation no longer exists. Is there a step to step guide how to replace it?
Is the cause of this issue the Changes in Units of Measurement (UoM)
HTTP ERROR 500 java.lang.NumberFormatException: Character N is neither a decimal digit number, decimal point, nor "e" notation exponential mark.
URI: /basicui/app
STATUS: 500
MESSAGE: java.lang.NumberFormatException: Character N is neither a decimal digit number, decimal point, nor "e" notation exponential mark.
SERVLET: /basicui/app
CAUSED BY: java.lang.NumberFormatException: Character N is neither a decimal digit number, decimal point, nor "e" notation exponential mark.
Log entry
[WARN ] [org.eclipse.jetty.server.HttpChannel] - /basicui/app
at java.math.BigDecimal.<init>(BigDecimal.java:586) ~[?:?]
at java.math.BigDecimal.<init>(BigDecimal.java:471) ~[?:?]
at java.math.BigDecimal.<init>(BigDecimal.java:900) ~[?:?]
at java.math.BigDecimal.valueOf(BigDecimal.java:1368) ~[?:?]
at tech.units.indriya.function.DefaultNumberSystem.multiplyWideAndNarrow(DefaultNumberSystem.java:773) ~[?:?]
at tech.units.indriya.function.DefaultNumberSystem.multiply(DefaultNumberSystem.java:167) ~[?:?]
at tech.units.indriya.function.DefaultNumberSystem.divide(DefaultNumberSystem.java:172) ~[?:?]
at tech.units.indriya.internal.function.Calculator.divide(Calculator.java:143) ~[?:?]
at tech.units.indriya.function.LogConverter.convertWhenNotIdentity(LogConverter.java:138) ~[?:?]
at tech.units.indriya.function.AbstractConverter$Pair.convertWhenNotIdentity(AbstractConverter.java:450) ~[?:?]
at tech.units.indriya.function.AbstractConverter.convert(AbstractConverter.java:238) ~[?:?]
at org.openhab.core.library.types.QuantityType.toUnit(QuantityType.java:270) ~[?:?]
at org.openhab.core.library.types.QuantityType.toInvertibleUnit(QuantityType.java:306) ~[?:?]
at org.openhab.core.ui.internal.items.ItemUIRegistryImpl.getLabel(ItemUIRegistryImpl.java:419) ~[?:?]
at org.openhab.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:130) ~[?:?]
at org.openhab.ui.basic.internal.render.AbstractWidgetRenderer.preprocessSnippet(AbstractWidgetRenderer.java:113) ~[?:?]
at org.openhab.ui.basic.internal.render.TextRenderer.renderWidget(TextRenderer.java:57) ~[?:?]
at org.openhab.ui.basic.internal.render.PageRenderer.renderWidget(PageRenderer.java:199) ~[?:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:165) ~[?:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processChildren(PageRenderer.java:186) ~[?:?]
at org.openhab.ui.basic.internal.render.PageRenderer.processPage(PageRenderer.java:130) ~[?:?]
at org.openhab.ui.basic.internal.servlet.WebAppServlet.service(WebAppServlet.java:170) ~[?:?]
at javax.servlet.http.HttpServlet.service(HttpServlet.java:584) ~[bundleFile:4.0.4]
at org.ops4j.pax.web.service.spi.servlet.OsgiInitializedServlet.service(OsgiInitializedServlet.java:102) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656) ~[?:?]
at org.ops4j.pax.web.service.spi.servlet.OsgiFilterChain.doFilter(OsgiFilterChain.java:100) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHandler.doHandle(PaxWebServletHandler.java:310) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) ~[?:?]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505) ~[?:?]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) ~[?:?]
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:234) ~[?:?]
at org.ops4j.pax.web.service.jetty.internal.PrioritizedHandlerCollection.handle(PrioritizedHandlerCollection.java:96) ~[?:?]
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:731) ~[?:?]
at org.eclipse.jetty.server.Server.handle(Server.java:516) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732) ~[?:?]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479) ~[?:?]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:277) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[bundleFile:9.4.50.v20221201]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[bundleFile:9.4.50.v20221201]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[bundleFile:9.4.50.v20221201]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[bundleFile:9.4.50.v20221201]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[bundleFile:9.4.50.v20221201]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[bundleFile:9.4.50.v20221201]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[bundleFile:9.4.50.v20221201]
at java.lang.Thread.run(Thread.java:833) ~[?:?]
How do I solve this? and how do I find out which item is the issue?
I have tried to upgrade to M3 on several installations (Ubuntu/Debian/dietPi), but package installation is not offering the new version.
Upgrading to a new SNAPSHOT is working
Setting source to testing (Milestone) is not offering M3. I can see a difference in package size retreived from “apt upgrade” :
Just wanted to let you know that It is still present in M3
Logging in as openhab
Failed to load native library:jansi-2.4.0-46a31a7848b558ae-libjansi.so. osinfo: Linux/arm
java.lang.UnsatisfiedLinkError: /var/lib/openhab/tmp/jansi-2.4.0-46a31a7848b558ae-libjansi.so: /var/lib/openhab/tmp/jansi-2.4.0-46a31a7848b558ae-libjansi.so: cannot open shared object file: No such file or directory
It was already reported here by few users for previous milestone build.
