Does anyone know why the SCRIPT transformation was designed to use .script? Is there a reason not to use myscript.js, myscript.rb, myscript.rules?
Yes. Because all transformations use the name of the transformation service as file extension.
Alternative option is to include this in your pom.xml, see:
I just installed build #3380 and I’m found that my logs have stopped. In fact, they stopped around 4 PM three days ago (Friday).
I had this happen to me once before and I never figured out what caused it then.
Based on exploration, org.ops4j.pax.logging.cfg somehow got replaced with an empty file. Right when the logs stopped matches the timestamp on the file.
I have no idea how this file might be getting replaced. It’s not a file that I modify myself. The last update of my instance took place on the 16th and then on the 20th. The backup from the 16th shows the file as expected and the backup from today shows the file is empty so this isn’t related to an upgrade.
Is there any circumstance where Karaf or OH may open this file for writing and fail perhaps, leaving an empty file?
Based on the timestamp on the file I’m all but certain I was not doing anything to OH at that time last Friday, so this almost has to be related to some automated process. I’m at a loss on where to look next.
At least the fix on my end is super easy.
I’d love to find out I’m not alone and someone else has seen this too.
I had this too a few days ago. Can’t recall exactly when. I am on 4.0.0M1.
This has happened to me a few times in the past.
I noticed this a few days ago too, but the logging had actually stopped in February, and I’m on 3.4.1…
!@#$, it just happened again a couple minutes ago!
All I was doing was modifying Item metadata through the UI. I wasn’t doing anything on the host, docker container, or console. This is very mysterious indeed and certainly points to a pervasive if intermittent problem.
It happened while editing metadata? That’s really strange, because logging does not depend on JSON storage.
I can’t say there is a cause and effect there. When it stopped last Friday I am pretty certain I was not editing metadata. I was working with rules earlier in the day but I’m pretty sure I was away from my computers entirely by 4:00 pm when the file was replaced.
In short, maybe there is some generic “I was changing things in the UI” cause here but I doubt even that. I’m pretty sure @hafniumzinc uses text based configs and he’s seen the behavior. Were I to guess, I’d guess it’s some upstream regression on Karaf or something. But I’ve nothing to base that on beyond a hunch.
Edit: It just happened again nine minutes ago and I was not interacting with OH at all at the time.
Edit 2: It’s happening several times a day now. There’s no pattern I can find that correlates to when it happens.
Has anyone problems with Zwave things? All are online. Some of information is updating (V and A in wall plug). Some not - switches in wall plugs and switch don’t react on changes in Basic UI and admin view, temperatures in thermostats.can’t be changed.
Just fighting with the same issue.
I just install version 4 and since then I see this problem.
I’ve updated from version 4.0.0~S3304-1 and it stopped working. I’ll try to find one and rollback, but it seems it was deleted…
Finally, I delete the bridge, create a new one and it was working again. of course I have now to rebuild the link between the things discovered with this new bridge and my items.
As a rule, before deleting a Bridge Thing take note of the Thing ID. When you recreate the Thing you have a one time option to set your own ID for the Thing. Make the new ID match the old one and all your recreated Things will have the same ID and all your Links will continue working unchanged.
My mother was saying “think before you do”.
I have a Thing for Zwave stick as a file. I’ve changed a name of the file and recreate - it doesn’t help
It might work if you remove the file completely. Verify the Things are gone in OH. Then restore the file. If not there is probably something that you have to change about your .things file.
I don’t know what else shoud I change. I’ve removed stick as a file, copied name and added from UI. Everything is online, but it still doesn’t work.
Edit:
It seems it was a hardware issue, something got locked - unplug and plug in again a stick helped.
Dear All
are there any issues concerning options items?
- component: oh-list-card
accordionList: false
title: =props.title
slots:
default:
- component: oh-label-item
icon: f7:thermometer
iconColor: '=(items[props.current_temperature_Item].state as Number > 0 && items[props.current_temperature_Item].state as Number <= 10 ) ? "purple" : (items[props.current_temperature_Item].state as Number > 10 && items[props.current_temperature_Item].state as Number <= 13 ) ? "lightblue" : (items[props.current_temperature_Item].state as Number > 13 && items[props.current_temperature_Item].state as Number <=17 ) ? "yellow" : (items[props.current_temperature_Item].state as Number > 17 && items[props.current_temperature_Item].state as Number <=20 ) ? "orange" : (items[props.current_temperature_Item].state as Number > 20 && items[props.current_temperature_Item].state as Number <=25 ) ? "red" : (items[props.current_temperature_Item].state as Number > 25 && items[props.current_temperature_Item].state as Number <=60 ) ? "purple" : "black"'
item: =[props.current_temperature_Item]
title: Temperature
- component: oh-slider-item
iconColor: '=(items[props.current_heating_setpoint_Item].state > 0 && items[props.current_heating_setpoint_Item].state <= 10 ) ? "purple" : (items[props.current_heating_setpoint_Item].state > 10 && items[props.current_heating_setpoint_Item].state <= 13 ) ? "lightblue" : (items[props.current_heating_setpoint_Item].state > 13 && items[props.current_heating_setpoint_Item].state <=17 ) ? "yellow" : (items[props.current_heating_setpoint_Item].state > 17 && items[props.current_heating_setpoint_Item].state <=20 ) ? "orange" : (items[props.current_heating_setpoint_Item].state > 20 && items[props.current_heating_setpoint_Item].state <=25 ) ? "red" : (items[props.current_heating_setpoint_Item].state > 25 && items[props.current_heating_setpoint_Item].state <=60 ) ? "purple" : "black"'
item: =[props.current_heating_setpoint_Item]
label: true
max: 30
min: 5
scale: true
step: 0.5
title: Current Heating Setpoint
unit: °C
- component: oh-list-item
action: options
actionItem: props.system_mode_Item
actionOptions: off,heat
after: =items[props.system_mode_Item].state
icon: '=(items[props.system_mode_Item].state === "heat") ? "f7:flame" : (items[props.system_mode_Item].state === "off") ? "f7:power" : "f7:exclamationmark_circle" '
iconColor: '=(items[props.system_mode_Item].state === "heat") ? "purple" : (items[props.system_mode_Item].state === "off") ? "red" : "black" '
title: System Mode
this line actionOptions: off,heat doesn’t work anymore, when clicked the options aren’t shown;
on stable version there are no issue
I try also inserting a option item manually in design mode in a new page (no widget) and it doesn’t work.
Maybe I miss some reccomanded configurations?
following the full code of the widget
uid: OH_Livio_Zigbee_TRV_Aqara
tags: []
props:
parameters:
- description: Title
label: Title
required: false
type: TEXT
- context: item
description: Item For Current Temperature
label: Item For Current Tempoerature
required: false
type: TEXT
- context: item
description: Item For Current Heating Setpoint
label: Item For Current Heating Setpoint
required: false
type: TEXT
- context: item
description: Item For System Mode
label: Item For System Mode
required: false
type: TEXT
- context: item
description: Item For Preset (Mode)
label: Item For Preset (Mode)
required: false
type: TEXT
- context: item
description: Item For Child Lock
label: Item For Child Lock
required: false
type: TEXT
- context: item
description: Item For Window Detection
label: Item For Window Open Detection
required: false
type: TEXT
- context: item
description: Item For Battery
label: Item For Battery
required: false
type: TEXT
- context: item
description: Item For Last Seen
label: Item For Last Seen
required: false
type: TEXT
- context: item
description: Item For Away Preset Temperature
label: Item For Away Preset Temperature
required: false
type: TEXT
- context: item
description: Item For Sensor
label: Item For Sensor
required: false
type: TEXT
- context: item
description: Item For Calibrated
label: Item For Calibrated
required: false
type: TEXT
- context: item
description: Item For Window Open
required: false
type: TEXT
- context: item
description: Item For Valve Detection
label: Item For Valve Detection
required: false
type: TEXT
- context: item
description: Item For Link Quality
label: Item For Link Quality
required: false
type: TEXT
- context: item
description: Item For Voltage
label: Item For Voltage
required: false
type: TEXT
- description: Show info
label: Show Info
required: false
type: BOOLEAN
- context: page + widget
description: Page or Widget to Show
label: Page or Widget to Show
required: false
type: TEXT
- context: action
description: "action to perform (values: popover, popup)"
label: action
required: false
type: TEXT
parameterGroups: []
timestamp: Jan 8, 2023, 3:33:36 AM
component: f7-block
style:
position: relative
-ms-user-select: None
-moz-user-select: None
-webkit-user-select: None
user-select: None
class:
- no-padding
- no-margin
slots:
default:
title: =props.title
slots:
default:
title: Temperature
min: 5
max: 30
label: true
scale: true
unit: °C
step: 0.5
title: System Mode
action: options
actionItem: =[props.system_mode_Item]
title: Preset
action: options
actionItem: =[props.preset_Item]
actionOptions: manual,auto,away
after: =items[props.preset_Item].state
icon: '=(items[props.preset_Item].state === "manual") ? "f7:hand_raised" : (items[props.preset_Item].state === "auto") ? "f7:house" : (items[props.preset_Item].state === "away") ? "f7:circle_grid_hex" : "f7:exclamationmark_circle" '
iconColor: '=(items[props.preset_Item].state === "manual") ? "red" : (items[props.preset_Item].state === "auto") ? "green" : (items[props.preset_Item].state === "away") ? "blue" : "black" '
title: Lock
action: options
actionItem: =[props.child_lock_Item]
actionOptions: LOCK, UNLOCK
after: =items[props.child_lock_Item].state
icon: '=(items[props.child_lock_Item].state === "LOCK" ) ? "f7:lock" : "f7:lock_open" '
iconColor: '=(items[props.child_lock_Item].state === "LOCK" ) ? "green" : "red" '
title: Last Seen
icon: '=(items[props.lastseen_Item].state.toString() === NULL ) ? "f7:exclamationmark_circle" : "f7:calendar" '
iconColor: '=(items[props.lastseen_Item].state.toString() === NULL ) ? "black" : "orange" '
item: =[props.lastseen_Item]
after: =items[props.lastseen_Item].state
action: =props.actionToDo
actionModal: =props.pagetoShow
actionModalConfig:
system_mode_Item: =[props.system_mode_Item]
preset_Item: =[props.preset_Item]
away_preset_temperature_Item: =[props.away_preset_temperature_Item]
child_lock_Item: =[props.child_lock_Item]
sensor_Item: = [props.sensor_Item]
calibrated_Item: = [props.calibrated_Item]
window_detection_Item: =[props.window_detection_Item]
window_open_Item: =[props.window_open_Item]
valve_detection_Item: =[props.valve_detection_Item]
battery_Item: =[props.battery_Item]
voltage_Item: =[props.voltage_Item]
linkquality_Item: =[props.linkquality_Item]
thanks in advance for your help
Option actions should continue to work. Are there any errors shown on the browser console when you click on the widget?
