Why is that? Did you use the metadata.json I send to your email?
I just tried it in the old system, but there I couldn’t run the script. I will try it in the new system later on. What I forgot to say, that all units from z-wave devices are gone except for temperature . There is not Voltage „V“ for electric.potential
The world is ok again. I copied the metadata.json file and it works ok. Thanks a lot.
I made my first foray into openHAB 4 today. I loaded the SNAPSHOT 3842 using openhabian. I had previously updated to Java 17. It appears to have gone fairly smoothly.
The biggest obvious problem I experienced was when I went to add the smart home/j Tuya and AmazonEchoControl bindings. When I first went to the Add-on’s screen in the UI, the smarthome/j bindings were listed after the Community Bindings. A little while after I clicked on install on the AmazonEchoControl and Tuya bindings, there was an error message in the lower left hand corner. It didn’t stay, so I’m going from memory but it was something about JSON file error. After that, the smarthome/j bindings disappeared front the UI. I tried restarting openHAB, but that didn’t help.
I poked around looking for things that looked amiss. There are some references to 3.4 that seem out of place in:
openhabian@openhabian-spring:/var/lib/openhab/config/smarthomej $ cat AddonProvider.config
:org.apache.felix.configadmin.revision:=L"73"
installedAddons="smarthomej-binding-amazonechocontrol_3_2_4"
installedFeatureRepos="mvn:org.smarthomej.addons.features.karaf/org.smarthomej.addons.features.karaf.smarthomej-addons/3.2.4/xml/features"
service.pid="smarthomej.AddonProvider"
runtimeInfo:
version: 4.0.0
buildString: "Build #3482"
locale: en-US
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 17.0.6
javaVendor: Raspbian
osName: Linux
osVersion: 6.1.21-v8+
osArchitecture: arm
availableProcessors: 4
freeMemory: 34531208
totalMemory: 259522560
startLevel: 70
bindings: null
clientInfo:
device:
ios: true
android: false
androidChrome: false
desktop: false
iphone: false
ipod: false
ipad: true
edge: false
ie: false
firefox: false
macos: false
windows: false
cordova: false
phonegap: false
electron: false
nwjs: false
os: ios
osVersion: "16.1"
webView: false
webview: false
standalone: false
pixelRatio: 2
prefersColorScheme: light
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: 7
language: en-US
languages:
- en-US
onLine: true
platform: MacIntel
screen:
width: 1024
height: 1366
colorDepth: 32
support:
touch: true
pointerEvents: true
observer: true
passiveListener: true
gestures: true
intersectionObserver: true
themeOptions:
dark: light
filled: true
pageTransitionAnimation: default
bars: light
homeNavbar: default
homeBackground: default
expandableCardAnimation: default
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15
(KHTML, like Gecko) Version/16.1 Safari/605.1.15
timestamp: 2023-05-28T23:05:29.155Z
I have a few rules I need to sort out. I thought I went through and opened all of my Blocklies and saved them, but I’m still getting a few Errors.
2023-05-28 18:12:29.454 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: dd9beff2-1ccc-4b81-bac0-456fd51c723e
2023-05-28 18:12:29.513 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: 26aebbf6-1481-4b97-b875-dba3d20e5f41
2023-05-28 18:12:29.514 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: dbafca86-c651-4184-b303-9e7100185542
2023-05-28 18:12:29.518 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: dbafca86-c651-4184-b303-9e7100185542
I can’t connect the identifier to anything that would help me figure out which rule is causing the error. Is there some way to do that I’m missing?
Sorry for the slow reply - I never saw your edit. But anyhow, I figured it out today. I was wrongly assuming that if you don’t have the unit
metadata set, it would infer the unit from the state description. As for my debugging… I found a bug in the Ruby helper library that unit
is possibly calling the wrong method. So yeah, I think it was just a few things wrong on my end, and it seems to be working now. Thanks!
openHabian clean install on rpi4 OH4.0.0 #3483 with just EnOcean binding installed.
EnOcean USB300 dongle is automatically put to inbox with correct port.
The port is available and working.
But after adding thing “trying to get bridge base id …” does not work.
2023-05-29 09:53:19.298 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver initialized
2023-05-29 09:53:19.300 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver RX thread started
2023-05-29 09:53:19.300 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'enocean:bridge:FT3OLRGB' changed from OFFLINE (CONFIGURATION_PENDING): opening serial port... to OFFLINE (CONFIGURATION_PENDING): starting rx thread...
2023-05-29 09:53:19.301 [INFO ] [nternal.handler.EnOceanBridgeHandler] - EnOceanSerialTransceiver RX thread up and running
2023-05-29 09:53:19.304 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'enocean:bridge:FT3OLRGB' changed from OFFLINE (CONFIGURATION_PENDING): starting rx thread... to OFFLINE (CONFIGURATION_PENDING): trying to get bridge base id...
Do you have the JavaScript Scripting add-on installed?
No, I did not. Installing it appears to have resolved that problem. Thanks.
Regarding enocean binding, I can find 3 changes in 2023:
EnOcean USB300 dongle “trying to get bridge base id …” does not work
It was reported to be working with OH 4.0.0.M1, but broken on OH 4.0.0.M2 and M3 …
I tested it with OH 4.0.0.M3 and OH4.0.0 #3483. Both show the error on a clean rpi4 openHABian install.
The thing status does not change afterwards? Can you set log:set TRACE org.openhab.binding.enocean
on the karaf console and disable/enable the thing again? You can revert that log setting by exchanging TRACE
with DEFAULT
Please find below the logs with OH 4.0.0.M3:
2023-05-29 15:06:10.699 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'enocean:bridge:FT3OLRGB' to inbox.
2023-05-29 15:07:11.423 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver initialized
2023-05-29 15:07:11.427 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver RX thread started
2023-05-29 15:07:11.430 [INFO ] [nternal.handler.EnOceanBridgeHandler] - EnOceanSerialTransceiver RX thread up and running
2023-05-29 15:07:11.434 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request base id
2023-05-29 15:07:11.441 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:07:11.444 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 08
2023-05-29 15:07:11.446 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700838
2023-05-29 15:07:11.451 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - set postmaster mailboxes
2023-05-29 15:07:11.453 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type SMART_ACK_COMMAND with callback
2023-05-29 15:07:11.455 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request version info
2023-05-29 15:07:11.457 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:07:11.701 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type SMART_ACK_COMMAND, payload 0814
2023-05-29 15:07:11.702 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500020006C40814C4
2023-05-29 15:07:11.963 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 03
2023-05-29 15:07:11.965 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700309
2023-05-29 15:07:57.478 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:07:57.479 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:07:57.481 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Closing the serial port
2023-05-29 15:07:57.515 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:08:09.476 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver initialized
2023-05-29 15:08:09.479 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver RX thread started
2023-05-29 15:08:09.480 [INFO ] [nternal.handler.EnOceanBridgeHandler] - EnOceanSerialTransceiver RX thread up and running
2023-05-29 15:08:09.482 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request base id
2023-05-29 15:08:09.484 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:08:09.488 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 08
2023-05-29 15:08:09.489 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700838
2023-05-29 15:08:09.493 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - set postmaster mailboxes
2023-05-29 15:08:09.494 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type SMART_ACK_COMMAND with callback
2023-05-29 15:08:09.496 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request version info
2023-05-29 15:08:09.497 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:08:09.743 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type SMART_ACK_COMMAND, payload 0814
2023-05-29 15:08:09.745 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500020006C40814C4
2023-05-29 15:08:10.001 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 03
2023-05-29 15:08:10.003 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700309
2023-05-29 15:08:11.460 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
2023-05-29 15:08:11.498 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
2023-05-29 15:09:09.500 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:09:09.502 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:09:09.504 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Closing the serial port
2023-05-29 15:09:09.548 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:09:09.578 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver initialized
2023-05-29 15:09:09.584 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver RX thread started
2023-05-29 15:09:09.586 [INFO ] [nternal.handler.EnOceanBridgeHandler] - EnOceanSerialTransceiver RX thread up and running
2023-05-29 15:09:09.588 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request base id
2023-05-29 15:09:09.591 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:09:09.596 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 08
2023-05-29 15:09:09.598 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700838
2023-05-29 15:09:09.603 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - set postmaster mailboxes
2023-05-29 15:09:09.605 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type SMART_ACK_COMMAND with callback
2023-05-29 15:09:09.607 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request version info
2023-05-29 15:09:09.609 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:09:09.853 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type SMART_ACK_COMMAND, payload 0814
2023-05-29 15:09:09.856 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500020006C40814C4
2023-05-29 15:09:10.115 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 03
2023-05-29 15:09:10.118 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700309
2023-05-29 15:09:11.502 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:09:11.504 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:09:11.506 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:09:11.508 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
2023-05-29 15:09:11.544 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
22023-05-29 15:10:09.611 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:10:09.614 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:10:09.618 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Closing the serial port
2023-05-29 15:10:09.650 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:10:09.680 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver initialized
2023-05-29 15:10:09.682 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver RX thread started
2023-05-29 15:10:09.686 [INFO ] [nternal.handler.EnOceanBridgeHandler] - EnOceanSerialTransceiver RX thread up and running
2023-05-29 15:10:09.691 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request base id
2023-05-29 15:10:09.694 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:10:09.696 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 08
2023-05-29 15:10:09.699 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700838
2023-05-29 15:10:09.709 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - set postmaster mailboxes
2023-05-29 15:10:09.712 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type SMART_ACK_COMMAND with callback
2023-05-29 15:10:09.713 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request version info
2023-05-29 15:10:09.716 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:10:09.960 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type SMART_ACK_COMMAND, payload 0814
2023-05-29 15:10:09.962 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500020006C40814C4
2023-05-29 15:10:10.217 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 03
2023-05-29 15:10:10.219 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700309
2023-05-29 15:10:11.547 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:10:11.549 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:10:11.551 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:10:11.553 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
2023-05-29 15:10:11.582 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
22023-05-29 15:11:09.718 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:11:09.720 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:11:09.722 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Closing the serial port
2023-05-29 15:11:09.780 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:11:09.810 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver initialized
2023-05-29 15:11:09.814 [INFO ] [ernal.transceiver.EnOceanTransceiver] - EnOceanSerialTransceiver RX thread started
2023-05-29 15:11:09.816 [INFO ] [nternal.handler.EnOceanBridgeHandler] - EnOceanSerialTransceiver RX thread up and running
2023-05-29 15:11:09.819 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request base id
2023-05-29 15:11:09.821 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:11:09.825 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 08
2023-05-29 15:11:09.830 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700838
2023-05-29 15:11:09.840 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - set postmaster mailboxes
2023-05-29 15:11:09.842 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type SMART_ACK_COMMAND with callback
2023-05-29 15:11:09.844 [DEBUG] [nternal.handler.EnOceanBridgeHandler] - request version info
2023-05-29 15:11:09.845 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Enqueue new send request with ESP3 type COMMON_COMMAND with callback
2023-05-29 15:11:10.090 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type SMART_ACK_COMMAND, payload 0814
2023-05-29 15:11:10.092 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500020006C40814C4
2023-05-29 15:11:10.348 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Sending data, type COMMON_COMMAND, payload 03
2023-05-29 15:11:10.349 [TRACE] [ernal.transceiver.EnOceanTransceiver] - Sending raw data: 5500010005700309
2023-05-29 15:11:11.585 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - shutting down transceiver
2023-05-29 15:11:11.587 [DEBUG] [ernal.transceiver.EnOceanTransceiver] - Interrupt rx Thread
2023-05-29 15:11:11.588 [INFO ] [ernal.transceiver.EnOceanTransceiver] - Transceiver shutdown
2023-05-29 15:11:11.591 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
2023-05-29 15:11:11.622 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler EnOceanBridgeHandler tried updating the thing status although the handler was already disposed.
I’ve opened a new issue against the Main UI, however I’m concerned it’s related to the core and not the UI itself (specifically with how/when the addon is loaded). Addons where a jar is put into the addons folder show up without issues when trying to manually add a thing on the UI. Addons pulled in from the marketplace don’t have any option to manually add a thing with the error “No thing types can be added with this binding.” I have this happening across all 3 of the bindings I have in the marketplace right now, I just used Ring as an example.
Just checked with Webex Binding, which lets me add an account thing manually.
So it seems not to be a UI or core bug, but a binding issue.
Interesting. Do the jars get loaded at a different time between the two? I did my tests with the exact same jar file. Not sure why it would work on one and fail on the other.
Is there an addon.xml in the jar?
Yes. There is actually both addon and binding on those for compatibility in the marketplace.
I’m not sure if this is fixed as part of the upgrade tool or not. You might need to delete the org.openhab.marketplace.json file from the jsondb folder (and the backup folder if it’s there) and let OH recreate it.
I recommend going forward, when you create a rule always change the randomly generated uid with something meaningful. For these, search for the rule id on the rules page. Search works on the names and the ids. Search in the developer sidebar should work too.
It might be a Script too so search there also. But the root problem, as you found is the add-on isn’t installed.
