Does it makes sense to open an issue for these addons then to let the owners know that this need to be done? How is this usually handled? Do the codeowners have to take care of that?
None of these I have actually installed or it is telling me because it didn’t startup correctly.
i DO know, that my backup which I restored contains INFLUXDB.
Therefore I removed influxdb in /srv/openhab-userdata/config/org/openhab/addons.config
Note that I also did a clean-cache before the restart.
and now it is starting up!
Btw, I found another one that uses gson 2.9.0 : org.openhab.binding.bluetooth.generic
UPDATE:
Unfortunately it gets further but I still have the following errors in the log
2022-12-26 23:28:00.177 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: fb6c8e18-252f-4e8c-9f06-882824c744a7
2022-12-26 23:28:00.223 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - ScriptEngine for language 'application/javascript' could not be found for identifier: 97ee8cff-60f2-49ca-a99f-437beb9d39dd
2022-12-26 23:28:05.807 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-package-standard': Error:
Error downloading mvn:com.google.code.gson/gson/2.8.9
2022-12-26 23:28:07.264 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-persistence-mapdb, openhab-binding-deconz, openhab-misc-openhabcloud, openhab-binding-network, openhab-ui-habpanel, openhab-binding-nanoleaf, openhab-binding-jeelink, openhab-automation-jsscripting, openhab-binding-shelly, openhab-binding-chromecast, openhab-binding-mqtt, openhab-transformation-map, openhab-binding-ipcamera, openhab-binding-lgwebos, openhab-binding-systeminfo, openhab-binding-icalendar, openhab-binding-mail, openhab-voice-googletts, openhab-transformation-regex, openhab-binding-yamahareceiver, openhab-transformation-jsonpath, openhab-binding-homeconnect, openhab-binding-zwave, openhab-persistence-rrd4j, openhab-ui-basic, openhab-binding-ntp, openhab-binding-openweathermap, openhab-binding-gardena, openhab-binding-http, openhab-binding-astro, openhab-binding-unifi, openhab-binding-squeezebox, openhab-binding-gpstracker, openhab-binding-onkyo': Error:
2022-12-26 23:28:08.503 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed to refresh bundles after processing config update
org.apache.karaf.features.internal.util.MultiException: Error:
at org.apache.karaf.features.internal.download.impl.MavenDownloadManager$MavenDownloader.<init>(MavenDownloadManager.java:91) ~[?:?]
I installed the NASHORN addon and at least "ScriptEngine for language ‘application/javascript’ could not be found " has gone away.
