Upgraded to #3313 and all rules are broken. There appears to be up to three separate problems.
Problem 1
The first seems to be a problem with the addon.xml file for the Zigbee binding.
20│--------------------------------------------- file got truncated /srv/openhab/userdata/logs/openhab.log 2023/02/14 07:56:04---------------------------------------------│
20│2023-02-14 07:56:11.707 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.0.0 (build Build #3313) │
20│2023-02-14 07:56:12.501 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'America/Denver'. │
20│2023-02-14 07:56:12.516 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to 'X,Y'. │
20│2023-02-14 07:56:12.517 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'en_US'. │
20│2023-02-14 07:56:12.518 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'US'. │
20│2023-02-14 07:56:19.406 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'test.items' │
20│2023-02-14 07:56:20.031 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist' │
20│2023-02-14 07:56:20.098 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist' │
20│2023-02-14 07:56:28.775 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007 │
20│2023-02-14 07:56:34.019 [WARN ] [ty.util.ssl.SslContextFactory.config] - Trusting all certificates configured for Client@581281f4[provider=null,keyStore=null,trustStore│
20│=null] │
20│2023-02-14 07:56:34.020 [WARN ] [ty.util.ssl.SslContextFactory.config] - No Client EndPointIdentificationAlgorithm configured for Client@581281f4[provider=null,keyStore│is.g│=null,trustStore=null] │
00│2023-02-14 07:56:34.036 [WARN ] [core.thing.internal.ThingManagerImpl] - No config description for 'channel-type:http:channel-config-switch' found when normalizing conf│5920│iguration for 'http:url:adguard:protection_status'. This is probably a bug. │
20│2023-02-14 07:56:34.100 [INFO ] [nding.http.internal.HttpThingHandler] - Using the insecure client for thing 'http:url:adguard'. │
20│2023-02-14 07:56:34.456 [INFO ] [.network.internal.utils.NetworkUtils] - CIDR prefix is smaller than /24 on interface with address 172.17.0.1/16, truncating to /24, som│
20│e addresses might be lost │
20│2023-02-14 07:56:36.764 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager started at http(s)://10.10.1.112:8080/shelly/manager │
20│2023-02-14 07:56:37.017 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to 'argus.koshak.lan' with clientid openhab │
20│2023-02-14 07:56:37.240 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/OH-INF/addon/addon.xml' in module 'org.openhab.binding.zigbee' could not be │
20│parsed: │
20│---- Debugging information ---- │
20│cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassException │
20│cause-message : author │
20│class : java.util.ArrayList │
20│required-type : java.util.ArrayList │
20│converter-type : com.thoughtworks.xstream.converters.collections.CollectionConverter │
20│path : /addon/author │
20│line number : 10 │
20│class[1] : org.openhab.core.addon.xml.internal.AddonInfoXmlResult │
20│required-type[1] : org.openhab.core.addon.xml.internal.AddonInfoXmlResult │
20│converter-type[1] : org.openhab.core.addon.xml.internal.AddonInfoConverter │
20│version : 1.4.19 │
20│------------------------------- │
20│com.thoughtworks.xstream.converters.ConversionException: │
20│---- Debugging information ---- │is.g│cause-exception : com.thoughtworks.xstream.mapper.CannotResolveClassException │
20│converter-type : com.thoughtworks.xstream.converters.collections.CollectionConverter │is.g│path : /addon/author │
00│ at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:81) ~[bundleFile:1.4.19] │1020│ at com.thoughtworks.xstream.core.AbstractReferenceUnmarshaller.convert(AbstractReferenceUnmarshaller.java:72) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:68) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:52) ~[bundleFile:1.4.19] │
20│ at org.openhab.core.addon.xml.internal.AddonInfoConverter.unmarshal(AddonInfoConverter.java:77) ~[?:?] │
20│ at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:74) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:136) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1421) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1399) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1350) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1304) ~[bundleFile:1.4.19] │
20│ at org.openhab.core.config.xml.util.XmlDocumentReader.readFromXML(XmlDocumentReader.java:105) ~[bundleFile:?] │
20│ at org.openhab.core.config.xml.osgi.XmlDocumentBundleTracker.parseDocuments(XmlDocumentBundleTracker.java:396) [bundleFile:?] │
20│ at org.openhab.core.config.xml.osgi.XmlDocumentBundleTracker.processBundle(XmlDocumentBundleTracker.java:382) [bundleFile:?] │
20│ at org.openhab.core.config.xml.osgi.XmlDocumentBundleTracker$2.run(XmlDocumentBundleTracker.java:347) [bundleFile:?] │
.g│ at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?] │
20│ at java.util.concurrent.FutureTask.run(FutureTask.java:264) [?:?] │
20│ at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?] │
20│ at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) [?:?] │
20│ at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) [?:?] │is.g│ at java.lang.Thread.run(Thread.java:833) [?:?] │
20│Caused by: com.thoughtworks.xstream.mapper.CannotResolveClassException: author │
20│ at com.thoughtworks.xstream.mapper.DefaultMapper.realClass(DefaultMapper.java:81) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.mapper.DynamicProxyMapper.realClass(DynamicProxyMapper.java:55) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.mapper.PackageAliasingMapper.realClass(PackageAliasingMapper.java:88) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.mapper.ClassAliasingMapper.realClass(ClassAliasingMapper.java:79) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125) ~[bundleFile:1.4.19] │is.g│ at com.thoughtworks.xstream.mapper.ArrayMapper.realClass(ArrayMapper.java:74) ~[bundleFile:1.4.19] │
00│ at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:71) ~[bundleFile:1.4.19] │3320│ at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readBareItem(AbstractCollectionConverter.java:131) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:117) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.converters.collections.CollectionConverter.addCurrentElementToCollection(CollectionConverter.java:99) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:92) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:86) ~[bundleFile:1.4.19] │
20│ at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:81) ~[bundleFile:1.4.19] │
20│ ... 24 more │
The Zwave binding has a similar error.
Problem 2
The second problem is related to creating the script engine.
20│2023-02-14 07:56:38.495 [INFO ] [ort.loader.AbstractScriptFileWatcher] - (Re-)Loading script '/openhab/conf/automation/js/node_modules/openhab/@globals-webpack.config.j│
20│s' │
20│2023-02-14 07:56:39.006 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = d0...e1, base URL = http://localhost:8080) │is.g│2023-02-14 07:56:43.934 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error while creating ScriptEngine │
20│org.graalvm.polyglot.PolyglotException: Cannot invoke "java.nio.file.Path.resolve(java.nio.file.Path)" because the return value of "java.nio.file.Path.getRoot()" is nul│
20│l │
20│ at org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine.isRootNodePath(OpenhabGraalJSScriptEngine.java:312) ~[?:?] │
20│ at org.openhab.automation.jsscripting.internal.OpenhabGraalJSScriptEngine$1.checkAccess(OpenhabGraalJSScriptEngine.java:190) ~[?:?] │is.g│ at com.oracle.truffle.api.TruffleFile.checkAccess(TruffleFile.java:2125) ~[?:?] │
20│ at com.oracle.truffle.api.TruffleFile.exists(TruffleFile.java:288) ~[?:?] │
20│ at com.oracle.truffle.js.runtime.JSRealm.addCommonJSGlobals(JSRealm.java:1617) ~[?:?] │
20│ at com.oracle.truffle.js.runtime.JSRealm.addOptionalGlobals(JSRealm.java:1692) ~[?:?] │
20│ at com.oracle.truffle.js.runtime.JSRealm.initialize(JSRealm.java:2193) ~[?:?] │
20│ at com.oracle.truffle.js.lang.JavaScriptLanguage.initializeContext(JavaScriptLanguage.java:362) ~[?:?] │is.g│ at com.oracle.truffle.js.lang.JavaScriptLanguage.initializeContext(JavaScriptLanguage.java:114) ~[?:?] │
20│ at com.oracle.truffle.api.TruffleLanguage$Env.postInit(TruffleLanguage.java:3317) ~[?:?] │
00│ at com.oracle.truffle.api.LanguageAccessor$LanguageImpl.postInitEnv(LanguageAccessor.java:289) ~[?:?] │0920│ at com.oracle.truffle.polyglot.PolyglotLanguageContext.ensureInitialized(PolyglotLanguageContext.java:689) ~[?:?] │
20│ at com.oracle.truffle.polyglot.PolyglotContextImpl.eval(PolyglotContextImpl.java:1294) ~[?:?] │
20│ at com.oracle.truffle.polyglot.PolyglotContextDispatch.eval(PolyglotContextDispatch.java:63) ~[?:?] │
20│ at org.graalvm.polyglot.Context.eval(Context.java:399) ~[?:?] │
20│ at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.evalInternal(GraalJSScriptEngine.java:376) ~[?:?] │
20│ at com.oracle.truffle.js.scriptengine.GraalJSBindings.initGlobal(GraalJSBindings.java:96) ~[?:?] │
20│ at com.oracle.truffle.js.scriptengine.GraalJSBindings.initContext(GraalJSBindings.java:92) ~[?:?] │
20│ at com.oracle.truffle.js.scriptengine.GraalJSBindings.requireContext(GraalJSBindings.java:86) ~[?:?] │
20│ at com.oracle.truffle.js.scriptengine.GraalJSBindings.put(GraalJSBindings.java:129) ~[?:?] │
20│ at javax.script.SimpleScriptContext.setAttribute(SimpleScriptContext.java:246) ~[java.scripting:?] │
20│ at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.addAttributeToScriptContext(ScriptEngineManagerImpl.java:286) ~[?:?] │
20│ at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.createScriptEngine(ScriptEngineManagerImpl.java:156) ~[?:?] │
20│ at org.openhab.core.automation.module.script.rulesupport.loader.AbstractScriptFileWatcher.createAndLoad(AbstractScriptFileWatcher.java:328) ~[?:?] │9.78│ at org.openhab.core.automation.module.script.rulesupport.loader.AbstractScriptFileWatcher.lambda$15(AbstractScriptFileWatcher.java:306) ~[?:?] │
20│ at java.util.concurrent.CompletableFuture$AsyncRun.run(CompletableFuture.java:1804) [?:?] │
20│ at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?] │
20│ at java.lang.Thread.run(Thread.java:833) [?:?] │is
This error repeats for every file in $OH_CONF/automation/js
Problem 3 (may be another symptom of Problem 2)
Several of my rules are throwing this error:
20│2023-02-14 07:56:43.958 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'debounce4': Cannot invoke "java.util.Map.put(Object, Object)" because "│
.g│this.global" is null │
It seems reasonable that this error is caused by problem 2 failing to load and/or initialize something (cache
perhaps?).
