Well, this is embarrassing. I know that folder shouldn’t be there and I don’t know how it got there. I must have done a mv .. instead of mv ~ at some point during testing without realizing it (probably when I was trying to get openhab-js 4.0 installed with npm and it kept installing the older version). It’s been there for a few weeks. Weird how it’s only now generating errors.
Anyway, that was the problem. I think for the first time since I’ve installed the OH 4.0 SNAPSHOT my startup is without significant errors and everything appears to work. I still have to restart after OH comes up after a cache clearing but issues are open for that.
Thanks! I apologize for the false alarm but at least now I know what it means when I see that and can help users in the future when I see it.
one more issue i noticed while saving a rule is the below error
2023-02-24 16:56:06.085 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'marantz.rules'
2023-02-24 16:56:06.138 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'marantz.rules' is either empty or cannot be parsed correctly!
2023-02-24 16:56:06.139 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'marantz.rules'
var Timer Wait_Timer = null
rule "Load Marantz.rules"
System started
logInfo("info", "Loaded model 'Marantz.rules'")
rule "Dialogpegel +"
Item DialogPlus changed to ON
if( DialogPlus.state == ON ){
logInfo("TV Dialogpegel +","TV Dialogpegel +")
marantz_command.sendCommand("PSDIL UP")
DialogPlus.sendCommand(OFF)}
rule "Dialogpegel -"
Item DialogMinus changed to ON
if( DialogMinus.state == ON ){
logInfo("TV Dialogpegel -","TV Dialogpegel -")
marantz_command.sendCommand("PSDIL DOWN")
DialogMinus.sendCommand(OFF)}
rule "TV on"
Item Marantz_power changed to ON
then {
LG_TV1_Power.sendCommand(ON)
logInfo("TV und Amiblight AN", "TV und Amiblight AN")
if (Wait_Timer === null) {
Wait_Timer = createTimer(now.plusSeconds(7)) [ |
if( LedDeviceEnabled.state == OFF ) {
HyperionEnabled.sendCommand(ON)
LedDeviceEnabled.sendCommand(ON)
logInfo("Amiblight AN" , "Ambilight an")
Wait_Timer = null }
if( LedDeviceEnabled.state.state == ON ) {
logInfo("Amiblight AN", "Ambilight war an")
Wait_Timer = null }
rule "TV off"
Item Marantz_power changed to OFF
then {
LG_TV1_Power.sendCommand(OFF)
logInfo("TV und Ambilight AUS" , "TV und Ambilight AUS")
HyperionEnabled.sendCommand(OFF)
LedDeviceEnabled.sendCommand(OFF)
what’s wrong in this rule ? btw the rule is working !
Better don’t use + or - as part of the logger name as well as of rule names.
Please be aware that the first string argument of logInfo() is part of the logger name. This is not meant to be a specific text. All log commands with the same logger name can be controlled as a group. Let’S say you are using logInfo, logWarn and logError, you can set the same logger name to all of them. If setting the log level to WARN, logInfo messages will be suppressed, while logWarn and logError will be still logged. There even es a logDebug command, you have to set the log level to Debug to get these messages. and the log level is set per logger name, so the common way would be to use maybe
logInfo("marantz","TV Dialogpegel +")
and all stuff regarding marantz will be logged with this name. Ich you don’t want to see these messages, just set org.openhab.core.model.script.marantz to WARN.
I just started seeing this on recent snapshot builds (I’m on 3320). My openHAB runs on Ubuntu 22.04 and exposes a Samba share, If I edit a file on the Samba share using my Mac (using vscode, vi, or any other editor), I see that behavior when I save the file.
This happened a really, really long time ago (openHAB 2.x?), but I suspect something recently changed that causes it to occur again.
I have replaced all + and minus, still the same, running Debian 11.6 as Proxmox VM.
File was edited via samba share with win10 pnotepad.
if I modify the file with Nano locally the problem is gone !
Thomas
The problem with this approach is that we effectively lose events.
What I see is the sequence DELETE - CREATE - DELETE- CREATE when in fact the file was modified. If we discard everything except the last event (which is what the code above does), we end up with CREATE. In the current implementation of model repository and script file watchers it doesn’t matter as they handle CREATE and MODIFY in the same way, but in general DELETE would remove (whatever) and CREATE would add (whatever), while MODIFY would first remove and the add (whatever), so if we discard the DELETE event it could be that (whatever) is added twice.
Yeah, the original “fix” was not ideal, as it only worked around the problem.
BTW, it’s a bit more messy with items, as a simple change to the file now give you this, which can be short or long depending on how extensively the items are used in rules…
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'hvac-automation-2' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'presence-3' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'hvac-automation-1' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'presence-2' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'presence-1' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'PresenceMark' needed for rule 'presence-4' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Uptime_Mark' needed for rule 'presence-7' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'PresenceCathy' needed for rule 'presence-5' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Uptime_Cathy' needed for rule 'presence-8' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'PresenceMelanie' needed for rule 'presence-6' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.219 [WARN ] [dule.handler.ItemStateTriggerHandler] - Item 'Uptime_Melanie' needed for rule 'presence-9' removed. Trigger '0' will no longer work.
2023-02-25 09:12:35.239 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'unifi.items'
2023-02-25 09:12:35.250 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'unifi.items'
2023-02-25 09:12:35.255 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'hvac-automation-2' added. Trigger '0' will now work.
2023-02-25 09:12:35.255 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'presence-3' added. Trigger '0' will now work.
2023-02-25 09:12:35.255 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'hvac-automation-1' added. Trigger '0' will now work.
2023-02-25 09:12:35.255 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'presence-2' added. Trigger '0' will now work.
2023-02-25 09:12:35.255 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'gPresence' needed for rule 'presence-1' added. Trigger '0' will now work.
2023-02-25 09:12:35.257 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'PresenceMark' needed for rule 'presence-4' added. Trigger '0' will now work.
2023-02-25 09:12:35.257 [INFO ] [g.openhab.core.model.script.presence] - PRESENCE: Mark is home
2023-02-25 09:12:35.264 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'Uptime_Mark' needed for rule 'presence-7' added. Trigger '0' will now work.
2023-02-25 09:12:35.267 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'PresenceCathy' needed for rule 'presence-5' added. Trigger '0' will now work.
2023-02-25 09:12:35.267 [INFO ] [g.openhab.core.model.script.presence] - PRESENCE: Cathy is home
2023-02-25 09:12:35.272 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'Uptime_Cathy' needed for rule 'presence-8' added. Trigger '0' will now work.
2023-02-25 09:12:35.273 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'PresenceMelanie' needed for rule 'presence-6' added. Trigger '0' will now work.
2023-02-25 09:12:35.273 [INFO ] [g.openhab.core.model.script.presence] - PRESENCE: Melanie is away
2023-02-25 09:12:35.277 [INFO ] [dule.handler.ItemStateTriggerHandler] - Item 'Uptime_Melanie' needed for rule 'presence-9' added. Trigger '0' will now work.
I think I have a solution for that, but I need a working “latest snapshot” for that. I believe this should be available tomorrow, now that the add-ons build has been fixed
I migrated from 3.3 stable to 3.4.2 stable and have the same problems like you.
2023-02-28 18:18:15.646 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - Creating ZWave discovery service for zwave:serial_zstick:23fcd2f523 with scan time of 60
2023-02-28 18:18:15.647 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Active zwave:serial_zstick:23fcd2f523
2023-02-28 18:18:15.647 [INFO ] [zwave.handler.ZWaveControllerHandler] - Attempting to add listener when controller is null
2023-02-28 18:18:15.670 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Initializing ZWave serial controller.
2023-02-28 18:18:15.671 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Initializing ZWave Controller zwave:serial_zstick:23fcd2f523.
After that nothing. When I switch the docker images everything is fine with the hardware.
So maybe this not dependent from Java 17?
Maybe you found a solution?
I forgot about that issue. I’ve not actually seen that in awhile, or if I have, it occurs after a clearing of the cache and I need to reboot for the Shelly binding problems and it goes away. ON the latest snapshot Zigbee and Zwave work just fine for me.
